Oil filter study
Discussion in '1st Gen. Tacomas (1995-2004)' started by geochurchi, Dec 15, 2014.
  1. Dec 15, 2014 at 3:19 PM
    geochurchi
    geochurchi [OP] Well-Known Member
    NH
    Tacoma
    Hi All, I saw a study that a member did on oil filters back in 2010,unfortunately I was unable to open the link,can anyone advise?
    Thanks geo
  2. Dec 15, 2014 at 3:25 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Fram junk
    Wix good
    Oem good
    K&n good
    Mobile 1 good
    Thats what i found
  3. Dec 15, 2014 at 3:28 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I usually use K&N because it has the 1" socket head on it which makes removing it a breeze.
  4. Dec 15, 2014 at 4:34 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    At the end of the day, the consensus is go with OEM.
  5. Dec 15, 2014 at 5:37 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    The cheapest I can find because in 5k miles, I will be replacing it..
  6. Dec 15, 2014 at 8:09 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    go big or go home, get the oversized filter which is a direct fit. WIX 1516, for a 1995 3.0L Ford Taurus.
    Yota Wix specs:
    Item#: FIL1348
    Price: $5.79
    tax and shipping not included
    Attributes:
    Gasket I.D. (Inches):2.43
    Gasket I.D. (mm):61.72mm
    Gasket O.D. (Inches):2.734
    Gasket O.D. (mm):69.44mm
    Height (Inches):3.404
    Height (mm):86.46mm
    O.D. (Inches):2.921
    O.D. (mm):74.19mm
    Style:Spin-On Lube Filter
    Thread Size (inches):3/4-16
    Ford Wix specs:
    Item#: FIL1516
    Price: $5.99
    Attributes:
    Height (Inches):4.828
    Height (mm):122.63mm
    O.D. (Inches):2.921
    O.D. (mm):74.19mm
    Mobil 1 version of same filters:
    Same inner and outer diameter, same threading, just taller. Taller = more filter material.
  7. Dec 15, 2014 at 8:33 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    I suspect the taller one would be a hell of a lot easier to get at too. So just to be clear, the taller version is a direct fit for the 3.4?
  8. Dec 15, 2014 at 9:17 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  9. Dec 15, 2014 at 9:18 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Purolator pureone is the best on bob is the oil guy.
  10. Dec 15, 2014 at 10:02 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    YZZD3 OEM is what I use
  11. Dec 15, 2014 at 10:34 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yes, a direct fit. I use the taller one (wix 1516) religiously now.
  12. Dec 15, 2014 at 10:39 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
  13. Dec 15, 2014 at 10:55 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  14. Dec 16, 2014 at 7:38 AM
    MatthewMay1
    Matthew
    Lone Star Republic
  15. Dec 16, 2014 at 7:46 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Oil filters all overkill. I do understand OEM filters filter much, much better than aftermarket, but they all perform way more filtering than regular engine oil needs day to day. I used this in another thread on here.
    Its like a comparing a #1 pro football player and a #1 college level player. Either one is going to be able to catch the ball and run the ball. Doesn't matter which level you pick from.
  16. Dec 16, 2014 at 7:52 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    I use OEM, I get it when I get the washer...it's $5...every 5k
  17. Dec 16, 2014 at 7:54 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Been using the Pure one and Mobil 1 synthetic for 50K without a problem. I don't burn a drop between changes.
  18. Dec 16, 2014 at 8:48 AM
    sirotto
    sirotto Well-Known Member
    Indy
    Taco with a man pedal
    Bone stock
    This seems a lot of talk about something completely irrelevant. The OEM filter may not be the best and sure as hell not the worst but it is what the system has built into it. Why would anyone want to diverge from it?
    Not trying to be a dick but this comes up on every forum i have belonged to.
    Find one record, proving it was an oem filter by itself that caused an engine issue.
    Lack of oil intervals is the #1 killer. Not the filter.
  19. Dec 16, 2014 at 4:09 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    The OEM filter for the 4.0L v6 will fit the 3.4L v6 and gives you a bit more filter element as it's longer. It's also a bit easier to change. OEM has always been the cheapest most effective filter I have found.
  20. Dec 16, 2014 at 4:22 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    I just use a big ol' wad o' cheese cloth duct-taped over the oil filter attachment hole. :D
