Oil Pan Heater Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sweater914, Sep 18, 2009.
  1. Jul 5, 2015 at 11:02 AM
    #41
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Coming from an electrician's perspective, nice. Just a thought, you could splice the block heater and this pad somewhere along the line so that you only have one male end to plug in. :)
    kidthatsirish and guitar2323 like this.
  2. Jul 16, 2017 at 8:44 PM
    #42
    brapp_kid7
    brapp_kid7 Well-Known Member
    Never thought about doing this. Looking forward to perhaps do this to both my Tacos
  3. Aug 8, 2017 at 7:03 AM
    #43
    CrashAB
    CrashAB mmm...pimentaco
    Calgary, Canada
    2011 Black DCLB
    Another option is a webasto heater - in line coolant heater that was mentioned previously. We use them extensively on all kinds of vehicles up north and lots of big rigs. I've seen many installed on diesel Landcruisers. They can be on a timer, or on a thermostat, and sip a small amount of fuel (diesel). They are the cat's ass.
    GilbertOz likes this.
  4. Jan 29, 2018 at 7:30 AM
    #44
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    Just rule of thumb for stick on oil pan heaters:
    In 60 minutes, 1 watt will heat up 1 quart by 1C°.
    For example, 125 watt heater in 1 hour will increase temperature by 20C°.
    1 watt x 125=125watt
    125watt / 6 quart = 20.8C°. (My 2.7 lt. takes 6 quarts)
    So leaving on 125 watt pad all night (10 hours) will raise oil to 200C°!!! (Operating temp. is 100C°.)
    So you need timer or thermostat.
    I have timer that starts 2 hours before I start car to warm it up. I do it even around 0C°.
    (Wifi plug, with app with timer and on demand on/off)
    I will try to measure temp of oil pan.
    Atlas86 and DavesTaco68 like this.
  5. Jan 29, 2018 at 8:00 AM
    #45
    Sandyman
    Sandyman Well-Known Member
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    I'm not a science major but the above equation doesn't take into account the passive radiation of the aluminum engine block.
    Years ago a friend here in Anchorage was looking for an interior heater for his Chebby Astro Van. He repurposed a hot air popcorn popper mounted to a piece of plywood and placed in back. He would fire it up about 10 minutes before he was ready to leave, then would drive to work in short sleeves.
    Sandy
  6. Jan 29, 2018 at 11:15 AM
    #46
    egres
    DELCO PA
    Ok, so i went and plugged in heater just for kicks.
    Test started 12pm
    Outside temp +7C°
    Bottom of oil pan +7C°
    30 minuts later: +11
    60 minuts: +12
    90 minuts: + 13
    120 minuts: +13.5
    So I decided to drain some oil and check temp directly:
    2 hours after plug in + 18C°
    I used laser thermometer. I wonder if result would have been different if i have used submerged thermometer.
    Ok so what went wrong? Aluminum desapated all the heat?
    I guess i can increase time its plugged in.
    If its about 5 C° in hour, and i leave car 10 hours overnight, and it heat it up by 50 C°. Minus temperature drop at night.....
    What you think?
    Edit: 3:30 pm
    Outside temp drop to 6C°
    3.5 hours plug in, poured oil sample out and measured 18.5 C°...
    Edit: 5pm
    Outside tepm 5.5C°
    5 hours plug in, sample 18C°
    Done for today, will get better termomiter and try it again.
    deanosaurus and Atlas86 like this.
  7. Jan 29, 2018 at 3:23 PM
    #47
    Sandyman
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    Coolio! Thanks.
    btw, I wasn't trying to be a jerk. I know after many years an Alaska that if my oil had ever gotten that hot the snow would have been melting off the hood and HOT air would have come out of the ducts.
    Sandy
    DavesTaco68 likes this.
  8. Jan 29, 2018 at 5:29 PM
    #48
    egres
    DELCO PA
    No sweat at all, when you said it, i wanted to actually check if formula was right. I got it from british stick on heating pad manufacturer. Will go back to website and check math again.
    Tonight I have set timer for 3 hours before i have to start truck.
    Will try to do overnight measurement when temperatures drop to 25 f.
  9. Jan 29, 2018 at 5:37 PM
    #49
    egres
    DELCO PA
    You right, I was thinking leaving heat all night tonight, i just cameback from drive, but its only 5C° tonight.
    DoorDing likes this.
  10. Jan 29, 2018 at 6:58 PM
    #50
    Taco'09
    Taco'09 Well-Known Member
    For the V6 I was able to put two of the Wolvering 125 watt heaters on the oil pan -- one on each side, and the OEM block heater that fits into the port on the rear of the engine. Works great but depending on the ambient temp you may have to leave it plugged in all night. Kind of neat to jump in and see the temp needle already a 1/4 way up the dial.
  11. Jan 31, 2018 at 4:14 AM
    #51
    egres
    DELCO PA
    So, last night parked truck after long drive, plugged it in right after, 6 pm. After 13 hours plugged in, drained and oil is +5C°. Outside temp -11C°
  12. Jan 31, 2018 at 4:54 AM
    #52
    egres
    DELCO PA
    It was good today, no metal clicking sound that you get from cold start. But it gets -20 C° once in blue moon at my parts.
  13. Jan 31, 2018 at 6:30 AM
    #53
    Sandyman
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    Shazzam! Today is a blue moon.
  14. Jan 31, 2018 at 9:10 AM
    #54
    egres
    DELCO PA
  15. Nov 9, 2019 at 6:15 PM
    #55
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Just did this mod today.... looking forward to testing it this winter here in Oklahoma. It often times will get down into the single digits here during December, January and early February.
  16. Dec 25, 2019 at 11:21 AM
    #56
    mthew96
    mthew96 Well-Known Member
    mathew
    Western Massachusetts
    2008 tacoma TRD sport access cab 6 speed
    Bilstein 5100 kit and 1” spacer 265/70r17 duratracs BHLM DRL mod anytime fog light mod stubby antenna TRD shift knob LED tail lights TRD cat back exhaust
    Do you think there would be any benefit to having the heater on the bottom of the pan opposed to the side? I suppose that always gives the concern of the wires being lower but idk heat rises. I wonder if they work better that way. Or if it even matters at all.
  17. Dec 25, 2019 at 11:23 AM
    #57
    Bishop84
    Bishop84 Well-Known Member
    We can't install these any more, its actually because of VW.
    They were all mounted to the bottom of the pan, they would fall off and ignite the possible oil leak underneath the vehicle caught in the skid tray.
    I prefer the frost plug block heaters as the coolant circulates way more than engine oil. Just way harder to install.
