Oil Leak Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MX81, Sep 22, 2011.
  1. Sep 22, 2011 at 8:00 AM
    MX81
    MX81 [OP] Well-Known Member
    Dallas
    2014 TRD Offroad PreRunner
    This week while changing my oil I noticed the leak in the pic attached. I'm pretty sure it is the oil pan gasket, but just wanted y'alls opinion before I took it in. Thanks
  2. Sep 22, 2011 at 8:48 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That does look like oil pan. You can try bringing to the dealer or you can try tightening oil pan bolts to spec.
  3. Sep 22, 2011 at 8:52 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    degrease area, tighten bolts a little and see if it comes back maybe
  4. Sep 22, 2011 at 9:03 AM
    MX81
    Dallas
    Thanks, I will try that tonight. Does anyone have the torq. specs on hand ?
  5. Sep 22, 2011 at 9:34 AM
    saugus
    saugus Well-Known Member
    It's very little so don't overdo it. I want to say like 70-80 inch lbs on my corolla.
  6. Sep 22, 2011 at 9:37 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Clean the area, but try looking just above the p/s pump, our engines tend to leak from the timing cover and trail down to that area. If it is leaking, it is covered under the powertrain warr., i would gladly fix it if you were in orlando.
  7. Sep 22, 2011 at 9:38 AM
    neoflex
    neoflex Well-Known Member
    Looks like you have a 2010. Just bring it in and have the dealer look at it under warranty. Chances are they will drop the pan and replace the gasket anyway and put it back together to spec with zero cost or time wasted trouble shooting on your end.
  8. Sep 22, 2011 at 11:18 AM
    MX81
    Dallas
    Thanks for the help, I'm actually out of warranty though...about 61k miles.
  9. Sep 22, 2011 at 12:10 PM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    x 2 bingo!
  10. Sep 22, 2011 at 1:51 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    I have a 2009 and there is no gasket only rtv.
  11. Sep 22, 2011 at 6:27 PM
    neoflex
    Doh! I guess you drive the sh*t out of it.:D
    That may be considered Powertrain which is 60K. Maybe they will be good guys and still cover it being so close. I know I have lucked out a few times with warranty work and being slightly past the maturity of it mileage wise.
