Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 18, 2013 at 2:27 PM
    #2681
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Yep, definitely. Enjoy!
  2. Sep 18, 2013 at 6:53 PM
    #2682
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    With all that weight be prepared to remove a leaf or order a set of top plate spacers. The front end will settle after a few weeks. I waited a few months before the rake drove me nuts.
  3. Sep 19, 2013 at 5:23 AM
    #2683
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Thanks for the tip :cheers:. See how it goes, I may be okay with some rake.
  4. Sep 19, 2013 at 6:38 AM
    #2684
    YOTA LOVER
    NH
    I was at 1.5" rake without a winch. 10mm spacer would have brought it back to 1", but I went with the 13mm and got the rake down to 1/2".
  5. Sep 19, 2013 at 9:59 AM
    #2685
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Sorry what do you mean 1.5" of rake. Does that mean there was 1.5" height (hub to fender) difference between the front and rear. Or were you level and the front end sagged 1.5"?
    sorry for the need of clarification
  6. Sep 19, 2013 at 11:26 AM
    #2686
    YOTA LOVER
    NH
    ^That
  7. Sep 19, 2013 at 11:55 AM
    #2687
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    okay that's not too bad then. I can handle that much rack. That's probably still less than stock ( I could go measure but too lazy right now :eek:)
    Thanks for the clarification
  8. Sep 19, 2013 at 1:05 PM
    #2688
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    So if I'm understanding correctly, some of y'all are running top plate spacers with 886s? I just ordered my 886/nitrochargers and got extended top studs just in case I don't get a full 3" after settling and want to add spacers. I'm a access cab with armor..
  9. Sep 19, 2013 at 1:11 PM
    #2689
    YOTA LOVER
    NH
    I am. Before and after top plate spacer numbers are in my build thread.
  10. Sep 19, 2013 at 5:17 PM
    #2690
    Digger2
    Digger2 Well-Known Member
    Ontario, Canada
    '08 Double Cab TRD
    ARB Deluxe bumper, Full OME HD lift kit with Dakars. Frame welded Crew Fab DOM rock rails,Custom full skid plates, tow points,Cab mount chop, 265/70R17 Duratracs, weather tech mats.Coming soon Camburg BJ UCA's, Warn ??? winch
    Hey fellas I've had my ome kit on for a couple of months now and just did the front hub to fender measurement drivers side is 22.5" and pass is 23.5". Truck is full of fuel and has arb bumper sliders and armor no winch yet. Coils are 886 with nitro shocks and no trim packer. Would a 1/4 spacer on drivers side help with the lean I have? Don't really want to pull spring apart to put in trim packer. Thanks.
  11. Sep 19, 2013 at 5:24 PM
    #2691
    YOTA LOVER
    NH
    Yup, spacer will fix you, but I feel something else is off.
    Did you put the rear leafs on their respective proper sides?
  12. Sep 19, 2013 at 5:51 PM
    #2692
    Digger2
    Ontario, Canada
    '08 Double Cab TRD
    Yup I put the dakars + on drivers side and - on pass. Both sides are roughly 24.5". I also run firestone ride rites in the daystar air bag saddles.
  13. Sep 19, 2013 at 5:55 PM
    #2693
    YOTA LOVER
    NH
    Go for the top plate spacer. 1/4" spacer will bolt right in and you'll sit much closer to level.
  14. Sep 19, 2013 at 5:57 PM
    #2694
    Digger2
    Ontario, Canada
    '08 Double Cab TRD
    Perfect Thanks Yota lover!
  15. Sep 19, 2013 at 6:57 PM
    #2695
    FluByU
    FluByU Well-Known Member
    How long to OME shocks typically last? I have 40K on mine and the Vegas heat seems to have done a number on them, not as good as they were. Whats the mileage everyone is averaging out of a set?
  16. Sep 19, 2013 at 7:39 PM
    #2696
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OME trim packer ?
  17. Sep 20, 2013 at 10:04 PM
    #2697
    YOTA LOVER
    NH
    Yeah bud, little bit of somethin' somethin' to preload the spring and help negate Taco lean.
  18. Sep 21, 2013 at 7:02 AM
    #2698
    jetta.the.hut
    jetta.the.hut B4nn3d
    Aren
    Aberdeen,NC
    2013 Access Cab Long Bed 4x4
    anyone running these and spindles? im building the wallet for maxtracs but want to keeps these too. should give me 6.5 to 7" of lift, then add a 2-3" block to my 2" AAL for the back. i've got the 885's
  19. Sep 21, 2013 at 7:13 AM
    #2699
    la0d0g
    running for the hills
    For crawling not hauling
    Cereal?
  20. Sep 21, 2013 at 8:13 AM
    #2700
    jetta.the.hut
    Aren
    Aberdeen,NC
    fo reals, i can get 4" on the bottom with the maxtrac's and 3" with my OME's
