Oil filters?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tennesseetaco23, Apr 9, 2012.
  1. Apr 9, 2012 at 6:02 AM
    Tennesseetaco23
    Tennesseetaco23 [OP] Member
    Oak ridge, Tn
    08 white double cab TRD offroad Tacoma
    What kind of oil filters do yall use for yalls newer tacomas? I was wondering if i should go back factory or is there something yall recommend?
  2. Apr 9, 2012 at 6:39 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Same ^
  3. Apr 9, 2012 at 6:49 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Fram Oil Filter Part# - PH3614 is what I use.
  4. Apr 9, 2012 at 6:50 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Factory filters are hard to beat- I have not seen another filter I would rather run then OEM. ;)
  5. Apr 9, 2012 at 6:57 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I'm with everyone OEM filters are all I use.
  6. Apr 9, 2012 at 6:57 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Theres a comparison on here somewhere. OEM appeared to be the best quality, even against the higher dollar filters.
  7. Apr 9, 2012 at 7:04 AM
    Toyotacrawler
    Cusseta/Opelika AL
    I used Fram in my 01 Taco.
    110,000 miles, regular oil changes every 3000 miles...Never had any engine problems at all. Don't know where my old Taco is now, but I would think it's still doing just fine. Of course, I do think Toyota built em tougher back then though...we shall see. Hope my 2010 holds up like my 01 did.
    It would appear so.
  8. Apr 9, 2012 at 7:15 AM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    I was using the Mann ML 1003 oil filter until I saw this (Thanks Chris 4X4)
    http://youtu.be/kqosalQDQ-A
    I now have a case of factory oil filters in the shed waiting to be installed at the next oil change.
  9. Apr 9, 2012 at 7:32 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    www.bobistheoilguy.com
    Everything you've ever wanted to know about oil and oil related products... and a whole lot of shit you could care less about too.
  10. Apr 9, 2012 at 8:00 AM
    sherlock
    sherlock Well-Known Member
    I wouldn't use a Fram oil filter even if you gave them to me!
  11. Apr 9, 2012 at 10:29 AM
    Toyotacrawler
    Cusseta/Opelika AL
    Agreed. I'll be using OEM from now on. Thanks man.
  12. Apr 9, 2012 at 1:53 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  13. Apr 9, 2012 at 2:38 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i think the last time i bought OEM, the lady at the counter gave me some internet special pricing. $5 each..i got 4 of them.
    i havent bought a FRAM for 25 years.
  14. Apr 9, 2012 at 2:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Camelbacktoyota parts ( vendor on here) sells them to members for $3.96
  15. Apr 9, 2012 at 4:28 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    WIX filter from Oreily's
  16. Apr 9, 2012 at 4:31 PM
    BackwoodsBoy
    BackwoodsBoy Well-Known Member
    Adam
    Pittsburgh Area
    06 TRD Sport
    I use Napa platinum filters..
  17. Apr 9, 2012 at 6:30 PM
    95Gstman
    95Gstman Active Member
    Eric
    Austin, TX
    2009 Reg. Cab 4x4 Tacoma
    OEM. Use to use Wix which is a good filter also.
  18. Apr 9, 2012 at 7:12 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Been reluctant to use OEM thanks to Honda. Stock filter for that car made in Japan by Toyo Roki, but unless you special order it under an S2000 part # for $20+ they give you the 'genuine Honda' filter made by ...Fram.
    Glad to know Toyota actually sells the customer a good filter.
  19. Apr 9, 2012 at 7:21 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
  20. Apr 9, 2012 at 7:27 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
