oil filter spec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpoint16, Jun 11, 2008.
  1. Jun 11, 2008 at 8:24 AM
    rpoint16
    rpoint16 [OP] Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    Just went to change out the OEM oil filter on my 08 V-6. I always use FRAM as replacements. The FRAM filter is about 5/8" shorter than the OEM. Will this be a problem?
  2. Jun 11, 2008 at 10:10 AM
    missileman125fw
    missileman125fw Well-Known Member
    I use FRAM also. It has worked fine for me.
  3. Jun 20, 2008 at 11:23 PM
    UNHAPPY GREG
    UNHAPPY GREG New Member
    mt. aukum ca
    06 tacoma trd sport
    The O.e.m Filter Has A Check Valve In It And You Should Use It I Keep One In My Taco In Case I Am On The Road And Need Service
  4. Jun 21, 2008 at 12:27 AM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    i just went to the new owners orientation at toyota. they mentioned that you should only use toyota brand oil filter. at first i thought it was just so they could sell their own brand but they said it was because of the gasket. on others (fram, mobile, etc) the gasket over the 5000 mile run before the next oil change, the gasket tends to stick and come off the oil filter. and if you don't notice it and put the new oil filter on while the old gasket is stuck on, you have a double gasket that will eventually pop and all the oil will jet out. with the oem toyota oil filter the gasket is held on the oil filter by brackets or something like that, that won't come off. also they mentioned that the oem filter is designed especially for the vehicle with something inside on how it holds the oil and filters it.
    Well that is what i got out of the orientation. I found it informative. but then again who knows.
  5. Jun 21, 2008 at 5:45 AM
    tjdriscoll
    tjdriscoll Active Member
    07, Tacoma Std Cab, 2WD, 5-M, 2.7 L I4, Indigo
    OEM Foglights, iPod adapter, Bedlights-Underbody lights, more to come soon.
    thats only if you super tighten the filter. before you put it on, you should wet the rubber ring with the new oil. this ensures a tight seal. also, you're only supposed to hand tighten the filter on to the bolt. i've used fram filters all my life and never had a gasket come off. the only time it did was with a honda filter on my old accord.
  6. Jun 21, 2008 at 11:49 AM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    This whole thread is wrong on so many levels.
    FRAM ain't gonna be your best filter. Worst rep out there.
    Anybody who doesn't notice a 1/4 wide rubber ring stuck on the filter flange on this engine (on top, right in front of you), shouldn't be working on a car.
  7. Jun 21, 2008 at 4:36 PM
    RWDUNKY
    RWDUNKY Member
    moline il
    08 TACOMA REG CAB 4x4
    bed extender, cruise control, intermittent wipers, hood protector. 4x4 emblem off of a tundra on tailgate.
    Use The Toyota Filter, Better Seal, Made For Your Engine And
    No Poss Warranty Problems If Engine Takes A Dump. Cost Is About The Same.
  8. Jun 21, 2008 at 5:55 PM
    MikeS.
    MikeS. Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    Call Shannon at Toyota Offroad Parts. A case of 10 OEM filters comes in at 3.29 apiece for the Tacoma.
  9. Jun 21, 2008 at 7:50 PM
    HD Tacoma
    HD Tacoma New Member
    Vicksburg,Mississippi
    2008 Toyota Tacoma SR5 TRD 4x4
    I agree with Taco Trud, Fram is a less than ideal filter. You really do want to stick with Toyota OEM filter,WiX or Mobil1 extended performance. Your engine will thank you.
  10. Jun 21, 2008 at 9:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would go so far as to say use only Toyota and Wix. I have used the Mobil1 filters and found that my oil psi would drop when useing them. Once I discovered that, I stopped useing them. Im sure its because they filter better, but I dont know if the trade off is worth lower oil psi.
  11. Jun 21, 2008 at 9:56 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Most any oil filter in the family of oil filters that have the 3/4"-16 threads, 8-11 lb bypass will have a check valve regardless if it is for an application used threaded side up, inverted like the 4.0 Toyota, or sideways like some old Ford trucks; simply because that filter spec is so common on literally millions of vehicles. My 2.7L Tacoma filter cross ref is a NAPA 1348, but 1st change I used the 1516 which is longer, and this time I used the 1515 which is the old standard Ford filter, and also the old Toyota HiLux, Land Cruiser. No real benefit to the larger size except a little more oil, and a lot more capacity for contaminates should I ever be dumb enough to forget to change my oil for a long period of time. A lot of people use Fram, and never have a problem, but cut open a Fram, and 2 or 3 of the premium competitors and you will be surprised at the quality differences. Toyota over the years has used several vendors from Japan and the US to the current Thailand batch, so a Toyota filter is any decent filter of the month with Toyota painted on it, but next week it may be from another vendor. Toyota is busy tending to there worldwide empire, they don't build filters, but they do have a decent spec for those who do.
  12. Jun 22, 2008 at 9:34 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    do you guys pay attention on the oil filter when u FIRST change it???
    the ones that comes new on the truck is made in japan, and the OEM they sell it to u from the parts from malaysai... I think is more inferior product because why would put a filter from japan on new now selling it parts from malaysia....
    and they are different parts # too....
    please check, I ain't lying!
  13. Jun 22, 2008 at 2:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I make sure to buy the ones from Japan. The parts guy makes sure to get them for me. :D
