Oil
Discussion in '4 Cylinder' started by 03dyna, Nov 10, 2009.
  1. Nov 10, 2009 at 8:08 AM
    03dyna
    03dyna [OP] New Member
    Chip
    Vermont
    2009 Tacoma SR5 4 cyl. 4 x 4
    Hello all,
    First 5K oil change coming up. What kind of oil OEM oil was used, regular 5 20w, blended synthetic, or synthetic?:)
  2. Nov 10, 2009 at 8:18 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I think it would vary in different areas. In Tucson, they Toyota rep was telling me they use 'semi-synthetic'. I run Mobil 1 5w-30 w/ OEM filter. IMO our engines run good on synthetic, people use different types of oil. You just got to pick one and see how your engine runs on it.
  3. Nov 12, 2009 at 10:07 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Doesn't matter, you can mix and match synthetic, regular, and semi-synth all you want. It's the numbers that count, don't put 5-20 in with 10-40.
  4. Nov 12, 2009 at 10:12 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Your 2.7 can run 0w20 or 5w20, but I think 0w20 is only available as a synthetic. I run Mobil 1 5w20.
  5. Nov 12, 2009 at 12:50 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    my dealer used regular 5w20 but i put castrol syntec...helped alot...made the engine run much smoother
  6. Nov 12, 2009 at 3:33 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    youre in vermont so it gets pretty damn cold up there, i woud run mobil 1 0w-20 synthetic. its a better oil for colder climates and easier on start-up.
  7. Nov 14, 2009 at 5:20 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I use AMSOIL Signature Series 0W-30 and EaO-57 oil filter.
    I drain the crankcase annually. The filter is changed at 5,000 mile intervals.
    Son #1 lives at Grand Forks, North Dakota (Also known as Lower ManiSkatchiwan.:canada:) and does the same with his 4cyl/5spd Tacoma.
  8. Nov 15, 2009 at 9:15 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Not sure what your crankcase was filled with at the factory, but with this oil change at 5k I suggest you run a round of regular (dino) 5w20. Dino oils work fine but they don't protect *quite* as well as synthetics, so this will allow the rings and cylinders to wear in a bit better. Then switch to a synthetic after 10-12k. Just my opinion.
  9. Nov 15, 2009 at 9:54 AM
    def4pos8
    Ohio
    The crankcase was filled at the factory with whatever Service J 5w-20 was cheapest that day.
    I feel better doing what I have done. At 1063 miles there was a metallic shimmer to the transmission oil, probably due to synchronizer wear-in. The differential lube had some micrometal in it -- and a nice metal chip on the drain magnet.
    I didn't cut open the engine oil filter like I do for my airplane but if I had, a few sparkles of micrometal would not have been a shock.
    No worries! I've done this before -- six times.
  10. Dec 1, 2009 at 1:13 PM
    Deer Slayer
    Deer Slayer Active Member
    NW Mississippi
    08 4X4 I4 MT Acc Cab
    You don't have any issues with using 30 weight oil on an engine that calls out 20 weight?
    The reason I am asking is that I have the same truck and was thinking about putting exactly the same oil and filter in there, but everybody been telling me you can't put 30 grade oil in it because it would adversely affect the VVT engine operation....(some thing like that).
    How does the car run on this combination? Does it run any smooter than 20 weight oil?
  11. Dec 1, 2009 at 1:20 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I don't know if anybody on this forum knows for sure if running a 30 wt oil instead of a 20 wt oil will hurt the vvt-i. My question is, why would you take the chance? I will continue to run what the owner's manual and oil cap tell me to. JMO.
  12. Dec 1, 2009 at 1:34 PM
    SuperSnoop
    SuperSnoop Member
    Vermont
    04 Tacoma Bare Bones
    I was getting some top end knock/rattle after startup a while back and since have been running Lucas Oil Treatment (1qt) with the balance being standard 5-20 wt. oil. No startup knocks and my oil seems to remain cleaner after my regular 5000 mile changes. Anyone with good or bad experience with the Lucas?
  13. Dec 1, 2009 at 2:02 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    lucas is some good stuff!
  14. Dec 1, 2009 at 5:47 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I've ran mobil 5-30 for 27000 kilometers and no issues (why would there be any, your 20 wt oil is at the same viscosity than a 30 wt when it's not at it's hottest!). Now I'm trying the mobil 5-20 that the book is calling for.
  15. Dec 1, 2009 at 9:20 PM
    def4pos8
    Ohio
    No problems!
    My VVT works just fine!! An 0W-30 has a "base number" of about 15 versus 10 of an 0W-20. They both flow through things with ease -- especially a fully-engineered synthetic like the AMSOIL Signature Series product. I pull a 2,000-lb cargo trailer now and then -- plus cargo. I like the extra bit of protection offered by the 0W-30.
    I've only had my Taco for a few weeks but my children have been running up tens of thousands of miles on their (same driveline) '08s and '09 over the past two years. They all use Signature Series 0W-30 and change out the miniscule EaO-57 filter at 6,000-mile intervals. We also use AMSOIL Severe Gear 75W-90 lubricant in our differentials and transmissions.
    Smoothness is a very subjective thing. All of the Toyotas I've ever had were smoother than any of the domestic products we were forced to operate by circumstance. I'd have to say that MY engine does operate with less noise after installing the 0W-30. I don't detect as much whining from the thing as before.
    Our trucks operate trouble-free in Arizona, Texas, Ohio and North Dakota (Lower Maniskatchiwan, eh! :canada:).
  16. Dec 2, 2009 at 7:38 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
  17. Dec 2, 2009 at 6:36 PM
    supralight
    Dan
    Earth
  18. Dec 4, 2009 at 11:06 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I would use the weight recomended although I doubt 30W will hurt anything. As far as brand, any major brand should be fine. Regular changes are more important than brand names.
