Oil drain pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Av8er, Nov 14, 2012.
  1. Nov 16, 2012 at 5:29 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I have used the same pan for a lot of years. I like to cut out the top so that the oil doesn't splash out. As soon as it is drained and filled, I just pour it back into the 5 quart jug and take it to the recycling place.
  2. Nov 16, 2012 at 5:42 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I use the pan from wally world, don't really have much splashing going on. And I have two 12qt containers I bought from O'Reilly's (they're nice b/c they have bigger opening than a 5qt jug to pour oil into, no need for a funnel) and once they're full I dump them at Advance Auto parts
  3. Nov 16, 2012 at 8:03 PM
    Av8er
    Av8er [OP] Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    Just did the wifes oil change and that was the last straw with that one. Gonna go with a new catcher and then pour the spent oil into the emptied 5qt.'s when finished for transport to AZ.
    Thanks for all the great ideas folks!! Cool to see the creativity amongst the group.
  4. Nov 16, 2012 at 9:51 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    I had this: http://www.quickoildrainvalve.com/ on my 2002. It made draining the oil a breeze. Just hooked some vinyl tubing that I bought at Home Depot to the valve, ran the other end into a drain pan, turned the valve and chilled while the oil drained out. Once it was done, close the valve, disconnect the tubing and toss it. No mess, no fuss. You could put the oil into anything this way, even back into the original container your oil came in.
  5. Nov 16, 2012 at 10:10 PM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    yeah, dont but a drain pan like the one posted from walmart, changed my oil today just to find out the cheap ass pan's front cap doesnt screw on straight and leaked oil everywhere.
  6. Nov 17, 2012 at 7:07 AM
    Av8er
    Taylor
    I like these fumoto's drains!! I've been checkin' them out the last few days. The version for the accord will require an additional adapter to keep the the assembly from extending too far into the drain pain. I'll probably bite the bullet and grab these for both taco and accord soon.
  7. Nov 17, 2012 at 12:50 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    I run the fumoto valve on my truck and it does make oil changes that much easier. It does take a little longer for the oil to drain though, but worth it IMO.
  8. Nov 17, 2012 at 7:58 PM
    Beers
    Colorado
    12 TRD OR
    It does take longer since the drain hole is only half the size due to the shutoff valve but since you can set it up and walk away, i don't mind the extra few minutes. That time gets made up by not having a mess to clean up later.
  9. Nov 17, 2012 at 8:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto.
    It takes a while to position my body, arms, and zip-lock bag to remove the oil filter from the 2nd Gen 2.7 working on my 5-lug without using a jack or ramps.
    You guys with the 4.0 got it EASY!
  10. Nov 17, 2012 at 8:41 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
  11. Nov 18, 2012 at 9:18 AM
    Beers
    Colorado
    12 TRD OR
    My 2002 was a 2.7L so I know the pain! I used the Solo "Beer Cups" to grab the oil filter and catch most of the oil that came out but always had some to clean up on the skid plate. The 45 degree angle of the drain plug didn't help things any either. I couldn't believe how far the oil could shoot back. You needed a 3' trough to catch the oil without spilling it. At least mine was a Prerunner so I had room to crawl under and reach everything without needing a jack or ramps. This 4.0 will be so much nicer to do the oil changes with.
  12. Nov 18, 2012 at 10:27 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    On the 2nd Gen 2.7, the filter sits out from the block a bit, so unlike my old 22RE, the oil doesn't run down the side of the block, but there's a slight kickout at the oil pan, and the trans cooler lines are directly under the edge of the filter.
    Even parking with the driver's side slightly elevated, the oil still hits the cooler lines.
    If I were to use ramps and elevate the nose, the oil would hit the lines AND the front crossmember.
  13. Nov 18, 2012 at 10:47 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Quite the discussion youve got here. I just park over top an open sewer and let gravity do the work.:p
    No no I dont. Ive been using the same oil catch pan for years (since about 16). The regular round open face catcher. Fills right to the brim every time.
    If you have any issues with spillage I suggest Brake Cleaner in an aerosol can. If youve never used it to clean oil before your in for a pleasant surprise. Ive lifted 30 year old oil stains with that stuff. Spray on affected area, pat to lift oil and watch the rest dry.
  14. Nov 18, 2012 at 11:04 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Works on concrete.
    Eventually erodes asphalt.
    Destroys epoxy floor coatings... ask my former boss what I did to the warehouse floor.
  15. Nov 18, 2012 at 11:25 AM
    #35
    ImplicitlyAlberta
    David
    edmonton
    Yes. Thank you for pointing that out.
    Boy would there have been some unhappy people.:D
    Also, do not use on any plastics. Made that mistake once.
  16. Nov 18, 2012 at 11:35 AM
    #36
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    or leather
  17. Nov 18, 2012 at 11:50 AM
    #37
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I do this also, once my bucket is full. I take it to recycle. Also OP, I have the same pan, and I hate, no matter how I position it, oil splashes out as soon as I pull the plug. So that same powdered laundry detergent gets put on the oil stain in the driveway. That shit works great. I just spread it on the oil, and let the rain wash it away. Cleanest spot on the driveway, until next oil change that is. :D
