OIL
Discussion in 'Mid West' started by donson61, Nov 4, 2010.
  1. Nov 4, 2010 at 12:01 PM
    donson61
    donson61 [OP] New Member
    illinois
    2010 tacoma
    Does anyone run full synthetic in the newer tacomas. The local dealership did not reccomend synthetic, my first oil change is coming up. WEST CENTRAL ILL.
  2. Nov 4, 2010 at 12:25 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    There is no reason why you shouldn't go with syn. Mobil 1 with a OEM filter for me. BTW welcome to TW. I look forward to seeing you around the forum.
  3. Dec 31, 2010 at 6:57 PM
    vwthingguy
    vwthingguy USAF SecurityPolice
    Illinois
    1996 Tacoma 2WD
    200,000 mi
    I run it in my first gen just fine. Truck has 188K on it and runs like new. Synthetic provides better wear protection, reduced start-up friction and lower maintenance cost (with extended oil change intervals). You can't go wrong with a good synthetic.
  4. Dec 31, 2010 at 7:06 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    What reason did they give???
  5. Dec 31, 2010 at 7:21 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Don't the new ones come with syn from the factory??
