Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 25, 2013 at 3:19 AM
    #2061
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Did you get new bushings or re-use your old ones?
  2. Jun 25, 2013 at 6:43 AM
    #2062
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Did you tightened the hangers (front frame mount and rear shackle) while the truck was in the air? Shouldn't be torqued until trucks back on the ground and bounced a couple times.
  3. Jun 25, 2013 at 6:51 AM
    #2063
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I'm stock and currently at:
    Front Driver - 20" Rear Driver - 22 1/4"
    Front Pass - 20 3/8" Rear Pass - 22 5/8"
    Little less than 1/4 tank fuel.
  4. Jun 25, 2013 at 7:02 AM
    #2064
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Haha you must look a little tilted :D.
  5. Jun 25, 2013 at 2:39 PM
    #2065
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    Alrighty guys im just about too pull the trigger on a OME 3" suspension kit i would be purchasing and getting the install done at my work (a Toyota dealership) I have been working with one of my service advisors just making sure what is and is not in the kit and it has Dakar leafs, 886 coil/springs..
    Is there anything i am missing and should make sure it is included?:confused:
    Thanks
    -Kris
  6. Jun 25, 2013 at 2:48 PM
    #2066
    bjboucher
    Brad
    San Antonio, Texas
    If you're getting 886s, you're going to get more than 3" of lift probably. Are you putting a steel bumper or a lot of armor on? You might want to splurge for some UCAs. Might have issues getting alignment without them. Carrier bearing drop, extended rear brake lines, might need axle shims.
  7. Jun 25, 2013 at 2:49 PM
    #2067
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Do you have, or are you planning on adding extra weight up front? Like armor or a winch. If not, you should go with 885s, 886s are a higher spring rate, so they are stiffer, and designed for trucks with extra weight up front.
  8. Jun 25, 2013 at 2:56 PM
    #2068
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Yes i wanted the 886's because i plan on getting a full skit kit, a Bruteforce hybrid front bumper and a BF rear bumper and eventually a winch.
    I do plan on getting after market UCAs eventually..
    But my service advisor did say he didn't really think i would need extended brake lines with that much lift?? should i get them anyways?
    Carrier bearing drop?? similar to a Diff drop?
    And axle shims?? to get rid of any vibes??
  9. Jun 25, 2013 at 2:58 PM
    #2069
    bjboucher
    Brad
    San Antonio, Texas
    Brake lines for the rear is recommended around here. At full droop with the Dakars, you'll be pushing the limits of the stock ones.
    The carrier bearing is in the middle of the drive shaft, attaches the frame. The kit adds some small spacers to keep stock driveline angles. Helps with vibrations. Axle shims do as well.
  10. Jun 25, 2013 at 3:06 PM
    #2070
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Ohh ok so go ahead and get those extended brake lines as well!
    Oh i gotcha! so just make sure it includes the carrier bearing drop!
    Does it normaly come with that in the lift kits?
  11. Jun 25, 2013 at 3:19 PM
    #2071
    evanmb31
    evan
    connecticut
    09 trd off road
    Yes it normally does, that and the trim packer. Where are you ordering from? Got a link? Most of the time the OME kit doesnt come with bushings for the rear eye of the dakars. Make sure your kit has longer u-bolts also.
  12. Jun 25, 2013 at 3:24 PM
    #2072
    bjboucher
    Brad
    San Antonio, Texas
    I ordered through wheeler's and I had to ask for the CB drop and I never got axle shims. Luckily I didn't need them. Wheeler's knows to send you a set of bushings for the rear eye though.
  13. Jun 25, 2013 at 3:30 PM
    #2073
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Where did you guys get your extended brake lines?
    And im getting it installed at my work, i work at Mark Miller Toyota so one of the techs at my work is doing the install..
    Where do you get the bushing for the rear eye normaly if not included?
    Also does a OME kit normaly come with longer u-bolts?
  14. Jun 25, 2013 at 3:39 PM
    #2074
    bjboucher
    Brad
    San Antonio, Texas
    I got everything from Wheeler's Off Road. It looks like everything including the additional bushings were included in the kit price. Kind of hard to tell for sure, they're all itemized on my receipt.
  15. Jun 25, 2013 at 3:49 PM
    #2075
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Look up OCTaco on here. He's got an awesome group buy for longer lines. Check my build thread for pics. Great deal, high quality stuff.
  16. Jun 25, 2013 at 3:59 PM
    #2076
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    hhmmmm well ill have too make sure its all included..
    So have they got some good reviews then?
  17. Jun 25, 2013 at 4:09 PM
    #2077
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Alrighty so it does include new Ubolts and they reuse the bushings for the Dakar leafs so it doesn't include new ones so I will be buying those lol
    Another question can you just flip the u-bolt or do you need a u-bolt flip kit to do that... and what are the advantages of doing so?
  18. Jun 25, 2013 at 4:27 PM
    #2078
    bjboucher
    Brad
    San Antonio, Texas
    You need a kit. The Ubolts that come with the kit are so long it's almost ridiculous. I've thought about cutting an inch or 2 off of them.
    The advantage to the flip is that it buys you a couple inches of ground clearance in that area.
  19. Jun 25, 2013 at 4:32 PM
    #2079
    YOTA LOVER
    NH
    They are awesome. Stainless steel braided, plastic coated any color you want. Check his thread. And you can put them in without hacking up the stock bracket in the rear.
  20. Jun 25, 2013 at 4:35 PM
    #2080
    bjboucher
    Brad
    San Antonio, Texas
    Doh! Wish you would've told me this when I was ordering my kit! Thanks for nothing! lol I haven't installed them, guess it's not too late yet.
