ok ive decided
Discussion in 'Suspension' started by toyotadude5, Oct 26, 2009.
  1. Oct 26, 2009 at 3:49 AM
    toyotadude5
    toyotadude5 [OP] Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    so for now since im on a budget im going to do a 3 inch suspension instead of the 6 inch. i know rough country sells one. Price is 250. is this a good setup? i plan in doing 15 inch rims on 33 inch mudders. Will the 15 inch rim cause any probs? any other inexpensive suspension setups?? thanks guys. also if you have pics of one (2008 tacoma access cab sport) please post, or other new models. thanks
  2. Oct 26, 2009 at 3:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Are you planning on off roading your truck at all?? Cause that spacer lift is not the way to go if you are. Look into the Bilstein 5100's. A little more money...but way worth it.
    IIRC- 15" rims are too small...16" is the minimum.
    33's will require you do some trimming, just so you know.
  3. Oct 26, 2009 at 7:56 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    DONT DO IT.save up and get a lift w/o the spacers.i did the spacers and the ride was horrible imo.
  4. Oct 26, 2009 at 7:58 AM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    I am looking to do about a 2 inch lift and will not be doing any off roading. My truck is an everyday driver so the ride will need to be good. What are my options?
  5. Oct 26, 2009 at 9:19 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    what brunes said in previous post.
  6. Oct 26, 2009 at 3:18 PM
    toyotadude5
    chris
    Flagstaff, az
    yes some off roading but mostly want for the snow up here and my upcoming hunt.
    so 15 inch rims will not work at all?
  7. Oct 26, 2009 at 3:39 PM
    toyotadude5
    chris
    Flagstaff, az
  8. Oct 26, 2009 at 3:44 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    15s wont clear your calipers. And depending on what type of spacers you are looking at. Some spacers require you to compress the spring adding preload. Real shitty ride. Procomp and Readylift leveling kits are spacers that go on top of the shock. This type does not add preload and your truck will ride and handle the same as stock just sit 2.25" higher in the front. They are realiable and tough. 4wheelparts.com sells then for around $200. Procomp/ready lift also makes these leveling spacers for 3/4t trucks out of the same material so it is tough enough for our little trucks.
  9. Oct 26, 2009 at 3:47 PM
    Yoytoda
    Roland
    completely stock
    That wont mess with ride quality. The spacer lift that toytec sells goes on top of the coil adding preload. This style goes on top of the entire assembly maintaining your factory ride. Perfect for light offroading and for a dd
  10. Oct 26, 2009 at 4:02 PM
    toyotadude5
    chris
    Flagstaff, az
    ok so i want that rough country kit. good price. i have a buddy that will sell me some 33 mud terrains cheap. only problem is they are 15 inch rims. i have 15 in toyota rims from an old truck. what type spacers do i need for these rims and tires to fit with this lift kit?
  11. Oct 26, 2009 at 4:10 PM
    Yoytoda
    Roland
    completely stock
    15" rims wont fit. the calipers are too big. The spacers i was talking about were the lift spacers. there is no way to get 15s on your truck. Also 33s will rub pretty bad 265/75-16s are 32"x10.5x16
  12. Oct 26, 2009 at 4:13 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    For sure...a 16 stock barely clears them...got 5100s...they are not much more and will make a world of a difference...unless you just want it for show and like to bounce all over the place.
  13. Oct 26, 2009 at 4:17 PM
    Yoytoda
    Roland
    completely stock
    the spacers that go on top of the shock wont bounce him because it does not add preload. only the spacers that go in between the spring and the top place add preload for lift. Rough country lift wont add preload so no bouncing all over the place
  14. Oct 26, 2009 at 4:19 PM
    TRICOMA
    Tri
    Carlsbad, CA
    Got it...but billy's for just a bit more...well worth it
  15. Oct 26, 2009 at 4:19 PM
    Yoytoda
    Roland
    completely stock
    ive got the readylift spacers until i get the AP Long travel kit. No bouncing, stock ride, no issues.
  16. Oct 26, 2009 at 4:22 PM
    Yoytoda
    Roland
    completely stock
    i almost went with the bilies but talking to the offroad shop they told me billies arent that good either. When you set them at 2 or 2.5 you sacrifice down travel so the spacers are better for a cheap practical lift without sacrificing down travel.
  17. Oct 26, 2009 at 4:33 PM
    TRICOMA
    Tri
    Carlsbad, CA
    On my tundra they were just set enough to fix the rake...but compared to the stock shocks they were much better...I am saving up for Fox's 2.0 myself...I would love to have LT but it would likely be too much suspension for me and it's about double or triple the price of a midtravel...I don't plan on jumping my truck...just trails and some crawling. Are you in socal now? I just want to do it right the first time...either way he goes..as long as he is happy with it that is all that that matters
  18. Oct 26, 2009 at 5:21 PM
    Yoytoda
    Roland
    completely stock
    yeah im in the inland empire. I either want AP long travel or i want 2.5 camburg or fox 2.5 remote resi coil overs with tc ucas. but till i can scratch up 2-3000 i like my spacer lift so i can at least upsize the tires
