Oil filter ? Bigger is better ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Armed in Utah, May 23, 2019.
  1. May 26, 2019 at 3:49 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I run extended oil change intervals with long life filters. My analyses all come back great. No need to do this for my vehicle
  2. May 26, 2019 at 3:52 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    In the most literal sense sure. In terms of throwing extra oil into your engine expecting noticeable benefit, not so much. Simply put, Toyota engineers have it right on this one. I’ve driven 1GRFE prados in the sandbox with 700k Kilometers on them. They didn’t even have oem Denso filters and they ran on whatever bulk 5w30 that the motor pool could get in. They’d be driven or idle about 16 hours a day in upwards of 120 degree heat and dust. They still ran perfectly fine. My 05 still ran like a top with 295k miles on it with no oil related issues, and multiple confirmations from Blackstone saying I could surpass my 7500 mile intervals. That was with wallyworld 5w30 synthetic and a Denso oem filter. real world testaments and oil analysis tests will tell you a lot more than trying to out-engineer one of Toyota’s best engines. We aren’t talking about a big block dragster or an EJ257.
  3. May 26, 2019 at 3:56 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I really think you guys are buying OEM oil filters because they are so affordable. :crapstorm: If they were $15 each, we wouldn't be having these conversations. How many of you buying OEM oil filters also buy OEM air filters? OEM motor oil? I know a few of you do, but not the majority.
  4. May 26, 2019 at 4:05 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    Has nothing to do with an OEM product or not. Rather increased size in a filter. I personally chose OEM filters because I lived maybe a 1/2 mile from a dealership. The point I was making in my last post is that I drove trucks with questionable filters and oil on a regular basis with no issue, and in harsh conditions. Go ask all the high mileage 1GRFE owners how many of them used oversize filters. Ask them if they knew something Toyota’s engineers didn’t. Be surprised when they simply used compatible filters made for the engine, and motor oil that met Toyota’s specs. It’s really not that difficult, but different strokes for different folks.
  5. May 26, 2019 at 4:13 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I’m a broken record - the Toyota yzzd3 filter that everyone uses IS the oversized filter! It just happens that it’s what most Toyota places will give you when you ask for a 1gr-fe filter.
    Look at recommenced Fram 3614 or Mobil1 201 filter sizes - tiny right? Now look at the “oversized” 3600 or 209 - same size as the yzzd3.
  6. May 26, 2019 at 8:37 PM
    Montanahunter
    Montanahunter Well-Known Member
    Zhaun
    Helena Montana
    2009 DC TRD off-road
    OME lift Stealth custom wheels ARB bullbar Allpro Apex sliders Prismo design roof rack.
    A friend of mine used to run a 2 gt wix this blown big block. With a high volume high pressure oil pump and deep sump oil pan. A car like that can pump oil out of the pan faster than it drains back. But it ran 6 second 1/8 mile times at over 100mph. That oversized filter won't hurt but isn't necessary on a Tacoma.
    TacomaSport86 likes this.
  7. May 27, 2019 at 6:47 AM
    TacomaEd15
    TacomaEd15 Well-Known Member
    Ed
    communist state of NJ
    First Tacoma CPO 2015
    I bought an OEM toyota oil filter at the dealer for less than $6.00. I think it was $6.35 with the crush washer. Since its recommended by engineers smarter than me I'm sticking with it.
    StillNoPickles and TacomaSport86 like this.
  8. May 27, 2019 at 9:34 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    No point ,or gain by using anything larger than a factory filter.
  9. May 27, 2019 at 9:55 AM
    Armed in Utah
    Armed in Utah [OP] Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    this is a test.........
    repeat.......
    this is a test...........
    again....this Wix XP51515 was less than $7 shipped
  10. May 27, 2019 at 10:17 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    But you gain .5qts of oil..... so it's a gain of sorts
  11. May 27, 2019 at 10:28 AM
    JRVfromDVT
    JRVfromDVT Well-Known Member
    Southern Vermont
    2006 Tacoma Access Cab
    The YZZD3 is what was on it when I did the first oil change after buying the truck and its what is on it now. My local Walmart has most of the Toyota OEM filters. Only lost ~.5 quarts of oil in a 5500 mile interval so I don't see a reason to change.
    Back when I had my VW Passat, the OEM filter was not adequate due to the oil pan size decrease when they made the 1.8t longitudinal. In that case I would use a Mann filter that could hold over a quart on its own. You could stuff a small child in that thing.
  12. May 27, 2019 at 10:33 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I use these bad boys, why? because bigger is better.
  13. May 27, 2019 at 10:34 AM
    TacomaSport86
    Too small, i use filters at least 48 inches long
    TacomaEd15 likes this.
  14. May 27, 2019 at 10:35 AM
    coopcooper
    alberta canada
    is there a hood mod for that, I assume it would be the same as having a stack coming through, pretty badass imo
    TacomaSport86[QUOTED] likes this.
  15. May 27, 2019 at 10:37 AM
    #35
    TacomaSport86
    Oil snorkel
    coopcooper[QUOTED] likes this.
  16. May 27, 2019 at 10:39 AM
    #36
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Norton likes this.
