Oil Filter End Cap Wrench - 2nd Gen Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sherlock, Mar 11, 2012.
  1. Mar 11, 2012 at 1:38 PM
    sherlock
    sherlock [OP] Well-Known Member
  2. Apr 30, 2012 at 7:33 PM
    tony456
    tony456 Member
    Tony
    Wichita Falls
    2007 black Tacoma Regular Cab
    What oil filter end cap wrench would I have to buy for a 2nd Gen Tacoma 2.7 engine?
  3. Apr 30, 2012 at 7:39 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  4. Apr 30, 2012 at 7:41 PM
    tony456
    tony456 Member
    Tony
    Wichita Falls
    Thank you.
    Any particular brand I should get? The OEM one seems to have a bunch of bad reviews.
  5. Apr 30, 2012 at 7:42 PM
    NelsonTacoma
    Tucson, AZ
    They sell them at Sears. I got mine from Snap on, but it's their off brand Blue Point, had it for 7 years zero issues.
  6. Apr 30, 2012 at 7:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's an oddball wrench that's listed for the Dodge Sprinter.
  7. Apr 30, 2012 at 7:45 PM
    tony456
    tony456 Member
    Tony
    Wichita Falls
    Oh! I saw that at Pep Boys today. Had I known I would've gotten it. Thanks for the info.
  8. May 5, 2012 at 7:32 PM
    tony456
    tony456 Member
    Tony
    Wichita Falls
    Well, I ended up going over to Sears and buying this Craftsman adjustable oil filter wrench for seven bucks which you use with a 3/8 inch socket wrench. It worked nicely. Came right off. :)
  9. May 5, 2012 at 8:37 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    if you need a wrench to get your filter off it was installed to tightly.
  10. May 6, 2012 at 5:21 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Or if you have a 2.7L, there's only about two inches of filter housing that's exposed enough to grab with your thumb and index finger :(
  11. May 6, 2012 at 6:47 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I hand tighten the OEM filter every time. Damn thing is still too tight when I change the oil. I use a crescent wrench to get it off though, it crushes it a little but that doesn't matter cause it's old anyways.
  12. May 6, 2012 at 6:49 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    x2, when the prseeus and heat build up over 5000 miles, you shouldn't be able to remove it with your hand when changing. You sir must have Incredible Hulk like strength.
  13. May 6, 2012 at 7:00 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    buy the k&n filters with the bolt on top, makes life easy
  14. May 6, 2012 at 7:07 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  15. May 6, 2012 at 7:12 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Same thing I have had for years. It doesn't grab enough surface area of the filter (like the one another member posted before this) so on some cars filters I have had to use the old messy screw driver trick.
    lol... I lube my gasket and hand tighten them on my truck.
    Never once in 80k have I been able to turn it off by hand.
    Yes it does. I miss them :( I always ran them on my 5.0.
    Bought a 10pk of OE filters for the Taco years ago and still running through them.
  16. May 6, 2012 at 7:28 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  17. May 6, 2012 at 7:41 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    ^ or you can get a cheaper set at any auto parts store with multiple sizes for cheaper, then you have different sizes if you get something else.
  18. May 6, 2012 at 7:53 AM
    anthony250f
    Anthony
    San Diego, CA
    i use them evertime now, just put a new one in last week
  19. May 6, 2012 at 8:08 AM
    1980
    1980 Well-Known Member
    The Dust Bowl
    I have a little tub of silicone grease that I used to lube O-rings when I scuba dived. Put a bit of silicone grease on an oil filter's gasket instead of motor oil and it never seizes up so you can easily remove it by hand.
    I've also got a pair of those filter pliers that are build like a pair of channel locks. Here's what they look like:
  20. May 6, 2012 at 8:43 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No thanks.
    That nut isn't worth the extra $10 per oil change.
    The K&N filter is identical to the Mobil-1 filter, which is very good (and $3 less)... but the Pure-One is half that price, and the OEM Toyota filter which is arguably just as good is about 2/3rd the cost of the Pure-One.
