Oil filter wrench size: 73mm or 74mm?
Discussion in '4 Cylinder' started by rickcrna, Oct 15, 2013.
  1. Oct 15, 2013 at 9:29 PM
    rickcrna
    rickcrna [OP] Well-Known Member
    Rick
    Vancouver, WA
    '13 AC SR5 4WD I4 Auto MGM
    Am interested in purchasing an Assenmacher oil filter wrench suitable for the OEM oil filter on my 2013 Taco with 2.7L engine. The feedback I am reading is that the 73mm is really snug and it's difficult to remove the filter once off the truck. I have also read people using the 74mm as well.
    Does anyone have any experience with this tool and what proper size to use for my situation? The applications information on the Assenmacher website was not very definitive.
  2. Oct 15, 2013 at 9:35 PM
    13Greysled
    13Greysled Well-Known Member
    WA
    13' Taco
    Tint
    X2 im intersted as well.
  3. Oct 15, 2013 at 10:11 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Great question. I wanted one of those wrenched that is like a socket that fits on the end of the filter so I took an OEM filter to Auto Zone and tried every wrench they sell and none of them fit properly. Then went to O'Reiley, none there fit either. Had to buy a strap type wrench that pivots. It works but you cant really get off to the side on the V6 filter very well. SOMEBODY has to make a socket style tool....
  4. Oct 15, 2013 at 10:21 PM
    DoyleMcpoyle
    DoyleMcpoyle Well-Known Member
    Carlos
    Bakersfield, CA
    02 TRD 4x4
    Why not one of these? I used to work at toyota changing oil. And that's all we really needed.
  5. Oct 16, 2013 at 6:25 AM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    If they are put on correctly in the first place, they shouldn't really need a tool to get them off.
    I worked at a Valvoline oil change place and have done many hundreds of changes. A lot of the factory ones were on way too tight and/or had unlubed gaskets... and that is when we used the tools to get them off.
  6. Oct 16, 2013 at 1:17 PM
    rickcrna
    Rick
    Vancouver, WA
    Since my truck is new and I am anticipating gathering of tools I will need for my first oil change...this is the impetus for the question. I fully anticipate getting the factory installed oil filter off will be difficult without the correct size wrench.
  7. Oct 16, 2013 at 1:32 PM
    Robnik
    Robnik Well-Known Member
    Rob
    Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    73mm with 14 flats
  8. Oct 16, 2013 at 1:34 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I cheat and use a big honkin' pair of vice grips on mine. I bought them in high school at a garage sale for $5, and I figure they've saved me at least $100 in different specific filter wrenches in the last 10 years or so. Lots of different cars, but the vice grips fit 'em all!
  9. Oct 16, 2013 at 1:44 PM
    Robnik
    Rob
    Florida
    I usually just stick a screwdriver through it for leverage. The first time is the worst, especially on Toyotas.
  10. Oct 16, 2013 at 1:51 PM
    Noelie84
    Noel
    Wales, Maine
    I actually tried the screwdriver trick once and I don't recommend it. I actually destroyed the filter trying to get it off the car. That was a LONG afternoon:frusty:
  11. Oct 16, 2013 at 2:26 PM
    Robnik
    Rob
    Florida
    Yeah, I know what you mean. Once the sheet metal starts tearing, you're pretty much screwed. I don't necessarily recommend it either, just as an option. Best bet is a socket cap, filter pliers, Vise Grips or Channel Locks. Not that crap they sell at K-mart or Wal-mart with the red handle. :)
  12. Oct 21, 2013 at 8:40 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    This is a smart anticipation...they are on there stupid tight from Toyo.
    I'd go with the 73mm...and live with it being too tight the first time...
    the one i got from the parts place must have been 74mm...or just slightly
    too large to grab the sides of the filter.
    I had to put a couple screws thru the socket and into the filter to get mine off finally...
    so the socket was basically a throw away anyway.
    As others say, if the gasket is lubed properly and put on right,
    hand tight is all you need after the first removal.
    Good luck with it and plan on spending way to much time getting
    it off.
    PC
