Oil vs MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Sep 9, 2011.
  1. Sep 9, 2011 at 7:58 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Gonna keep this short and simple. Before my last oil change, I always used Pennzoil conventional or Kendall Synthetic blend depending on price/if I had a shop do the change. With my lift and tires, I consistently got 15-16 mpg. Now, after my last oil change with Mobile1 Full Synthetic, my mpg's have significantly went up. My last 4 fill up's have been: 18.4, 20.1, 19.5, and my last one was 22.4! The first three were all city mpgs, but the last one was highway driving. Is this normal? I'm pretty damn excited.
  2. Sep 9, 2011 at 8:07 PM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    Anything is possible and numbers don't lie. Besides, every vehicles reacts differently to modifications and changes.
  3. Sep 10, 2011 at 4:06 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I know changing old oil to new is good for mpg on a big fleet-wide average but that's way big improvement... did ya change oil weight? still, even that doesn't explain such a big change. There has to be something else you 'touched'. New air filter? Weather cooler so using A/C less? Driving style change? Hard to imagine oil alone accounting for that much improvement unless you went from 90 weight to 20 weight.
    The only accurate way to measure mpg is record gas put in at fill up and divide it into the miles driven since last fillup. Do that over several fill ups (total gas used divided into total miles driven) and you get an accurate average mpg. Using the instrument cluster readout isn't that accurate (but very useful for instantaneously gauging gas use and adjusting driving habits accordingly.)
  4. Sep 10, 2011 at 7:48 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I used the same weight. I clean my K&N at every oil change. Weather has been around the same, maybe a little warmer. Same driving style except for that last fill up was all highway mileage. I use this app called "FuelLog" to monitor my MPG's. I enter my current odo reading, how many gallons, and the price after every fill up.
  5. Sep 10, 2011 at 7:50 AM
    saugus
    saugus Well-Known Member
    Sounds fishy. No new plugs?
  6. Sep 10, 2011 at 9:00 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Nope. i just remembered though that I put some LR UCA's on the same day I changed the oil. Would being in correct alignment help too?
  7. Sep 10, 2011 at 11:30 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Yes it would... tire scuff (from bad toe-in, for instance) is a gas-eater. I assume it was mis-aligned before the UCA install, when you also got an alignment? Was it significantly bad?
    Don't know if it could account for that much but there's more here than just an oil change to be sure.
  8. Sep 10, 2011 at 11:33 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    The only thing off was the camber. It was just eating the outsides of my tires.
  9. Sep 10, 2011 at 11:43 AM
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
    Maybe a data entry error? I've done this many times with my Scanguage!
    You will see as you enter more tank usages!
    I always notice better MPG after a oil change but only lasts 1-2 tanks and about 2-4 mpg better.
  10. Sep 10, 2011 at 12:32 PM
    saugus
    bingo:)
  11. Sep 12, 2011 at 8:02 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Go back to Pennzoil and see if it goes back down.....
  12. Sep 12, 2011 at 9:12 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    I went from the factory oil to Mobil 1 recently, no change in MPG.
  13. Sep 12, 2011 at 9:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, did the same thing and no reported change in MPGs.
  14. Sep 12, 2011 at 12:34 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2016 Black AT DCSB 4x4 TRD
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Sub Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Starter TRD Pro Grille ROAV Dash Cam 3" RC Lift Turn-down exhaust pipe TRD PRO Shift Knob vF Tune
    there's the change! :)
