oil drain plug ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blue02r1, Nov 10, 2010.
  1. Nov 10, 2010 at 3:27 PM
    blue02r1
    blue02r1 [OP] tom
    tom
    pennsylvainia
    2011 trd timberland green
    toyota hood protector, AVS vent shades, Toyota Bed Mat, TRD Catback Exhaust , K&N Intake, Tacoma Bedmat, Weathertech Mats, Extang Tuff Toneau ,Foglight Mod.
    not going to be home for my 1st oil change on my 2011 and want to make sure i have what i need without taking anything xtra, so i was wondering what size the drain plug is and do you have to take the skid plate off to get to the drain plug like i did on my 04. thanks for the help.
  2. Nov 10, 2010 at 3:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Probably a 13mm but just crawl under there with some sockets and see which one fits. You don't need to remove the skid.
  3. Nov 10, 2010 at 3:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  4. Nov 10, 2010 at 3:35 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    14mm
    There's an hole in the skid plate where the drain plug is. The drain plug torque is 30 ft-lbs.
  5. Nov 10, 2010 at 4:56 PM
    TACONORM
    TACONORM Member
    NORM
    FL
    2010 TRD OR 4X4
    I used mobil 1, the filter size is M1-102, should cost around 12-13 bucks and Mobil 1's 0W-30 synthetic, should cost around 22-24 dollars for a 5 quart jug. Since the engine takes 5.5 quarts you'll need to buy a seperate quart at around 5 bucks. The drain plug is 14mm and I used a crushable washer and torqued it down to spec (30 ft/lbs)
  6. Nov 10, 2010 at 6:04 PM
    AlerAero
    AlerAero Equipment MFG
    Northern Vermont
    09 Tacoma V6 SR5 4x4
    BakFlip Folding Tonneau, Locking bed storage compartments, Bug/rock guard, Anytime backup cam mod, Hitch + wiring
    OK I feel I need to ask you to please use the search function this question has been beat to death.
  7. Nov 10, 2010 at 6:09 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    at least its a valid question....
    not like he is asking whats the best type of lift or for pics of black rims:D
  8. Nov 10, 2010 at 6:12 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i use amsoil....what
    tmuhler likes this.
  9. Nov 10, 2010 at 6:13 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    i agree better have him do it right and not drain trans oil like some have by accident
  10. Nov 10, 2010 at 6:36 PM
    AlerAero
    Northern Vermont
    yes but all the information is all available on here! I found the right way to change all my diff a trans case oil, what i needed for my first oil change and what to watch out for. almost all my question have been solved with a search.
  11. Nov 10, 2010 at 6:42 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Wow. :infantry:
  12. Nov 10, 2010 at 8:31 PM
    blue02r1
    blue02r1 [OP] tom
    tom
    pennsylvainia
    thanks for all your help. i guess i could have searched it , but thanks for all your info and patience.. love my new truck way better than my 04 which was great aswell. 7 years makes a big difference!!!!!!!!!!
  13. Nov 11, 2010 at 4:18 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    I didn't see where you identified which engine you have. The 4 cyl takes more oil than the 6. Better to have enough oil with you after you drain than realize you need more than you have.
  14. Nov 11, 2010 at 4:53 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    This.....If your just really quick, it can happen.
