Oil Filter Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfw4x4, Jun 27, 2017.
  1. Jun 27, 2017 at 8:08 AM
    cfw4x4
    cfw4x4 [OP] Member
    Alex
    2010 Tacoma, TRD Off-road, 4.0 V6
    Nothing yet :(
    Hello, I am new to the group and haven't been able to find this question being asked, so forgive me if I missed this discussion.
    I am looking to see if anyone has changed out the Stock Oil filter to something a little bigger. Stock Oil Filter is a FRAM PH3614 or WIX 51348. Both of which I feel is too small. What I would like to do is switch over to a FRAM PH8A or WIX 51515.
    What I am wondering is (sense they are both the same thread and inlet size), has anyone tried just screwing the bigger filter onto the filter mount. I don't know about o-ring size difference, but was wondering if anybody has tried this before?
    My backup plan is to use a remote Oil filter mount. I was just wondering if I could do a direct switch or if anyone has tried this before.
    I have the 4.0L V6 engine. Any thoughts
  2. Jun 27, 2017 at 8:09 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  3. Jun 27, 2017 at 8:24 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    If you get an OEM Toyota filter it will be taller than the aftermarket size. Get a pack of 6 and you'll save some money per filter
    Blockhead and Kyitty like this.
  4. Jun 27, 2017 at 8:25 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Why would size of the filter matter?
    Lester Lugnut and scottalot like this.
  5. Jun 27, 2017 at 8:26 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    It doesn't really but that's what the op asked
    PackCon likes this.
  6. Jun 27, 2017 at 8:36 AM
    cfw4x4
    cfw4x4 [OP] Member
    Alex
    Nothing yet :(
    More filter element to collect particulate, as my Dad and Grandpa say.
    My real reason, is am trying to reduce the number of Oil filters I need to keep on hand. I figure going in oil filter size is the best way. Increase oil capacity, more time to cool the oil to cool and in theory Longer life in an engine. Maybe increase the interval that I have to change the oil if the Oil and filter are still good.
    I currently change my oil about every 5 to 6 weeks, that is about when my filter bypass opens by my best estimates and numbers.
  7. Jun 27, 2017 at 8:38 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    An oil change every six weeks seems excessive. You know the interval is longer than that right?
    Norton and Krazie Sj like this.
  8. Jun 27, 2017 at 8:42 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Quality of the filter matters more than the size in my opinion.
  9. Jun 27, 2017 at 8:46 AM
    cfw4x4
    cfw4x4 [OP] Member
    Alex
    Nothing yet :(
    I think Quality and size if I can have both, but I usually go for Quality if I have to chose between the two :p
    scottalot and NAAC3TACO like this.
  10. Jun 27, 2017 at 8:46 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
  11. Jun 27, 2017 at 8:49 AM
    PackCon
    Connor
    You figure wrong. More filter doesn't necessarily mean better quality filter overall. Size really has nothing to do with that.
    If you want to extend your OCI first step is to run a high quality synthetic oil. Conventional won't get you past 5k miles magical filter or not. Then run the oil filter paired with the oil you pick and replace per the manufacturers instructions.
    Amesoil can get you to 25k miles with two filters. Mobil 1 just released an annual protection that is rated for 20k miles with 1 filter. I am currently testing the Mobil 1 Annual Protection. Will have the oil tested by Blackstone labs at 15k to determine if its got life for more miles.
    The science has been done on this so no need to make assumptions or guesses. I recommend bobistheoilguy.com for a reference.
  12. Jun 27, 2017 at 8:50 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    I run the over sized WIX filter
    scottalot likes this.
  13. Jun 27, 2017 at 8:54 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Another option is Wix 51516 - longer than the 51348, a little shorter than the 51515. Same specs on all 3 for Bypass valve, all have anti-drainback valve.
  14. Jun 27, 2017 at 9:01 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    your filter bypass is not opening, ever, unless the filter is defective
    if you had that much crap in your motor, to clog the filter and
    force the bypass to open...you'd have major symptoms of engine damage
    by now....
    OEM filter is more than enough to filter that engine if you change oil and filter every 5 thousand miles,
    or every 10,000 if using 100% synthetic
    scottalot and cliffyk like this.
  15. Jun 27, 2017 at 9:07 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    OP - how many miles between oil changes in 5-6 weeks?
  16. Jun 27, 2017 at 9:16 AM
    cfw4x4
    cfw4x4 [OP] Member
    Alex
    Nothing yet :(
    Usually 3700 to 4500.
    Torspd and scottalot like this.
  17. Jun 27, 2017 at 9:21 AM
    PackCon
    Connor
    Switch to synthetic and run to 10k. A higher quality oil and filter and you might be able to go longer. The quicker you put on miles (and the more highway miles) the more likely you can extend that OCI.
  18. Jun 27, 2017 at 10:21 AM
    cfw4x4
    cfw4x4 [OP] Member
    Alex
    Nothing yet :(
    @ PackCon
    Thanks for the Info, that is something I didn't know. I have been running Sync, wasn't aware that some of them would last over 10K miles. I will have to check in and do a little research on that.
    @ 127.0.0.1 I change the oil when I get aproch the 1 MPG lose. I usually make about 19.5ish MPG when I usually stay their for 4 - 5 weeks, then a loose about 0.75 to 1 MPG over one filling. I have checked and held out for several tanks to verify that it isn't just the driving I am doing/load I am moving. When I change the oil, I go back up to the 19.5ish That is the only thing I have figured. Testing the idea that changing the Oil filter is the key thing currently. That has made the difference in the past. I am creeping up on the 5th week. Thinking of checking to see if a bigger filter makes a difference or not is my next step, which brings me to my question that was asked at the begining.
    @ edm3rd and Kerrigan 911 Thanks for the suggestions, that is something I can try and see what happens. Thanks for the parts :D
  19. Jun 27, 2017 at 10:32 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Wonder if the slightly used (dirty) oil affects the VVT-i, and gas MPG suffers?
  20. Jun 27, 2017 at 10:45 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wow, changing oil every few weeks is insane..... you must have a lot of time on your hands
