Oil everywhere on skidplate with metal shavings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tailzz, May 21, 2016.
  1. May 29, 2016 at 2:10 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    2000 tacoma trd prerunner 2d
    Bilstein 5150 front adjustable shocks set at 2 1/2 inc on 31×10.50 goodyear wranglers
    Thank u cle for the only logical answer. I had asked all these so called know it alls a simple que,and no answer. Simply asked if there is any kind of oil our fluid that runs threw the front end,our front driveline. They said no im not fourwheel drive. Come to find out there is,its called power stering FLUID duh. Blew a seal and that is where metal shavings and fluid was coming from. Just wish i read your advice sooner.
  2. May 29, 2016 at 2:40 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Hmm. If you would have actually looked before you posted this thread.....you would have found the problem. The smart ass answers are justified by YOU not taking the time to LOOK for the problem and giving shady answers to questions. Next time....take the little step of diagnosing a problem prior to posting and describing in detail of what you found. Oil and metal shaving on the front skid plate can be from many things as you have found out.
  3. May 29, 2016 at 3:37 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Id say both these guys tried to help but with no pics or anything they can't help you
    robssol likes this.
  4. May 29, 2016 at 5:08 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    POWER STEERING FLUID?!? Make sure you put in the right stuff! You can read right? Maybe not very well judging by your responses or lack there of. Good luck replacing that rack:rolleyes:
    The Hunter likes this.
  5. May 30, 2016 at 10:51 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    Atypical, all u guys do a great job of taking shit. Please just quit before u go home with your tail between your legs. The world already has plenty of nincompoops with your guys help. Now run along.
  6. May 30, 2016 at 10:52 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    Now I'm the duche bag tool Lmbo!
  7. May 30, 2016 at 10:55 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You keep saying front end as if you are 4wd. Saying oil that lubricates the front end...? The motor has oil, the power steering uses ATF...and the tranny has oil...no gear oil up front....you should post pics because it is clear you are confused.
  8. May 30, 2016 at 10:56 PM
    anthony250f
    Anthony
    San Diego, CA
    Did you verify that it was a ps seal? Or are you just going with the first thing that's suggested??.
  9. May 30, 2016 at 10:56 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    If u had read previous post I clearly stated oil,fluid.aby kind of lubrication
  10. May 30, 2016 at 10:57 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    Tranny don't have oil they have fluid
  11. May 30, 2016 at 10:58 PM
    anthony250f
    Anthony
    San Diego, CA
    Previous post said GEAR OIL. Now you say oil? But apparently it's POWER STEERING FLUID...even though our trucks don't use that. So which is it then.
    robssol likes this.
  12. May 30, 2016 at 10:58 PM
    anthony250f
    Anthony
    San Diego, CA
    False. Auto has fluid manual has oil
  13. May 30, 2016 at 10:59 PM
    Tailzz
    Tailzz [OP] Member
    jeromey
    Can anyone clarify
  14. May 31, 2016 at 12:20 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    are there signs of leaks on the rack? if you have that much residual oil on the skid, you should be able to spot any wet spots from the source. my steering rack didn't fail until 210,000 miles.
  15. May 31, 2016 at 12:34 AM
    #35
    robssol
    Rob
    S. Wisconsin
    This thread has run its course. :locked:
  16. May 31, 2016 at 6:56 AM
    #36
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    If any amount of fluid was lost from ps system it would show on dipstick or you probably wouldn't have functioning power steering. If your auto there lines running to and from radiator with atf in them.
    You should be able to tell the difference if its atf, engine oil, or gear oil by color, viscosity, and smell.
