Oil filter help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spinney, Aug 19, 2017.
  1. Aug 19, 2017 at 6:48 PM
    Spinney
    Spinney [OP] Member
    Stock 2009 Toyota Tacoma Sport
    I need to change my oil! What type of oil filter do I need to buy? I have a 2009 Tacoma TRD Sport
  2. Aug 19, 2017 at 8:30 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
  3. Aug 19, 2017 at 8:36 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Check out the Mods and Tutorial section
  4. Aug 20, 2017 at 2:30 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    There were two filter threads just last week ... Many of us use extra capacity filters. I had been using Wix 51516, but will next be using the slightly larger 51515, plus an extra half quart of oil. When it comes to oil filters, larger is better, but there are practical limits. Car manufacturers will use the smallest size they can get away with to save a dollar, which can translate into millions over the millions of cars they sell.
    Norton likes this.
  5. Aug 20, 2017 at 4:10 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Use OEM...when in doubt check your owner's manual.
  6. Aug 20, 2017 at 4:13 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    This thread title would suggest it's stuck and you've tried everything short of an air chisel.
  7. Oct 29, 2017 at 4:17 PM
    JSU
    JSU Member
    HouTex
    '07 PreRunner TRD/Sport AccessCab 4.0V6, auto
    I use Mobil One Synth and the Fram Extra Guard PH8A filter (ford 351 V8). I drain the oil sump and refill every 10,000 miles and change the filter, too. I then change the filter at 3,300 miles and again at 6,700 miles and top off the oil with the filter change, always one quart. This is what I started doing on the day I got my 2007 V6/auto PreRunner Sport which I bought in Feb 2009 with 30,000 miles on the odometer as I drove off the lot. It was totaled on 6/23/17 with 142,639 miles as I signed it over to the insurance company. It always showed full on the dipstick every time I checked between oil and filter changes.
    It took a while to find a replacement, but on 9/11/17, I won an eBay auction for a 2007 V6/auto PreRunner SR5 with 28,012 miles. I'm almost ready to start the same oil routine at 30,000 miles.
    I was committed to taking the first Taco to 250,000 miles and had a minor setback, that is, it was totaled. My goal remains to see the odometer roll at 250,000 miles, I just had to start over at just under 30K miles with this replacement PreRunner.
    This replacement Taco was bought new by the ebay seller. He only drove it to box stores and nurseries on weekends and otherwise kept it in his garage. He replaced the original tires the week before the auction, replaced the battery then too, and did the TSB for the rear leaf springs the day before it was signed-over to me. I've been busy redoing mods I did 8+ years ago. While I miss the steering wheel controls for the radio, otherwise this replacement is like coming home, again.
    My oil regimen worked for 112,000 miles on the first Taco, I'm betting my engine it will work on the second, too.
  8. Oct 29, 2017 at 5:28 PM
    Pigpen
    Dan
    Northwest Montana
    Not sure about your 250k comment. There is at least one member over 400k.
    OP, maximum filter media surface area is what makes for the best filter. There have been a few tests done. I haven't seen any filters that out performed the stock filter.
    jsi likes this.
  9. Oct 29, 2017 at 5:38 PM
    JSU
    JSU Member
    HouTex
    If others have made it to 400K+, all the better for them. My goal is 250K. Of that I'm sure.
    If Toyota can squeeze more filter media in a stock filter than in a Fram PH8A, so what? I know what has worked for me for more than 110K miles. If you're happy with the Toyota recommended filter, use it. I don't care.
    I haven't seen any filter tests, again, I don't care. I have seen my own 2007 Tacoma go 142K+ miles with my own regimen, and use no oil at any and all dip stick checks. My data, not a published filter test. Use what you want, I will too. And I still hope to see the odometer on my replacement Taco turn 250K miles.
    How far has your Taco gone?
  10. Oct 29, 2017 at 7:28 PM
    Pigpen
    Dan
    Northwest Montana
    My 2012 has a bit over 95k miles so far.
    I wasn't bashing you or Fram, or any person or brand. The OP asked for suggestions, so I offered mine.
    tacoman45 likes this.
  11. Oct 29, 2017 at 7:29 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use Carquest or napa filters....always have. If i can get my hands on one ill settle on a purolater.
