Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 28, 2013 at 7:40 AM
    #341
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    take a peek at the coils/sway, you will for sure see marks from contact
  2. Jan 28, 2013 at 9:13 AM
    #342
    Southpaw447
    Southpaw447 Member
    Ron
    South Jersey
    2012 Toyota Tacoma
    3 Inch ReadyLift Kit, ATX Artillery Teflon 18" Wheels, Toyo ATII 285/65/18
    If I get the OME Lift with top spacer to give me 3 inches what size tires would I need for an 18 inch wheel without having to do a front cab mount chop? and what specs for the 18 inch wheel for example the backspacing and width 18x9?
  3. Jan 28, 2013 at 9:17 AM
    #343
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    No sway on mine. There are some marks where the UCA's are close to the coils. No biggie but if I can get rid of it that would be nice.
  4. Jan 28, 2013 at 9:20 AM
    #344
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Probably 275/65/18 is as big as you can go with minimal trimming. I think 4.5" back spacing
  5. Jan 28, 2013 at 9:24 AM
    #345
    Southpaw447
    Southpaw447 Member
    Ron
    South Jersey
    2012 Toyota Tacoma
    Would I be able to go with a bigger tire if I use 17 inch wheels?
  6. Jan 28, 2013 at 9:28 AM
    #346
    evanmb31
    evan
    connecticut
    09 trd off road
    Wheel size wont matter. You can go bigger but if you go up to a 285 there is more of a chance of having to do the cab mount chop. You could always go with tall skinnys if you just want a large diameter tire. I have heard less trimming with a 255/85/16 or 255/80/17, but you will need a skinny wheel also, like 7-8 inches wide...like stock wheels
  7. Jan 28, 2013 at 9:32 AM
    #347
    Southpaw447
    Southpaw447 Member
    Ron
    South Jersey
    2012 Toyota Tacoma
    ok I dont really want a skinny tire I would like it to stick out like an inch past fenders or around there
  8. Jan 28, 2013 at 9:37 AM
    #348
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Are you talking wider, taller or both?
    275/65/18 32.07 x 10.83
    Not sure if these would require a cab mount chop.
    285/70/17 32.71 x 11.22
    275/70/18 33.16 x 10.83
  9. Jan 28, 2013 at 9:39 AM
    #349
    evanmb31
    evan
    connecticut
    09 trd off road
    Just keep in mind, the farther the tire sticks out the more likely you are to rub the cab mount and the bottom of the fender flares. My tires stick out over an inch (i should get pictures) and i had to do the cab mount chop to avoid rubbing during normal driving, i also only have 2.5" of lift and your alignment also plays a role in determining if you will rub or not. Basicly of you go with 285/70/17 or an equivalent size you can not be sure how much rubbing you will have. If someone tells you that you wont have much trimming or that you wont have to do the cab mount chop because of the correct backspacing/offset and enough lift, they may be wrong, there is to many factors to know for sure. So either go with a smaller tire or be ready to trim if you have to.
  10. Jan 28, 2013 at 9:40 AM
    #350
    4Wheelin4Banger
    Randy
    No trim & still run mud flaps with 255/85/16 on 16"x7" 4.5"BS on mine with 3" lift.
  11. Jan 28, 2013 at 9:40 AM
    #351
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    back spacing will play a role and look at a 275/70/17. I would love to go with this size but I really want the duratracs and they don't make them this size. BFG AT/KO is though.
  12. Jan 28, 2013 at 9:53 AM
    #352
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    Hey dude, I'm in Cloverdale, which part of beautiful BC you in :turtleride:, I could use a local Tacoma expert buddy :canada:
  13. Jan 28, 2013 at 10:12 AM
    #353
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Hankook ATm is available in 275/70/17 as well
  14. Jan 28, 2013 at 10:13 AM
    #354
    OZ-T
    Peter North
    British Columbia
    I'm in the Islands
  15. Jan 28, 2013 at 10:15 AM
    #355
    waheed
    Waheed
    Vancouver
    Where did you get the relocate sway bar KIT?:rolleyes:
  16. Jan 28, 2013 at 10:16 AM
    #356
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    When was this happening? While flexing, turning, etc?
  17. Jan 28, 2013 at 10:18 AM
    #357
    waheed
    Waheed
    Vancouver
    Nice, I was thinking of taking a trip to Bamfield.....heard it's a nice 50K drive down some logging roads to get to this not very well known town....heard there are some nie beaches there?? Where do you recommend going to the Islands for some nice scenery and secluded beaches and off-roading :pccoffee:......been to Ucuelet, Parksville, Victoria, Campbell River, Port Hardy...
  18. Jan 28, 2013 at 10:20 AM
    #358
    OZ-T
    Peter North
    British Columbia
    Bamfield is nice , I fished Spring salmon out of there
  19. Jan 28, 2013 at 10:33 AM
    #359
    george2pak
    george2pak Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    I will not recommend a 9" rim. It will rub. This is the setup that I had :
    tires:285/75/16, rims:Moto Metal MO951 Black 16x9,-12mm Offset, and 4.5" Backspace and I hate it. It rub to much.
  20. Jan 28, 2013 at 10:43 AM
    #360
    Nicky Lam
    Nick
    I've got 285/70-17 with full 3" ome 885 lift up front, TC UCA, and 17x9 4.5 BS, -12 mm off set. Caster when it was at 1.4 degrees rubbed can mount, and little bit of the fender, only in reverse. After changing caster to 2.8 degrees, no rub anywhere, will probably rub if wheeled hard (which I would expected) ill find out soon enough
