Oil Filter 2016 tacoma v6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texas_bjj, Oct 17, 2015.
  1. Mar 14, 2017 at 11:31 AM
    #401
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Speaking for myself, the nice thing with a truck is there's no need for a ramp. Plenty roomy under my 2017 OR when I did my initial/early oil change. I suppose if you use a creeper you might need to raise it further, but I've never owned one and just slide underneath.
    If you're asking who uses a torque wrench on the drain plug, I'd ask in return why you wouldn't do so (assuming you own one)? Sure it's easy to get it "close enough" by feel if you're experienced, but even after decades of doing this I prefer to take an extra two minutes and be sure.
    Schiel1 likes this.
  2. Mar 14, 2017 at 11:49 AM
    #402
    Swagnutz
    Swagnutz Well-Known Member
    Was curious would the crush washer give the torque wrench a false reading?
  3. Mar 14, 2017 at 11:58 AM
    #403
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Never torqued a drain bolt in my life.... and never will. Waste of time.. Just tighten it to "feel"...LOL
    rontom and 9TRDTCO like this.
  4. Mar 14, 2017 at 12:00 PM
    #404
    duckytw
    duckytw Well-Known Member
    It shouldnt, and since everything will probably have a little bit of oil, torque wrench should work better. That said, Ive found in the past the torque settings (on other toyota vehicles) felt much higher than what Im comfortable with using a steel bolt on a tapped aluminum part. I even choke up on the ratchet handle a bit to avoid stripping the pan. I understand the need for a spec, but havent felt the need to use it on oil changes.
  5. Mar 14, 2017 at 5:07 PM
    #405
    Swagnutz
    Anyone know what that vertical metal tab thingy that hangs a little over the oil filter canister is for?
  6. Mar 14, 2017 at 7:29 PM
    #406
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If it is what I think it is, its is a failsafe to put pressure on the canister just to make sure it cannot loosen.
  7. Mar 14, 2017 at 8:52 PM
    #407
    myamada1230
    myamada1230 Well-Known Member
    Greenacres, WA
    2021 TRD Offroad DCLB
    I work with the guy from Baxter performance, they do have one for the 2016-2017 taco as he offered me one for my truck, very good quality stuff.
  8. Mar 15, 2017 at 9:00 AM
    #408
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Is there still room under the skid plate for the adapter and a spin-on?
    G.
  9. Mar 15, 2017 at 11:35 AM
    #409
    myamada1230
    Greenacres, WA
    I spoke with him today, and he said that if you use a lower profile spin on filter, it would fit, but they reccommend to do the remote mount kit.
  10. Mar 15, 2017 at 12:41 PM
    #410
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Some of this thread cracks me up. It never ceases to amaze me how millions of dollars and engineering time gets thrown out due to forum posts and Google searches. I see no reason to change the filter canister on your new Toyota to Aluminum. It is sealed by the O-Ring and NOT the threads or the pressure against the block. My 2015 Passat TDI is the same way. Never leaked a drop. Secondly, the Bed of your truck is made out of plastic. Arguably takes FAR more abuse than that canister. Are folks going to get a metal bed to replace the plastic one? Put the tin foil hats away fellas. I'll bet whoever on eBay that had these old Aluminum filter housing s was licking his chops to start selling them again and clear out his shop! :) Just enjoy your trucks. I am pretty sure there was no master plan to build a filter housing that is known to fail or leak.
  11. Mar 15, 2017 at 12:51 PM
    #411
    gpb
    Atlanta
    It's a current part used on other Toyotas not something sitting in someone's garage. See https://parts.conicellitoyotaofconshohocken.com/oem-parts/toyota-filter-cover-1562031060
    I've not seen a need to buy one so I don't care one way or the other, just wouldn't want someone else reading your post to end up with wrong information.
  12. Mar 21, 2017 at 7:53 PM
    #412
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    I like the way he thinks
  13. Apr 12, 2017 at 8:49 PM
    #413
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    Gingerbeard Man and shakerhood like this.
  14. Apr 12, 2017 at 9:07 PM
    #414
    shakerhood
    Southern Ohio
    Mobil1 has a $12 Rebate on a 5Q Jug, well worth snagging a couple at Wally World.
  15. Apr 12, 2017 at 9:39 PM
    #415
    Metonymy
    None (yet)
    Wow, that's nice! Here's the link to the rebate form:
    https://apfco.com/secure/R8235W/
    shakerhood[QUOTED] likes this.
  16. Apr 12, 2017 at 9:58 PM
    #416
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    amazes me how lazy people can be. Why would you NOT torque it for peace of mind? Takes barely any extra time and you know for sure you're not over torquing or under torquing. also, yes different crush washers have different crush rates, but if you get a Toyota filter, ask for one of their crush washers at the same time....Toyota's torque spec accounts for their washer's crush rate...
    Sharky50 and gpb like this.
  17. May 30, 2017 at 9:24 AM
    #417
    Willbird
    Willbird Well-Known Member
    Bill
    Magnetic Gray Metallic 2017 SR5 Double Cab
    Lots of other brands that use/used spin on filters they shoved it so far up in there around a corner that oil rains on you with a spin on/off filter. Takes just as long to clean splattered oil off everything as it does to change filter and change oil :). I like to wipe everything up so that any drips indicate a leak not oil that got sprayed all over everything because of where the filter is buried ;-).
    Bill
    GreengoTaco likes this.
  18. May 30, 2017 at 9:31 AM
    #418
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    its a canister filter, I know dodge uses them on their sixxers pretty common filter but silly design imo
  19. May 31, 2017 at 6:03 PM
    #419
    GreengoTaco
    GreengoTaco New Member
    Jim
    Illinois
    2016 Red TRD Sport
    none yet
    Thanks for the Pics and the great info on location. I am out of free oil changes so time to get down to it. I had a Sunfire that the oil filter was on next to the fire wall and the oil would run down the block and onto the exhaust. talk about messy!
  20. Jun 1, 2017 at 9:12 AM
    #420
    Willbird
    Bill
    Some CNC milling machines I have worked with used "Velocite 2" oil in the spindles, when we get to that in automobiles it looks, feels, and smells a lot like Kerosene...
    Bill
