Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 8, 2013 at 8:13 PM
    #2201
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I ran 886s without my plate bumper for a year. Didn't experience any issues. Truck handled better than my wifes car! Had to install 1/2" TP spacer after the bumper went on to reduce rake back to 1/2".
    The coil produces the lift, so I would assume the Billie set at 0 would be exactly the same.
  2. Jul 8, 2013 at 8:14 PM
    #2202
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not on zero they don't
  3. Jul 8, 2013 at 8:19 PM
    #2203
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    884s should be roughly 2". I am not positive on nitros vs 5100s. The difference would be the location of the coil seat on the shock, i believe it is the same or at least very close, although it seems some people claim a little more lift with 5100s, but lift heights can be subjective. How people measure, how high the truck sat before the lift, things like that can effect measurements. So its hard to tell you exactly how much lift you will get. Nitros vs bilsteins will be about the same. Benefits of going with OME are the shocks are valved to be paired with OME coils, some vedors claim there can be warranty issues when you pair 5100s with OME coils, the trim packer (lean spacer) works with OME only. Which is a advantage if you want small top plate spacers as well as a lean spacer. Advantages of 5100s are a longer extended length, so less likely to top out the shock and they are cheaper.
  4. Jul 8, 2013 at 8:22 PM
    #2204
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    Correct but he didn't say at zero so I assumed he was asking in general. That's why I said at certain settings they may be different.
  5. Jul 8, 2013 at 8:22 PM
    #2205
    YOTA LOVER
    NH
    Silence! The OZ has spoken.
  6. Jul 8, 2013 at 8:23 PM
    #2206
    Texas Taco
    Texas Taco Well-Known Member
    U.S.
    2016 TRD OR DC 4x4 QS
    Icon stage 4 w/RXT leaf pack and shocks, Icon hydraulic bump stops, LT285/75R16 BFG KO2s, 30" Rigid light bar, HIDs, and window tinting. More to come...
    Is there a lean spacer that will work with the 5100/OME spring setup?
  7. Jul 8, 2013 at 8:25 PM
    #2207
    evanmb31
    evan
    connecticut
    09 trd off road
    Yes, 1/4" top plate spacer. But say you are going for a full 3" lift. You would want top plate spacers on both sides. So 1/4" passanger, 1/2" driver, but 1/2" top plate spacer requires longer studs, so more parts more work.
  8. Jul 8, 2013 at 8:28 PM
    #2208
    YOTA LOVER
    NH
    It's a gamble chasing away lean like that IMO. Could end up leaning on the PS. I'd stick with the trim packer on the nitro shock and keep the TP spacers the same.
  9. Jul 8, 2013 at 8:29 PM
    #2209
    OZ-T
    Peter North
    British Columbia
    The question was for a 5100 shock / OME coil set up
  10. Jul 8, 2013 at 8:30 PM
    #2210
    YOTA LOVER
    NH
    I know. I think the answer could easily be deduced from my answer.
    I.E., stick with the nitros.
  11. Jul 8, 2013 at 8:33 PM
    #2211
    evanmb31
    evan
    connecticut
    09 trd off road
    I think the trim packer is 5mm, which is just under 1/4", and they essentially do the same thing as small top plate spacers, just different ends of the coils. But i agree on doing OME with the trim packer, but IMO there are better reasons to pair OME coils vs. 5100s. Even though i still have some drivers side lean with the trim packer and a "+" dakar pack on the drivers side.
  12. Jul 8, 2013 at 8:39 PM
    #2212
    YOTA LOVER
    NH
    I thought the trim packer preloaded the coil :notsure: I didn't bother installing it.
    The TP spacers do not, as they sit on top of the entire strut.
    After measuring I know I have lean, it just doesn't seem noticeable.
  13. Jul 8, 2013 at 8:39 PM
    #2213
    OZ-T
    Peter North
    British Columbia
    Should have installed the trim packer ^^^
  14. Jul 8, 2013 at 8:46 PM
    #2214
    YOTA LOVER
    NH
    Meh. Doesn't bug me. I should remeasure though with the 1/4" spacers and sway removed now that everything has had a chance to settle.
  15. Jul 8, 2013 at 8:48 PM
    #2215
    evanmb31
    evan
    connecticut
    09 trd off road
    Ya i guess it does preload the coil. So ya not the same as top plate spacers.
  16. Jul 8, 2013 at 10:32 PM
    #2216
    Texas Taco
    U.S.
  17. Jul 9, 2013 at 3:31 AM
    #2217
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I still had about 1/4" lean even with the trim packer installed (and a + dakar on the driver's side). Not bad but it doesn't completely get rid of the lean. I doubt the tiny amount of pre-load the trim packer gives you affects the ride at all.
  18. Jul 9, 2013 at 3:42 AM
    #2218
    YOTA LOVER
    NH
  19. Jul 9, 2013 at 5:14 AM
    #2219
    Texas Taco
    U.S.
  20. Jul 9, 2013 at 5:55 AM
    #2220
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Did you get new UCA's?
