Okole installation help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aww1970, Oct 8, 2008.
  1. Oct 8, 2008 at 7:41 PM
    aww1970
    aww1970 [OP] Well-Known Member
    2009 Tacoma TRD Long Box
    I just Finished (almost) installing my new seat covers. I could find no feasable way to get the front-upper cover to wrap around the seat back bottom and velcro to the back of the cover?
    Any help would be appreciated.
  2. Oct 8, 2008 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Which seat? I took my seats out of the truck to install them. Saves you some time, and makes installing the covers much easier. :)
  3. Oct 8, 2008 at 7:51 PM
    aww1970
    It is both front seats- the upper portion of the cover. The seat back seems one piece and I could not see how it is possible velcro the front to the back?
  4. Oct 8, 2008 at 8:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'll have to go and check out mine. I cant remember haveing that issue.
  5. Oct 8, 2008 at 8:21 PM
    aww1970
    Thanks I would appreciate that.
  6. Oct 9, 2008 at 12:37 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Might be different depending on the seats you have, but on mine...the on passenger seat you had to stuff the front flap between the crack in the seat (where the seat folds forward) and tug it through then it will velcro to the back piece, it's a snug fit. On the drivers seat you have to unhook the flap on the back of the seat that goes underneath the seat and fold it up then pull the cover through the crack, you will leave the flap of the seat folded up and put the cover over it and attach it to the under side of the seat...confusing huh :confused:... over on ToyotaNation there is a thread with pics and install tips..
    http://www.toyotanation.com/forum/showthread.php?t=235795&highlight=okole+installation&page=2
  7. Oct 9, 2008 at 5:08 AM
    rc2125
    rc2125 Well-Known Member
    Indiana/Michigan border
    19 TRDor
    Unattach the factory "flap" bungee/hooks from under the seat and then fold the "flaps" up (I used two small pieces of duct tape stuck to the inside of the seat pouches, otherwise they kinda stick out to much under the covers), then you can slide the covers over and wrap around the seat crack. Thats how wet okole said they were designed to install.
  8. Oct 9, 2008 at 6:40 AM
    aww1970
    Thanks guys!
