Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 23, 2013 at 1:44 PM
    #201
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You would be higher in the front, if thats the look your going for then ya 885s up front and stock rear. If you want it level you should go with shorter springs up front or lift the rear
  2. Jan 23, 2013 at 1:45 PM
    #202
    Tacoma414
    Tacoma414 Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    I know that's what I want, so since I'm leaving the back stock, should I get the 884s or 885s, I just wanted to be a little higher then the 2" spacer lift I have mow
  3. Jan 23, 2013 at 2:05 PM
    #203
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    You cannot put in OME 885x coils in the front and stay stock and not expect a bro lean. I thought you said you had 2" blocks back there :/
    Interesting
  4. Jan 23, 2013 at 2:09 PM
    #204
    evanmb31
    evan
    connecticut
    09 trd off road
    On average with a lighter truck like yours
    884s ~ 2-2.25"
    885s~ 2.5-2.75"
    What are you center of hub to fender measurements right now?
  5. Jan 23, 2013 at 2:10 PM
    #205
    Tacoma414
    Cody
    Agua Dulce
    How much of lean would I have? I'm .5" higher in the front and it's barely noticeable I just wanted to go a little higher and loose the spacers completely
  6. Jan 23, 2013 at 2:17 PM
    #206
    evanmb31
    evan
    connecticut
    09 trd off road
    884s. Less need for aftermarket UCAs.
  7. Jan 23, 2013 at 2:19 PM
    #207
    Tacoma414
    Cody
    Agua Dulce
    So I'd still have the same look then? And I need the 1/4" spacer for the taco lean right?
  8. Jan 23, 2013 at 2:20 PM
    #208
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd go with a spindle lift and not waste my time with coils. You'll get more of the look you want because they push the front tires out further also. You won't have to mess with UCAs since all the stock geometry is retained. Put a 1.5" AAL in the rear and you'll still have that bro look you want but it's a simplier lift.
  9. Jan 23, 2013 at 2:23 PM
    #209
    evanmb31
    evan
    connecticut
    09 trd off road
    If you get 5100s then yes 1/4 top plate spacer spacer. If you get OME shocks then you can get the trim packer and not the top plate spacer. It is hard to be sure you will have the same amount of lift or higher. Post your center of hub to fender measurements, that will help. Every truck is different but going off of averages i think 884s will be the same or a little higher than what you have now. Just a guess tho because i don't know that you have exactly 2" of lift right now.
  10. Jan 23, 2013 at 2:24 PM
    #210
    Tacoma414
    Cody
    Agua Dulce
    I have a 100k on my stock shocks so I want to replace them anyways
  11. Jan 23, 2013 at 2:26 PM
    #211
    Eagledynasty
    AJ
    Worcester, MassHole
    The top plate spacer is 3/4" of lift.
    I think the taco lean spacer is 1/4" an should be used with any shock, may be wrong on that though.
  12. Jan 23, 2013 at 2:29 PM
    #212
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OME shocks use the OME trim packer
  13. Jan 23, 2013 at 2:30 PM
    #213
    evanmb31
    evan
    connecticut
    09 trd off road
    Top plate spacers come in different thicknesses, 1/4 should take care of tacolean :notsure: I was refering to the OME trim packer for taco lean, only works with OME.
  14. Jan 23, 2013 at 2:31 PM
    #214
    Tacoma414
    Cody
    Agua Dulce
    That's what I thought as far as the trim packer, so I think I'm gonna go with the 884s, 5100s all around and call it a day
  15. Jan 23, 2013 at 2:34 PM
    #215
    Eagledynasty
    AJ
    Worcester, MassHole
    You'll be happy. It will probably make you sit .5" more in the front. But its an estimate. Every truck is different.
    Just put a ton of weight in the bed to make it sit lower :D
  16. Jan 23, 2013 at 2:36 PM
    #216
    Tacoma414
    Cody
    Agua Dulce
    Well I already have the 2" spacer so it'll look the sand just ride 10x better
  17. Jan 23, 2013 at 2:40 PM
    #217
    evanmb31
    evan
    connecticut
    09 trd off road
    I would say thats a good choice, 885s would be a little much but that is just my opinion, to me the only time a tacoma looks nice with major bro lean is full long travel. Your pushing it with 885s also, the higher you go the more need for aftermarket UCAs. I still think you should go measure before purchasing anything. Or do what Pugga said and do a spindle lift with AAL
  18. Jan 23, 2013 at 5:02 PM
    #218
    Burgess65
    Burgess65 Active Member
    I'm about to put on the OME lift with the 885X coils from Toytec for my 08 access cab and I was wondering whether I should install the top plate spacer (.5 inch) or not. The back has the 1.5 inch aal. I am wanting my truck to sit more or less level and would like to avoid the front tilting upward at all. I have searched around but haven't found a definitive answer. Any thoughts/comments would be great!
  19. Jan 23, 2013 at 5:03 PM
    #219
    OZ-T
    Peter North
    British Columbia
    Not
  20. Jan 23, 2013 at 5:11 PM
    #220
    Burgess65
    What about potential sag? Or was the sagging relieved after the ome using the x model springs?
