Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 22, 2013 at 8:35 PM
    #2721
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Don't you have old 886's ?
    ie not 886x
  2. Sep 23, 2013 at 3:33 AM
    #2722
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    X
    A little stiff, but it's not that bad.
  3. Sep 23, 2013 at 5:45 AM
    #2723
    jetta.the.hut
    jetta.the.hut B4nn3d
    Aren
    Aberdeen,NC
    2013 Access Cab Long Bed 4x4
    not really if you think ahead you can keep yourself from doing it twice.
    once mine are in i dont ever want to remove them unless i add a Maxtrac.
    but then again i dont have 886's or a winch bumper so to each his own.
  4. Sep 23, 2013 at 7:27 AM
    #2724
    OZ-T
    Peter North
    British Columbia
    Adding 1/2" top plate spacers to 886x coils is dumb if you end up at well over 3" of front lift
  5. Sep 23, 2013 at 8:03 AM
    #2725
    YOTA LOVER
    NH
    I would agree that 2.5"-3" is optimal. It has been my experience that with plate steel armor (bumper and skid) even the 886x settle a lot. I waited a long time before I added the TP spacers to ensure the springs were settled, and at 1.5" of rake front to rear I had to address it.
  6. Sep 23, 2013 at 3:52 PM
    #2726
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    without a bumper/winch/skids up front, the ride is hella stiff...the front end doesn't give on any bumps...like driving without any suspension.
    with the bumper/winch/skids, it's hella smooth, a bit stiffer than stock compression but very "truck-feeling"
    i'll probably have to add a top plate spacer or machine a larger trim packer as my driver side is about 1/4" lower than my passenger side. My spare is also on the driver side, so once I move the load around, I might only need a 1/8" spacer or less.
  7. Sep 23, 2013 at 4:45 PM
    #2727
    YOTA LOVER
    NH
    It really didn't bother me before I added the armor. But, I did keep it on the asphalt knowing the ride would be much less forgiving.
  8. Sep 24, 2013 at 9:35 AM
    #2728
    luka
    Kailua, HI
    the road near my place is shit...they've been doing construction for almost 3 years and put off the paving until after its done. driving on the highway was pretty smooth without the armor, OME shocks ate up all the little bumps with ease.
    I drove without armor for ~4 months so It handled ok before, and much better after ;)
  9. Sep 25, 2013 at 5:17 PM
    #2729
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Anyone having any issue with there Dakar leafs clamp bolts rubbing the gas tank on the D/S?
  10. Sep 25, 2013 at 5:25 PM
    #2730
    OZ-T
    Peter North
    British Columbia
    No , lots of clearance
  11. Sep 26, 2013 at 2:00 PM
    #2731
    chyknees
    So Cal
    05 Tacoma TRD 4x4
    Not sure if I was referring to the right part. Here is a picture of where my Dakar leafs rub on the tank
  12. Sep 26, 2013 at 2:06 PM
    #2732
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Just checked mine....no rubbing. I was flexing them pretty good the other day too. Not sure why you don't have enough clearance.
  13. Sep 26, 2013 at 2:11 PM
    #2733
    OZ-T
    Peter North
    British Columbia
    That's odd
  14. Sep 26, 2013 at 2:12 PM
    #2734
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you jumpin it
  15. Sep 26, 2013 at 4:31 PM
    #2735
    chyknees
    So Cal
    05 Tacoma TRD 4x4
    Not sure either, but I will take a picture of the nut/bolt on the gas tank side, the clearance is close.
    haha. i wish. Truck is my DD and occasional off road, but nothing crazy.
  16. Sep 26, 2013 at 4:39 PM
    #2736
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    Anyone else have noisy nitrocharger sport shocks? I bought the complete OME kit from Wheelers about 5k miles ago and since first day of installing they've been noisy. I figured over time they would quiet down but that doesn't appear to be happening.
  17. Sep 26, 2013 at 5:03 PM
    #2737
    Bloom
    Bloom Well-Known Member
    NASCAR, North Carolina
    2011 BR DC TRD OR
    OME 885+Dakars, WeatherTech mats, EGR In Channel, PopNLock, Access LE, 3M tint and clear film paint protection, Sport grille, Amsoil, Zaino once in a while.
    Since I spent some time here studying before buying, I'd like to say thank you and add mine to the list of OME suspended Tacomas.
    Today, Tarheel 4WD in Charlotte installed a full OME suspension on my 2011 Tacoma. I'm a repeat customer now. They also installed an OME suspension on my beloved 1998 Tacoma and the difference was night and day remarkable, so I was hoping to repeat the magic on my 2011.
    I didn't think the 'After' picture would look that much different than than the 'Before' picture, especially with stock tires, but apparently size matters and a couple of inches more is hard not to notice. Much better!
    I need to find some level ground once it settles a bit, b/c the driver's side sits lower than the passenger side, but I'll wait a bit to see it that doesn't work itself out. Otherwise, the ride is a little better than the stock Off Road was and the cornering is much better.
    On the other hand, the driveline vibration accelerating from a stop before it shifts is more noticeable and annoying than before. I just read about that in T-SB-0249-12, so a trip to the dealer might solve the problem and who knows, maybe I can talk them into a deal on some new tires to go with the lift while I'm there.
    Thanks to the OP and all who posted to this thread! ARB owes you some referral $$ for selling another suspension for them.
  18. Sep 26, 2013 at 5:49 PM
    #2738
    OZ-T
    Peter North
    British Columbia
    Noisy how
  19. Sep 26, 2013 at 5:50 PM
    #2739
    bjboucher
    Brad
    San Antonio, Texas
    I responded to you in the TSB thread. Don't be surprised if the dealer laughs you out of the shop when you try and get the TSB done to a lifted truck. Especially since one of the major parts they replace is the leaf springs.
    Edit: Start looking into carrier bearing drop and axle shims for now. Hopefully that's all you need.
  20. Sep 26, 2013 at 6:19 PM
    #2740
    Fivespeed
    Tualatin, Oregon
    When going over speed bumps they make like a "woosh" noise.
