Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 16, 2014 at 10:47 AM
    #3361
    la0d0g
    running for the hills
    For crawling not hauling
    To be clear my statement was regarding having the diff drop and wheeling not regarding the CV angles.
    If I have the option of f'n up a CV or my diff, I'm going with the CV every time.
  2. Jan 16, 2014 at 11:07 AM
    #3362
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
  3. Jan 16, 2014 at 2:01 PM
    #3363
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I read an opinion somewhere that since it only tilts the differential, you may be moving some internals to areas that are no longer submerged in gear oil and could cause some undue wear. Not sure how far that argument got though.
  4. Jan 16, 2014 at 4:22 PM
    #3364
    Yotabilly
    The Bluegrass
    Anyone know how long it takes new coils to settle down to where they'll be?
    Mine have settled a half inch in a few days so far.
  5. Jan 16, 2014 at 5:30 PM
    #3365
    kaj21
    kaj21 Member
    Kyle
    Colorado
    2014 TRD Off-Road Access Cab 6spd
    TRD short shifter/shift knob, Alu-Cab topper, 4runner TRD Pro wheels, rear diff breather, Wet Okole seat covers, full set of RCI aluminum skid plates, RCI sliders, ECGS bushing, Icon Stage 3 front end with Delta-joint tubular UCA's, Icon RXT Stage 1 rear end with u-bolt flip.
    Hey Hunter thanks a ton for those thorough answers. It can get crazy tedious searching this site for the right answers. I hope to start buying the mods in the next month so I can get it ready for some fun this summer.
    I've done a little research on this and have heard the theory of it "tilting" rather than maintaing a level "drop". I guess I'll have to see how the build evolves and how the ride changes. Thanks for the help. I think the OME lift is first on my list of mods now!!!
  6. Jan 16, 2014 at 11:18 PM
    #3366
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    I'm glad I can help; paying it forward really. I've received so much guidance from this site it's amazing.
    I hadn't considered the differential drop as a possibly bad modification. It makes sense to me as to why this would be the case. Essentially the spaces create a lever arm (radius) that wasn't there before, which could amplify a force applied to the diff - from a rock or so forth. I plan to add armor; possibly sooner than I expected after discovering this. I can say that the diff drop only rotates the front diff. However, without completely disassembling the differential and analyzing the design, I can't comment on the possible premature wear as a result of a different internal oil level. If I had to guess though, I would assume that all of the rotating gears would throw oil all over everything anyways and it really wouldn't matter.
    Anyways, I am really happy with the OME lift. I love how the truck handles now, and I really appreciate running a set of 33" winter tires up here in Alaska. They have made a world of difference for my everyday driving off the mountain into work. I'm sure you will love it too once you get it on. Be sure to post pics for the rest of us!
    Hunter
  7. Jan 17, 2014 at 2:51 AM
    #3367
    Yotabilly
    The Bluegrass
    Again, I'm no expert, but it seemed the diff dropped straight down. The bolts when put back in were not at an angle. They were straight up and down. If there was a tilt seems like the bolts would have been off. IDK.
  8. Jan 17, 2014 at 7:05 AM
    #3368
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Here's the skinny on the DD. They became very popular on the Gen 1, and were more effective in reducing the angle on the CVs due to the way the 1st Gen diff was mounted. The train of thought followed that if they were so good on the 1st Gens, they've got to be good for the 2nd Gens. If you compare the way the two diffs are configured you'll see that the DD has much less effect on reducing the CV angles on the 2nd Gens, but still displaces the diff enough to put it in harms way (rocks and obstacles primarily, if not armored). I was a Gen 1 guy, so when I installed my lift the DD was a no-brainer. I didn't give it a second thought. For the 1-2 degrees it may give you back on the CVs, it may not be worth the risk. If I wasn't armored I'd have pulled it out a long time ago.
  9. Jan 17, 2014 at 9:26 AM
    #3369
    CVYota
    CVYota Damaged Goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Has anyone tried flipping the top overload on the dakars? I am getting a pack and a shakle flip, not sure what I am going to add/remove, waiting to see what hieght I will get. I always have a ton of work parts or camping equipment in the back.
  10. Jan 17, 2014 at 9:33 AM
    #3370
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Flip it to have it engage the pack earlier ?
  11. Jan 17, 2014 at 12:35 PM
    #3371
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    I was reading an older thread and it was mentioned as a way to maintain lift with extra weight but without the aal, not sure what it would really do, just wondered if anyone actually tried.
  12. Jan 17, 2014 at 2:51 PM
    #3372
    OZ-T
    Peter North
    British Columbia
    I believe it engages the pack at an earlier point , I haven't done it but would probably go the aal route myself
  13. Jan 17, 2014 at 3:02 PM
    #3373
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    That top overload is actually flat, I pulled it out and am just using the bottom shorter overload to gain more flex. It sits perfectly flat and has no negative arch despite what it looks like when installed. Flipping it would do literally nothing at all.
  14. Jan 17, 2014 at 3:46 PM
    #3374
    OZ-T
    Peter North
    British Columbia
    Yes , you are correct , it's the lower one that you can flip to engage the pack earlier , my bad
    Now I wanna find the article where I read that info
  15. Jan 17, 2014 at 5:35 PM
    #3375
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  16. Jan 18, 2014 at 6:26 AM
    #3376
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Wow, it looks curved in the pics.
    Ok I won't bother with it.
  17. Jan 18, 2014 at 2:49 PM
    #3377
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    This is my second tacoma lift,
    This was a full OME lift with 1.5 tsb add a leaf. Also dropped the diff.
    The lift went well
    Driving in 2wd is good
    When in 4 hi or 4 lo and turning either direction(past one full steering wheel rotation) the rear starts to "chirp" and lose traction. Granted this is testing on pavement only
    Is this only because I am on hard pavement?
    Trying to figure this out
    Thanks ahead of time
    2014 trd 4x4
    Ome coils 885 top plate spacer
    Diff drop
    Tsb aal
    265 bfg all terrain
  18. Jan 18, 2014 at 3:00 PM
    #3378
    evanmb31
    evan
    connecticut
    09 trd off road
    Yes it is because you are on pavement with good traction. You should not use 4x4 when you have good traction. You can if you are driving in a straight line, other than that you should only engage 4wheel when the road surface will allow the tires to break traction on slow tight turns. What you are doing is hard on the truck and you could possible break something. Especially in 4 low. Sounds like you might have even had the diff lock engaged which is another no-no
  19. Jan 18, 2014 at 7:48 PM
    #3379
    Traviste
    Travis
    Georgia
    Thanks for the heads up. I definitely was not driving up and down the streets just making sure everything engaged.
    Thanks again
    Pics to follow
  20. Jan 19, 2014 at 7:32 AM
    #3380
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
