Oil Pan Drain Plug Torque Spec.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Terrier, Mar 13, 2008.
  1. Mar 13, 2008 at 9:32 PM
    Terrier
    Terrier [OP] Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Anyone out there have access to a manual that states the torque specification for the oil pan drain bolt on the 2.7 liter 2008 Tacoma?
  2. Mar 13, 2008 at 11:36 PM
    ERdept
    ERdept Well-Known Member
    Sorry don't know but related, get the Fumoto drain valve.
    Eliminates you having the screw the plug on and off and get a new crush washer and potentially risk stripping the threads.
    Fastest oil change I've ever done with this.
  3. Mar 14, 2008 at 7:17 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i keep hearing about this. what is the fumoto drain valve? what does it cost? and does anyone have any pics of it, preferably side by side by the original plug?
  4. Mar 14, 2008 at 10:02 AM
    toyrunner07
    toyrunner07 New Member
    Chesapeake Beach, Maryland
    07 Tacoma SR5
  5. Mar 14, 2008 at 10:10 AM
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    This is one of the two models of Fumoto Drain Valve, the other one has a tube extension to make oil drain even easier.
  6. Mar 14, 2008 at 11:31 AM
    nd
    Nate
    Greenville, SC
    i keep hearing about how easy it woudl be to rip off when you are 4 wheeling. what if you have a skid plate, will that protect it enough?
  7. Mar 14, 2008 at 11:38 AM
    mvega1969
    Laredo
    I do have a skid plate, and even the other Fumoto valve model and I do not see how you can damage this valve and if so, you will definitely will damage the oil pan too. Too risky doing this, but for sure most of us even with a 4x4 model we will not risk the integrity of the truck even without the valve? or are you?
  8. Mar 14, 2008 at 12:15 PM
    isusww
    isusww Well-Known Member
    I have a manual and don't see a torque spec. I always go 1/2 turn past hand tighten. Just a rule of thumb I've used for years.
  9. Mar 14, 2008 at 12:17 PM
    nd
    Nate
    Greenville, SC
    are you talking about the plug or the filter, i have always used that rule for the filter
  10. Mar 14, 2008 at 12:37 PM
    CCRT
    CCRT Member
    2008 Tacoma Access Cab 4X4 Indigo Ink
    30 Ft lbs with crush washer (4.0 V-6)
    28 Ft lbs (2.7 4 cylinder)
  11. Mar 14, 2008 at 8:05 PM
    Terrier
    Idaho
    Thanks for all your replies. CCRT, thanks for the specific information. By the way, I like the music and the Camaro on your link. Is that your Camaro? Veeery niiiice!
  12. Mar 14, 2008 at 9:39 PM
    CCRT
    CCRT Member
    Yes, that's our Camaro......
    Racing season starts April 1st :D
  13. Mar 15, 2008 at 6:03 AM
    oldgoat57
    oldgoat57 New Member
    Yes, Thank you for the Torque spec. I searched high and low and couldn't find it on the web.
    do you have that manual for down load.
  14. Mar 15, 2008 at 7:08 AM
    asdfjkl
    asdfjkl Member
    28 foot pounds for the 2.7L. By the way, The one quart size PH1 style oil filter works perfectly on the 2.7L. I use a M1 301.
  15. Mar 18, 2008 at 10:01 AM
    isusww
    Thats for both really. I have the same page above that was posted, I'm just not smart enough to know what the '30' in the parentheses meant. I have about 1000 .pdf's I'm trying to put together for a complete manual. When I down loaded them, they weren't titled. Fun fun.....
  16. Mar 18, 2008 at 4:00 PM
    CCRT
    CCRT Member
    This may shed some light.....
  17. Nov 4, 2019 at 3:20 PM
    rayshand
    rayshand New Member
    07 Tacoma
    backup cam, tailgate lock
    Thanks, guys. I needed this info just to check my hand tightening feel.