  12. Oct 29, 2017 at 7:36 PM
    JSU
    JSU Member
    HouTex
    The devil is in the details. The stock Toyota filter for the 4.0 V6 is less than half the size of the Fram PH8A spec'd for a Ford V8. The stock Toyota filter can be removed with the engine cover in place, that won't happen with the bigger Ford V8 filter.
    As mentioned previously, synthetic oil will last a long time, if it's kept clean. That's why I do two filter changes in between oil changes (oil & filter, @ 3300 change filter and top off oil, @ 6700 change filter and top off oil, @ 10K repeat.)
    757yotas[QUOTED] likes this.
  13. Oct 29, 2017 at 7:42 PM
    757yotas
    Virginia
    2007 TRD Sport
    I have always done 5-6k changes. Never trusted fram tho as my friend had his blow the seal out on the interstate. After that fram has been in my shart list (plus they dont even use metal end caps or silicon anti drain backs, or coil springs, and the filter media is always so uneven its crazy). To each there own though. Use what works for you
  14. Oct 31, 2017 at 5:34 AM
    JSU
    JSU Member
    HouTex
    After further research, reading here and watching some vids, I'm amending my position on oil filters.
    I feel, no empirical data, that the success of my original Taco with synth oil (specifically Mobil One), despite going 10K mile change intervals, and using Fram filters, is due in part to changing the filters every 3300 miles. That 2007 4.0 V6/auto PreRunner TRD Sport Access Cab went 142K miles before being totaled in a freeway wreck. At the last oil change, 2K miles previous, the oil level was good, no usage.
    It's replacement, also a 2007 4.0 V6/auto PreRunner Access Cab (SR5 instead of TRD Sport) came to me on 9/11/17 with 28,012 miles and is about due for an oil change. I ordered the 90915-YZZD3 ten pack via eBay. I will stay with Mobil One and 10K intervals but will change the Toyota filter at 5K miles (and top off the oil).
    I'm not sure what filter is currently on the replacement Taco. It is a Toyota filter and installed at a Toyota dealer where the previous owner had all service done. It is tiny, much smaller than the Frams I have previously used. The Frams are smaller than the Toyota filters I ordered and referenced in the linked thread.
    This thread was the most informative for me:
    https://www.tacomaworld.com/threads/toyota-oil-filter-made-in-thailand-vs-the-competition.123608/
    Extra Hard Taco likes this.
  15. Oct 31, 2017 at 8:48 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Mobil 1 M1-209A
  16. Oct 31, 2017 at 8:53 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    At the store by all the filters there is a book that tells you what size filter to get for each manufacturer
    Alexely999 likes this.
  17. Jun 11, 2024 at 12:35 PM
    olebri
    olebri New Member
    No. CA
    07 PreRunner SR5
    I started with OEM M1-102 and switched to M1-209a with Mobil 1 5-30W
    I made the mistake of telling the Autozone clerk that my truck was a 2007 Prerunner
    and he said the 209a would not fit.
    I didn't say I was already using 209a, but just bought it anyway.
    Why would he say it won't fit?
  18. Jun 11, 2024 at 2:01 PM
    Waasheem
    Waasheem
    2007 xrunner
    51516 wix or napa 1516 is what I used several times. Switched to a baldwin b2 but of the 3 I bought, one didn’t fit. Switched to napa 1773 or wix 51773.
    Op, most are happy using the d3.
  19. Jun 11, 2024 at 2:57 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Because his book cross references by the oem part #. Note, the larger oil filters do not fit the non-towing package models. They can only fit longer filters but not the wider OD filters.
    I got tired of bruising my hand on the plastic cover over the filter, and too lazy to remove it. So, I am now using the shorter fat filters - Wix 51068 (or the shorter 51085), Baldwin B233, Denso 150-2065, etc… and still pumping in 6 qts of oil.
  20. Jun 12, 2024 at 1:50 PM
    Pjerdan
    Pjerdan “I do what I want”
    Philip
    Hebron KY
    2012 Tacoma 4x4 double cab (SR5 unfortunately)
    Working on it
    If you change it every time you change your oil it really does not make much of a difference
