Ok..how does this happen?
Discussion in 'Arizona' started by smabbott, Jun 15, 2014.
  1. Jun 15, 2014 at 3:05 PM
    smabbott
    smabbott [OP] Well-Known Member
    Stevo
    AZ
    So i just finished the New River trail from I-17 and Table Mesa Rd to Carefree highway. It was a pretty rough trail, but i didn't think it was THIS rough...
    question..
    Was this because my shock wasn't installed right (just had icons installed two weeks ago), because i pushed it too hard, or what? How does something like this happen? I have an appointment with the shop that installed them but it is about 30 minutes away.. another question; is this something unsafe to drive on? I'm just lucky i'm home instead of stranded in the desert!
    thanks,
    Stephen
  2. Jun 15, 2014 at 3:09 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    It's a shock. Not having it won't kill you. Were there any remnants of a bolt left? Looks like the nut may have backed off and the bolt came out. Tie it up or remove it and go on about your day.
  3. Jun 15, 2014 at 3:09 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    the bolt wasnt torqued down properly. the collars are now missing that you need to get from icon or a dealer.
  4. Jun 15, 2014 at 3:10 PM
    DeSean Thick
    DeSean Thick TuRD TACO
    Sean
    Snowmass, CO
    05 TRD Sport Speedway Blue
    probably a little rough. happened to me in moab and i drove it for a year without replacing a shock. wouldn't recommend it but it's safe to drive. just remove it entirely before you do
  5. Jun 15, 2014 at 3:16 PM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    If you plan to ride it like this, just take out the shock... and remember while driving you dont have a shock...
  6. Jun 15, 2014 at 3:25 PM
    smabbott
    Stevo
    AZ
    Ughh.....bummer.
    I have an appointment in Tempe tomorrow morning and i live in Peoria. Will take the shock out and carefully bring my truck for repair.
  7. Jun 15, 2014 at 4:41 PM
    JeepAndrew
    JeepAndrew Nah bitch Jeep guy
    Andrew
    Tucson, AZ
    Offroad beast YJ/2015 Taco
    Lots-o-mods
    Certain suspension components have to be re-torqued after a certain number of miles from install, regardless of whether you or a shop did the install. I've heard between 100-500 miles. Hardware for components with bushings and u-bolts are very susceptible to coming loose.
    Plus, you'd be surprised at how often stuff like "final tightening of bolts" is missed at shops.
    You could go to a local Autozone, Oreilly etc or even the hardware section in Lowes or Home Depot and pick up a new grade 8 bolt and nut that'll work till you can get it in to be fixed.
  8. Jun 15, 2014 at 4:58 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, & hit those threads with some locktite, red or blue either one will do..
  9. Jun 15, 2014 at 5:17 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
    Exactly!
  10. Jun 15, 2014 at 7:18 PM
    smabbott
    Stevo
    AZ
    Okay so i manned up and fixed the damn thing.
    Bought a jack, some replacement nuts and bolts, and youtubed my way to success.
    Going to get a torque wrench so i can make sure everything is where it needs to be. Locktite is next.
    I now have some tools i should have had in the first place and know a little more..
  11. Jun 15, 2014 at 7:23 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Atta boy Stevo !!!....:thumbsup::thumbsup: There is no subsitute for self reliance, & I DONT care what you read or whatever ANYONE has told you about the U bolts . Make sure they're at least 70 ftlbs. ...;)
  12. Jun 15, 2014 at 8:24 PM
    JeepAndrew
    Andrew
    Tucson, AZ
    Lots-o-mods
  13. Jun 15, 2014 at 8:30 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    How secure does the shock look on the passenger side? :devil:
  14. Jun 15, 2014 at 10:44 PM
    smabbott
    Stevo
    AZ
    Nut was missing on passenger side too.....
    Replaced and Torqued to 74 ... Taking a look at ubolts now
  15. Jun 15, 2014 at 10:47 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Someone didn't tighten it.
  16. Jun 15, 2014 at 10:51 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    This and the bolt was facing the wrong way bolt head should be facing the tire so if the nut does somehow fall off the bont will have a harder time coming out
  17. Jun 15, 2014 at 11:20 PM
    smabbott
    Stevo
    AZ
  18. Jun 15, 2014 at 11:36 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
  19. Jun 15, 2014 at 11:57 PM
    KenLyns
    Belly of the Beast
    This only applies to OEM bolts, by the way. Once you change to bolts with a different thread pitch, the torque specs go out the window. The Icon shocks come packaged with SAE grade 8 (as opposed to metric) bolts and nylon locknuts.
  20. Jun 16, 2014 at 12:16 AM
    smabbott
    Stevo
    AZ
    How does that effect the torque specifications?
    .. or a better question; how do i obtain torque specs if going SAE grade 8
