Oil Filter 2016 tacoma v6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texas_bjj, Oct 17, 2015.
  1. Aug 6, 2019 at 8:21 AM
    #481
    madcity27
    madcity27 Well-Known Member
    2016 Tacoma TRD OR DCLB
  2. Aug 6, 2019 at 9:25 AM
    #482
    staplegun
    staplegun Well-Known Member
    I forget what the thread pitch is, it'll accommodate others(filters) - all you have to ensure is that the mating surface is within the outer circumference of the filter's housing. Per cross reference, the Mobil One filter
    M1102A is a direct replacement of my former Taco PH3614 FRAM.
  3. Aug 20, 2019 at 6:54 AM
    #483
    W1JCW
    W1JCW 2016 TRD Sport 4x4
    Bryan, Texas
    Tacoma TRD Sport 4x4
    Added the Baxter adaptor, very nice. Sure makes oil changes easier than dealing with that housing. I was able to get the housing off with a small oil filter wrench. I was going to use a slightly larger filter but the clearance seems better with the 102A. I may try a larger filter as I like to run a 1qt size.
    The mobile 1 filters do seem high quality due to weight and the construction but for $11 at walmart kind of pricey. Walmart use to carry Purolator which seemed of the same construction for $3 and I stocked up on them. Now WM doesnt carry those as they want to sell their brand super tech.
    Great investment the Baxter adaptor, not sure why Toyota goes with the cartridge.
  4. Aug 20, 2019 at 7:11 AM
    #484
    staplegun
    The same 5VZFE filter (for my 1997 Taco) works with the Baxter adapter, totally happy about that...
  5. Aug 20, 2019 at 9:16 AM
    #485
    staplegun
  6. Oct 26, 2019 at 11:26 PM
    #486
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The interesting thing is that around 2015 Toyota started switching back to the older style filters again.
    I don’t personally care one way or another, though it does seem wasteful to be tossing metal in the bin all the time.
    Jeff
  7. Oct 27, 2019 at 5:07 AM
    #487
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It's kind of a mix now on some engines. My wife's '14 Prius had the 2ZR 1.8 with a cartridge. But her '19 Corolla, with the same engine, has a spin-on.
  8. Oct 27, 2019 at 1:37 PM
    #488
    Jeff Lange
    Calgary, Canada
    Yeah Toyota switched the ZR back to the spin-on in 2015’ish, and most new engine designs released after that point have used spin-on as well (A25A, M20A, V35A, etc.).
    There are still a lot of engines that use the canister style, but they're mostly older designs (mid-2000's to mid-2010's release).
    Also interesting is that occasionally they will use the same engine with differing oil filter types. For instance the ZR used spin-on filters from day one in some countries and while the V35A uses a spin-on filter in North America, Japan and some other countries, in Europe it uses a canister style filter.
    Jeff
    shakerhood likes this.
  9. Nov 1, 2019 at 6:18 AM
    #489
    thumper500
    thumper500 Member
    2013 Tacoma 4WD TRD Sport
  10. Nov 2, 2019 at 3:15 AM
    #490
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    Jeff Lange and GreyBaldTaco like this.
  11. Nov 8, 2019 at 6:34 PM
    #491
    Tmaloy
    Troy
    2019 SR DC LB
    I ordered this kit off eBay, came in the Toyota branded OEM box. Packed inside were the aluminum housing, element, O-rings, and drain plug adapter, just need to pull the drain plug from the plastic one when the time comes. I think it's a good deal for the price of the components.
  12. Nov 10, 2019 at 5:20 AM
    #492
    HMM
    HMM Well-Known Member
    2020 TRD Pro
    I don't mind the cartridge filter, I just wish they'd put it in a better location. My F250 cartridge filter was was on top of the engine and made the changes super easy.
  13. Jan 2, 2020 at 5:52 PM
    #493
    D21403
    D21403 Member
    Md.
    Tacoma TRD 05 4.0 Engine. 4x4
    Wow what a pain in the ass I think I will stick to my 4.0 engine with the top load filter, just remove filter on top of engine and wipe a few drops of oil the guard didn't catch and replace and your done. plus the 4.0 has more horsepower. Why can't Toyota make things easier to work on ?
    jetfishn likes this.
  14. Jan 2, 2020 at 5:54 PM
    #494
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 4.0 has Less Horsepower than the 3.5 and it's not hard to change the filter.
  15. Jan 2, 2020 at 8:14 PM
    #495
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    No oil to wipe up either.
  16. Jan 4, 2020 at 9:12 PM
    #496
    Connor.K
    Connor.K Well-Known Member
    2016 Tacoma TRD OR
    I just recently replaced my plastic housing with an aluminum one (OEM part #15620-31060) and I noticed some a very small amount of oil weeping out once the new housing was installed. I replaced the filter and all of the seals and coated the seals with oil prior to installing it. Has anyone else run into this issue or have any ideas on the how to fix it? Im thinking that worst case I'll just purchase and install another plastic housing.
    Junkhead likes this.
  17. May 21, 2020 at 3:22 AM
    #497
    speedgeezer
    speedgeezer Well-Known Member
    Rydal, GA
    2022 Red DCSB Sport 4x2
    I had this part installed on my 2017 Taco, no problems. Plan on buying another for my 2020 but both Amazon and ebay parts checker says no. Will continue to search for a replacement.
  18. May 21, 2020 at 3:47 AM
    #498
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Their parts checkers are about as trustable as gas station sushi and so on. Often wrong. 2020 is the same.
  19. May 21, 2020 at 3:50 AM
    #499
    speedgeezer
    Rydal, GA
    Thanks Pablo8. I didn't think a change had happened.
  20. May 21, 2020 at 4:32 AM
    #500
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    When I bought the same kit for my 2016 the Tacoma was not listed. I believe I bought one that listed Camry and it fit. Same one fit multiple vehicles. I just looked up the oem part number on a dealer site and it lists for 2016-2020. It is the same housing. Go to the following page and then click vehicle fitment. Shows Scion. Then click more vehicles. It shows 2016-2020 Tacoma V6.
    https://trdshop.carlocktoyotaoftupe...MIkMbEn-3E6QIVg4nICh1Wzg7kEAQYBiABEgKQNfD_BwE
