Oil Drain Plug Gasket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dustyroades, Feb 23, 2012.
  1. Aug 16, 2014 at 8:48 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    + 1 on the FUMOTO valve. No more washer problems.
  2. Aug 16, 2014 at 8:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Actually the money wasn't wasted. You learned something. Do Not over tighten brass. It is a good thing it was the brass. If it was steel and you borked the oil pan you would be shitting.
  3. Aug 16, 2014 at 9:34 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    But if I make it so tight maybe just maybe the 1mm I get will give me tons of clearance.
  4. Aug 16, 2014 at 11:50 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    Thanks for the heads up.
  5. Aug 17, 2014 at 5:02 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hmmmm. Didn't think about that. [​IMG]
  6. Aug 17, 2014 at 11:37 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    my dealer give you the crush washer with the filter purchase; don't think they track them too seriously. I do use them over and over though if I don't have a new one. Maybe be certain there's a little new oil on the pan side of the washer - usually wipe it clean but maybe a bad idea as it'll stick to the paint?
  7. Aug 17, 2014 at 11:56 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Mine gets stuck too, but I just wipe it clean and screw the oil pan bolt back in. Done it on three oil changes already. No leaks.
  8. Aug 17, 2014 at 7:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    A good while ago they used copper gaskets instead of crush washers. On my wifes old Camry Wagon I used the factory washer as long as she had the car ~ 199,000 miles.
  9. Sep 11, 2014 at 11:36 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Single edge razor blade works fine for removing baked on oil pan gaskets. Hold firmly and take your time.
  10. Nov 8, 2014 at 7:54 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well it is brass. [​IMG]
  11. Nov 9, 2014 at 7:10 AM
    Lester Lugnut
    I agree. I bought one of these from Griot's Garage several years ago and it still works great. Beware that there are many copies on the web that come with "short" hoses. If you buy one of these, you won't be siphoning much.
    Not just for oil. Can siphon transmission pans with no drain plug, power steering and brake reservoirs. Turkey basters are usually dead after one
    use as the chemicals kill the seal.
