oil filter cross reference?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 04asphalt, Feb 16, 2008.
  1. Feb 16, 2008 at 10:42 PM
    04asphalt
    04asphalt [OP] Well-Known Member
    PreRunner
    looking for part number of the wallymart brand "supertech" oil filter that fits my 06 with the V6.
    what about mobil1 or bosch?
  2. Feb 16, 2008 at 10:49 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Go to Advance Auto Parts and get a Purolator PureOne instead.
  3. Feb 17, 2008 at 1:37 AM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
  4. Feb 17, 2008 at 8:35 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^I would. Purolator PureOne is one of the best performing out there. Check the filter studies. Or maybe someday I'll have access to a scanner and I can post the years of oil study reports that I have.
  5. Feb 17, 2008 at 11:22 AM
    04asphalt
    PreRunner
  6. Feb 17, 2008 at 4:36 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
  7. Feb 19, 2008 at 4:07 AM
    04asphalt
    PreRunner
    :thumbsup:
  8. Feb 19, 2008 at 7:18 AM
    Jake
    Jake Member
    2007 Access Cab - Silver
    Bed D-Rings, Speaker Upgrade using TacoTunes Kit, Hitch w/ wire kit, Suspension TRB, More mods in process...
    The parts guy at the local Toyota Dealership commented the Toyota filter has an oil retention component built into the Toyota filter that other non-OEM filters may not. I am not a filter expert so take this for what it's worth... If you stick with Toyota filters and ever have an oil related failure, your warrany will never be questioned. The cost is under $5 / filter. Any filter experts out there have any comments?
  9. Feb 19, 2008 at 7:41 AM
    Jake
    Jake Member
    Here is what Toyota says:
    Genuine Toyota Oil Filters are designed specifically for your Toyota engine. Features of the Genuine Toyota Oil Filters include:
    • A bypass valve, which alleviates restricted oil flow in the event of a clogged filter.
    • An anti-drainback valve, which prevents oil from draining out of the engine and into the oil pan, helping to protect your engine from increased wear during cold starts.
    • A filter element which effectively filters contaminants and maintains the engine's lubrication capability during the maintenance interval. By comparison, a lesser quality filter element might clog during Toyota's recommended maintenance interval leading to engine wear, seizure or other problems. Some non-genuine oil filters do not meet all of Toyota's stringent specifications.
    Toyota recommends changing your oil filter and motor oil every 5,000 miles or 6 months.
    Additional Filter Information:
    http://www.toyotaownersonline.com/parts-service/toyota_parts/oil_filters.html
  10. Feb 19, 2008 at 8:23 AM
    04asphalt
    PreRunner
    seems like nothing special :confused:
    waiting for a Pro to post up....
  11. Feb 19, 2008 at 8:32 AM
    Jake
    Jake Member
    I use a FilterMag on my 7.3 PowerStroke. Have a look at the link, I think you'll find it intertesting!
    http://www.filtermag.com/
  12. Feb 23, 2008 at 8:41 PM
    04asphalt
    PreRunner
    :cool:
  13. Feb 23, 2008 at 9:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its not the m1-109 that fits, its the m1-102 and for more oil capacity its the m1-209.......a bit of a bigger filter that will flow more oil than oem.
  14. Feb 28, 2008 at 11:47 AM
    danusa
    danusa Well-Known Member
  15. Feb 28, 2008 at 5:34 PM
    04asphalt
    PreRunner
    don't most filters have an anti-drain valve?:confused:
  16. Feb 28, 2008 at 5:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yes,definitely, these days most all oil filters have an anti-drain valve.
  17. Jul 24, 2020 at 11:22 AM
    ericp95
    ericp95 Mean Jeanine
    Eric
    04 Tacoma V6 4x4 Manual
    For what it’s worth, the Mobil 1 definitely feels heavier in weight.. so they must be using heavier/sturdier? materials. Not sure how much that matters in oil filtering though
  18. Jul 24, 2020 at 11:24 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Most Walmart’s also stock o.e. Toyota filters now.
  19. Jul 24, 2020 at 11:27 AM
    ericp95
    Eric
    Good point. Just noticed. You think the oe or the Mobil one? I’mgetting Mobil 1 full synthetic for the oil so thought I’d match the filter
  20. Jul 24, 2020 at 11:29 AM
    Greenedmc
    Daniel
    Elizabethton TN
    Personally I always use oe filters on my tacoma. Occasionally I’ll use wix on some of my other vehicles.
