Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 4, 2013 at 9:07 AM
    #2181
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I actually prefer using a sawzall most of the time. Grab some lenox gold metal blades and they fly through bolts. The thin kerf makes real quick work of hacking up metal. I even did the majority of my cab mount chop with a sawzall lol. Maybe i just like using a sawzall because im a carpenter :D
  2. Jul 5, 2013 at 3:28 PM
    #2182
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Picked up about a half bed's worth of firewood today and the truck didn't sag a bit. Was pretty nice. Same amount of wood with the stock leafs and I was hitting the bump stops whenever I hit a bump. Loving the Dakars!
  3. Jul 5, 2013 at 3:32 PM
    #2183
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    It has its applications, but I prefer the angle grinder with a cutting blade.
  4. Jul 7, 2013 at 12:48 AM
    #2184
    Gitmo
    Gitmo Well-Known Member
    Justin
    Hey guys,
    After reading 50 pages or so of this thread...I have a few questions..
    I just bought the OME kit w/ 885's from toytec including the dakars for the rear. I will be cancelling the order for the 885's tomorrow and changing it to the 886's because I want to add a bumper as well. For a 10' tacoma, do I need 3 degree axle shims? I just ordered the lengtheners for the installation but haven't ordered the shims yet because on the toytec website, it said it helps with vibrations on 95.5-09 tacomas...
    Is there anything else I need to know about for the install? I also bought LR uca's, bora 1" or 1.25" spacers (still undecided) and plan on buying AMR teflon rims with 285/70/17 duratracs. I do realize I will have to do some trimming/cab mount chop.
  5. Jul 7, 2013 at 4:31 AM
    #2185
    evanmb31
    evan
    connecticut
    09 trd off road
    What are the specs on the wheels? If the wheels are available with the correct backspacing/offset you will not need spacers
  6. Jul 7, 2013 at 5:57 AM
    #2186
    bjboucher
    Brad
    San Antonio, Texas
    I didn't use shims, just a carrier bearing drop and I have no vibrations. What lengtheners are you talking about? The center pin collars?
  7. Jul 7, 2013 at 7:26 AM
    #2187
    Gitmo
    Justin
    Yea the center pin collars. Ill just cancel the order if I dont need them.
    Wheel specs - AMR Mojave AX9816 - 17x8"/6x5.5"
  8. Jul 7, 2013 at 7:52 AM
    #2188
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Whether or not you need centre pin collars depends on which style of axle shims you buy
    If you plan on getting the style that slide in giving you the option to add them at any point , get the collars ( these shims have a hole in them large enough for the centre pin head to fit through )
    This style :
    http://toyteclifts.3dcartstores.com/Zinc-Rear-Axle-Shims_p_273.html
    Toytec also sells an axle shim set up with an extended pin but this set up requires you to add the shims to the leaf pack prior to install as the hole through the axle shim is the size of the centre pin shaft and not the head
    This style :
    http://toyteclifts.3dcartstores.com/Solid-Steel-Axle-Degree-Shims_p_358.html
  9. Jul 7, 2013 at 6:39 PM
    #2189
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    Noob question:
    Wheeler's website says ome 881 coils will give me 1.75" to 2" lift.. I want a good 2" but don't want to go all the way 3".. I've heard of the 881's sagging to less than 1.5", has ome fixed this issue?
    And does anybody have any real world numbers as to how much lift the 881's gave them?
    Keep in mind I don't and won't have an aftermarket bumper. Thanks!
  10. Jul 7, 2013 at 6:47 PM
    #2190
    bjboucher
    Brad
    San Antonio, Texas
    I know they supposedly fixed the sagging issues on the 2nd gen springs. The new springs have an X after the numbers. Haven't seem much discussion in here from 1st genners though. You could always e-mail dan@wheelersoffroad.com and ask him if ARB updated the 1st gen springs too. As for height, the 2nd gen springs give more lift than is claimed. Their 2" lift kits usually net about 2.5".
  11. Jul 7, 2013 at 6:59 PM
    #2191
    evanmb31
    evan
    connecticut
    09 trd off road
    I googled the wheels, came up with 4.5 backspacing and 0mm offset. You dont need wheel spacers to run 285s on these wheels. Some wheels in the style do not clear the front brake caliper though. Before you buy them you should look into that, maybe just send american racing an email, they have a wheel fitment guide on their website and the mojaves do not come up on the list when you select tacoma as your vehicle.
  12. Jul 7, 2013 at 7:18 PM
    #2192
    DirtyDTaco
    Matthew
    Mississippi
    Thanks man I'll do that.
  13. Jul 8, 2013 at 7:57 PM
    #2193
    Texas Taco
    Texas Taco Well-Known Member
    U.S.
    2016 TRD OR DC 4x4 QS
    Icon stage 4 w/RXT leaf pack and shocks, Icon hydraulic bump stops, LT285/75R16 BFG KO2s, 30" Rigid light bar, HIDs, and window tinting. More to come...
    I've been contemplating going the OME springs/5100's route for the time being. Right now I'm completely stock as far as bumper and all but I eventually plan to add a plate bumper. Which spring should I go with for my current setup? I'm assuming the 886 would be way too strong for a stock application. Would 885's be the preferred route for approx. 2"-2.5" of lift up front? I would be running the 5100's at the lowest setting.
    Any advice from anyone running a similar setup would be greatly appreciated.
  14. Jul 8, 2013 at 8:04 PM
    #2194
    NCTacoma
    NCTacoma Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    That's my plan as well. I have a set of 885's that I just put up for sale because I keep hearing they give you 3". I want 2" with 5100's. I hate to sell my 885's if they will do 2". Anyone have info?
  15. Jul 8, 2013 at 8:06 PM
    #2195
    evanmb31
    evan
    connecticut
    09 trd off road
    Probably around 2.5" on a double cab with 885s
  16. Jul 8, 2013 at 8:07 PM
    #2196
    OZ-T
    Peter North
    British Columbia
    This is what I got
  17. Jul 8, 2013 at 8:07 PM
    #2197
    NCTacoma
    Caleb
    CLT, NC
    and 884s?
  18. Jul 8, 2013 at 8:08 PM
    #2198
    NCTacoma
    Caleb
    CLT, NC
    Do the different shocks make a difference to the lift height? OME's vs 5100s? Doesnt seem like they would, just asking.
  19. Jul 8, 2013 at 8:13 PM
    #2199
    OZ-T
    Peter North
    British Columbia
    Doubt it
  20. Jul 8, 2013 at 8:13 PM
    #2200
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    5100s are adjustable OMEs are not so depending on the setting then yes they do make a difference
