Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 30, 2014 at 5:51 PM
    #3481
    99civ
    99civ Well-Known Member
    Edmonton
    06 TRD Sport
    OME 885x w/Dakars - HIDs - Husky Mudflaps - LED Dome/Map/Reverse Lights - Illuminated 4x4 switch
    Yea I believe the one here is more geared towards the rig rocket crowd anyways. So I guess its looking like $2300 from Cochrane Toyota.
  2. Jan 30, 2014 at 5:55 PM
    #3482
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You could try OUIPACK , they are in Quebec but are / were the ARB dealer in Canada , I heard a couple people post that they aren't bringing any more stuff in but they might have the set up you're looking at in stock
  3. Jan 30, 2014 at 6:07 PM
    #3483
    99civ
    Edmonton
    06 TRD Sport
    Yea I read somewhere they stopped supplying as of November 1 or something. Probably worth a call though.
  4. Jan 30, 2014 at 6:08 PM
    #3484
    OZ-T
    Peter North
    British Columbia
    Good luck
    FYI , you need a set of bushings for the Dakars unless Toytec is supplying them and get centre pin collars for the Dakars in case you need to use axle shims later
  5. Jan 30, 2014 at 6:15 PM
    #3485
    99civ
    Edmonton
    06 TRD Sport
  6. Jan 30, 2014 at 6:21 PM
    #3486
    OZ-T
    Peter North
    British Columbia
  7. Jan 30, 2014 at 6:35 PM
    #3487
    jimbo33l
    jimbo33l Tacodile.... Supreme
    Jimmy
    Baytown, TX
    12 DC Off Rd 4x4
    Ok I have question and i hope this is the correct area to post it, I know there are alot of "will this work?" suspension questions but i just want someone to double check me on what i believe i will need.
    I plan on going with the OME lift kit 885's in the front with the 1 1/2" add a leaf for the rear because i already have the 4 leaf stock.
    I dont want any spacers for on top of the lift but i do need the trim packer for driverside to fix tacolean right?
    Also im gonna skip on the diff drop because it does more bad then good from what ive read?
    Are there any drops that i would definately need?
    The 885s would give me 2-2.5" correct? And for that i would definately need uca's?
    I plan on going with 255/75/17 bfg km mud terrains for the tires. Could these fit on stock rims with some trimming? If not im going to get the konig 6 shooters because they have 4.5" of backspace.
    Any advice or suggestions would be greatly appreciated.. I am really still up in the air on the 884 vs 885
  8. Jan 31, 2014 at 1:14 AM
    #3488
    LuckyE34
    LuckyE34 Active Member
    I have bf Goodrich all terrains, 255/75/17 on mine now and they fit pretty good with and without the lift on. no trimming or anything. So I don't see why they wouldn't. I'm still learning about the Tacoma lifts as I go. Much luck tho
  9. Jan 31, 2014 at 4:45 AM
    #3489
    jimbo33l
    Jimmy
    Baytown, TX
    12 DC Off Rd 4x4
    Thanks for the response. They show to be narrower but 1.5 inch taller roughly. I think because this I am going to go with the 884s that give 2 inch. Do u run them on stock rims?
  10. Jan 31, 2014 at 5:15 AM
    #3490
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i was running the 255/75/17 KM1s for a while on my 09 before i got the lift on it. no rubbing at all on stock wheels. once you start messing with backspacing i dont know though.
  11. Jan 31, 2014 at 5:26 AM
    #3491
    jimbo33l
    Jimmy
    Baytown, TX
    12 DC Off Rd 4x4
    I would imagine it would do nothing but help by lowering the back space from 5.5 (stock) to 4.5 on the six shooters.
  12. Jan 31, 2014 at 6:46 AM
    #3492
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    My 2 cents is in red.
  13. Jan 31, 2014 at 7:02 AM
    #3493
    jimbo33l
    Jimmy
    Baytown, TX
    12 DC Off Rd 4x4
    Thank you for the response. I am just going with the aal for now I do plan to upgrade later along with UCA's just not right now. I don't do any serious off roading just looking for a level to stick some decent sized tires under.
  14. Jan 31, 2014 at 8:04 AM
    #3494
    vantacothoma
    vantacothoma Member
    I just bought the same OME kit but with TC ucas, for 2081, shipped to us mailbox picked it up and drove it back duty was 200. If u can talk to Kevin he helped me out, be sure to get the TW discount. Also just had some tires put on down there that I ordered from tire rack right to a shop in Blaine for 1050 duratracs 285/70/17 with 1.25 spacers from a local shop, fit great took of mud flaps almost zero rubbing now. TC ucas are unreal!
  15. Jan 31, 2014 at 8:08 AM
    #3495
    YOTA LOVER
    NH
    I almost went TC UCA, but then learned about "cheating" the setting on the LR UCA ball joint forward for more clearance between the tire and the back side of the fender. That, and the idea of road salt and gunk getting in the uniball was a huge turn-off.
  16. Jan 31, 2014 at 8:15 AM
    #3496
    OZ-T
    Peter North
    British Columbia
    I'm going to go ahead and point out that Vancouver is a wee bit closer to the border than Edmonton
  17. Jan 31, 2014 at 8:21 AM
    #3497
    YOTA LOVER
    NH
    :D
  18. Jan 31, 2014 at 8:52 AM
    #3498
    99civ
    Edmonton
    06 TRD Sport
    Yea I've done a couple parts runs down to Sweetgrass from Edmonton but it's a long ass day in the car and by the time tax and duties is paid along with fuel it would be more than just paying stealership prices. Plus I don't have a vehicle available to me other than my truck to pick everything up and that would be north of 200 bucks of fuel right there
  19. Feb 1, 2014 at 1:00 AM
    #3499
    LuckyE34
    I didn't on stock height and rims. And i don't now. With the lift and don't know the exact backspacing on the rims I purchased. I turn full to both sides all the time. And no issues. I haven't really gone wheeling but I will be more now.
  20. Feb 1, 2014 at 4:29 PM
    #3500
    99civ
    Edmonton
    06 TRD Sport
    So I picked up my lift today and everything looks great, hoping to install next weekend. Just had a quick question though I opened my box and found I had 1/2" top plate spacers installed on mine and was curious how much extra lift that gives? I cant for the life of me find it on here after searching
