Oil Filter 2016 tacoma v6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texas_bjj, Oct 17, 2015.
  1. Feb 20, 2016 at 12:54 PM
    #201
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    Does the 2016 have a gasket on the drain plug? I didn't see one when I took it off, didn't see it in the oil, but I have them. To use or not to use?
  2. Feb 20, 2016 at 1:01 PM
    #202
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    My drain plug has a flat aluminum gasket.
  3. Feb 20, 2016 at 2:08 PM
    #203
    border411
    border411 Well-Known Member
    I would think that it is encapsulated by some other surface, or else what is there to force the oil through the filter? You need to have a sealed system (for the filtration to work) for the oil to pass through the media vs around it, which is what would happen. I mean, what would force the oil through the filter if there is a gap at the end (hence around it)?
  4. Feb 20, 2016 at 2:38 PM
    #204
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Toyota going old school. Mercedes-Benz and most other makes had the canister oil filter from the 1930's up to the 1970's. IIRC from having a '61, '65, and '68 Mercedes it didn't have all the O-rings. They had the one rubber O-ring at the top mating surface to the block, the canister was centered into the molded aluminum filter housing.
  5. Feb 20, 2016 at 2:52 PM
    #205
    renau001
    renau001 Well-Known Member
    There should be one, make sure it's not stuck to the pan before you put a new one on.
  6. Feb 20, 2016 at 3:44 PM
    #206
    plode682
    Southern NJ
    I found it. Had to get out a flash light. It was on the bottom of the pan, it was so stuck to the pan that I thought it was part of it. Oil change, complete. Did it (unnecessarily) at 1000 miles. I've seen some crap in filters/oil during break in on other vehicles previously, so I wanted to be on the safe side.
    I can also say I hate 0W-20. Comes out of the pan so easily it splashes everywhere. Including into my face/eye. Fun times...
  7. Feb 20, 2016 at 3:57 PM
    #207
    mlm682577
    mlm682577 Well-Known Member
    Mark
    DFW, TX
    2016 Blazing Blue Tacoma TRD OR DCSB
    60+ mods and counting (mod-aholic)
    Did you see much metal in the drain pan? I changed mine at about 2500 and saw a few pieces. I did not see any metal flakes in the filter though. Others are posting pictures with, what I would consider, a significant amount. I know it is normal for a new engine....just curious.
  8. Feb 20, 2016 at 4:02 PM
    #208
    renau001
    Excellent. Won't help on the oil pan. But try a 5/8" ID hose or tubing on the oil filter drain pipe and run it to your drain pan before you insert. Should help with the splash.
  9. Feb 21, 2016 at 7:16 PM
    #209
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    samsung[QUOTED] likes this.
  10. Mar 2, 2016 at 1:19 PM
    #210
    retired mech
    retired mech Well-Known Member
    Tom
    St louis,Mo.
    2016 sr5 double cab v6 4wd
    Get used to thin oil. Mazda is coming out with 0W16 and Shell is coming out with 0W8. I guess we will soon see a 0W0 if I had to guess
  11. Mar 3, 2016 at 8:44 PM
    #211
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    Torque them the first time to get a "feel" for how tight, then just guess after that.
  12. Mar 10, 2016 at 2:33 AM
    #212
    Heepspo
    Washington State
    Trying to understand this...
    You must remove the plug and insert the drain pipe which depresses the spring and allows the oil to flow?
    So no oil comes out when simply removing the plug, correct?
    Where to buy this plug? Does it come with each new filter?
  13. Mar 10, 2016 at 3:14 AM
    #213
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4Ă—4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Ps save your o rings.You never know...
  14. Mar 10, 2016 at 6:25 AM
    #214
    renau001
    Yes, remove the oil drain plug from the oil filter cap and nothing will come out at that time. When you insert the temporary plastic drain pipe into the spot where the oil filter plug was oil will start to flow. Use some 5/8" ID tubing on the plastic drain pipe and route it to your pan to keep it clean. The oil filter cap and oil filter drain plug are permanent. You replace the filter cartridge and 2 o-rings (one for the cap and one for the plug) each time you change the filter and throw away the plastic drain pipe. The filter element kit comes with a cartridge, 2 o-rings, and the plastic drain pipe and instructions are on the box. There's lots of DIYs and videos for this on 4runners, Highlanders and other Toyota's if you look around. Here's an example . Just be aware that there are some slight part # differences between some vehicles.
    Here's another link for your reference. https://www.tacomaworld.com/threads/3rd-gen-diy-maintenance-quick-reference.406712/
  15. Mar 10, 2016 at 1:18 PM
    #215
    Heepspo
    Washington State
    Thanks a lot for confirming the details. Never dealt with this setup before and would rather make sure I get it right than have oil everywhere and be missing needed parts.
  16. Mar 10, 2016 at 2:08 PM
    #216
    renau001
    Another thing I forgot to mention. When you move the filter drain plug, make sure the o-ring stays in place on the cap. It will seal around the plastic drain pipe to make it all flow out your tubing. When you take off the drain pipe, then the o-ring should come with it.
    Heepspo[QUOTED] likes this.
  17. Mar 13, 2016 at 7:36 AM
    #217
    smugly
    Doug
    Ditto!
    Kumunoy likes this.
  18. Mar 13, 2016 at 10:40 AM
    #218
    ManyTacomas
    ManyTacomas New Member
    Just completed my first oil change on a '16 Tacoma TRD Sport. What evil genius created this filter system. A couple of notes that others might find helpful. 1) You're probably going to get messy. The filter change isn't exactly clean. Two oil catch pans helps. 2) The OEM O-rings are black, and it takes a bit to actually locate them (esp on first time). Big one on the outside of the canister, the smaller one on the canister drain on the bottom. 3) Get the canister wrench. It's worth it. 4) The canister drain plug may be tight. When you try to loosen it, you may find the whole canister turning (the canister wasn't that tight, but the plug was tighter). 5) From experience after owning a good number of Tacomas, take the bolts that hold the protection pan out and replace them with stainless steel bolts. Do it sooner rather than later. I've broken a few off in years past, and struggled with rusted in bolts too. The bolts are metric threads 8x1.25. Carefully run a tap through the hole to make sure the new bolts fit. The ones I got from BoltDepot have 13 mm heads on them, but you can probably find them elsewhere. Use anti-seize. Use a 6-point socket on them - less chance of it slipping. I've made this change from my 98 Tacoma on forward.
    Blazingbluesport likes this.
  19. Mar 13, 2016 at 10:57 AM
    #219
    VinTaco
    VinTaco Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    If the center drain plug was used first, would it still be as messy..??
    Heepspo likes this.
  20. Mar 13, 2016 at 11:12 AM
    #220
    ManyTacomas
    It might be less messy once one gets used to doing this oil change, but I don't think it will get as clean as oil changes on earlier models ('05 - '11) were. I barely had to use a rag when doing oil changes for various model years in that range. I don't mean to drive people away from the newest model, just letting them know what to expect.
    VinTaco likes this.
