Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Feb 26, 2014 at 8:07 AM
    #3701
    Washington
    Washington Well-Known Member
    Minot, ND
    15 Tacoma TRD off-road
    Stealth Custom Series- Stealth 6 wheels, 285/70-17 Goodyear Duratracs, Allpro stainless extended brake lines, Dakar rear leaf springs, Light racing upper control arms, OME 887 front coils, OME 90000 front struts, OME 60091 rear shocks, BPF front skid plate, CB radio, Shovel mount in bed rail, 30" LED light bar in front bumper, Rear Diff lock anytime relay mod, Diff breather mod
    What leaf pack are you thinking?
  2. Feb 26, 2014 at 8:12 AM
    #3702
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    To provide clarification on this, the 5160s have a shorter extended length vs the OME shocks, so you would actaully be getting less down travel running them. The only benefit of the 5160 is the resies, which is more of a shock fade thing. Basically if you don't do a lot of offroading and heat the shocks up the resies are pointless. Also the OME shocks were designed to be used with the Dakars, so compression and rebound is just right.
    Oh and they are not on back order that I know of.
  3. Feb 26, 2014 at 8:21 AM
    #3703
    Mr Salty
    Hermmy
    Lots of chrome
    To squeeze more down travel out of the Dakars running longer shocks you'll need to run longer brake lines and consider an extension for the e-brake lines as well. Also with longer shocks one must consider shock compressed length to ensure they are still hitting the bumps on up travel.
    Just throwing this out there... I've screwed with the rear of my truck many times and this is what I have learned from doing so.
  4. Feb 26, 2014 at 8:22 AM
    #3704
    Washington
    Minot, ND
    Ah I did not know they were shorter. Why are some folks switching from OME rears to bilstein 5100's? Are the 5100's longer?
    On the Toytec website they say the rear shocks are temporally unavailable or something like that.
  5. Feb 26, 2014 at 8:35 AM
    #3705
    Mr Salty
    Hermmy
    Lots of chrome
    Standard 5100s are shorter, the extended length 5100 one are too long; compressed legth becomes a problem with them. For those tossing these in I suspect they didn't cycle their suspension to figure this out. If running longer bumps to accomodate for longer collapse length, they are likely gaining no more travel with them.
  6. Feb 26, 2014 at 8:48 AM
    #3706
    Washington
    Minot, ND
    Well, I sure am glad I asked. I will be sticking to the OME shocks for the rear, which is good because it will save me some cash.
    What's a good rear leaf pack that will only give a 3" lift and not add towing or hauling capacity like OZ was saying?
  7. Feb 26, 2014 at 11:02 AM
    #3707
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    The AllPro leaf pack will get you the lift, still increase capacity over stock, yet is designed to be more flexible for offroad.
  8. Feb 26, 2014 at 11:39 AM
    #3708
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The Allpro expedition pack is just as stiff as the Dakars , no ?
  9. Feb 26, 2014 at 11:47 AM
    #3709
    YOTA LOVER
    NH
    Standard pack, buddy
    "All-Pro Standard Duty Leaf Springs Improve your Tacoma's suspension performance and gain lift for tire clearance and long travel with All-Pro Standard Duty leaf springs! The 2005+ Tacoma 3" lift springs mount in the original spring hangers. They feature a special torque leaf to reduce axle wrap. The 11-leaf pack provides a smooth, progressive spring rate, while extended u-straps and teflon friction pads improve performance. The military wrap at the non-shackle eye provides the durability to take years of punishment."
  10. Feb 26, 2014 at 12:33 PM
    #3710
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    I just ordered the Dakar Leaf spring pack for my truck!
  11. Feb 26, 2014 at 1:35 PM
    #3711
    OZ-T
    Peter North
    British Columbia
    Dakar
  12. Feb 26, 2014 at 1:36 PM
    #3712
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  13. Feb 26, 2014 at 1:49 PM
    #3713
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    :facepalm:
    What bumpstops do most of you guys go with? I am getting the AP Flip Kit and I am not sure if I need $200 bumpstops.
    ohh and what bushings did you order? Regular toyota ones?
  14. Feb 26, 2014 at 2:14 PM
    #3714
    Mr Salty
    Hermmy
    Lots of chrome
    I have experience with both packs, the AP standards and Dakars, both give about 3".
    Both are great packs but I honestly like the Dakars more and here’s why...
    The AP packs did do good in the dirt over the bigger rolling bumps (better than the Dakars), but I found them to be a bit too stiff on the road.
    The Dakars, IMO, do better on the road and when I needed to tow something they support the weight better thanks the overloads.
    Now again they are both great packs, but I just honestly like the versatility of the Dakars and therefore setteled with them over the AP packs.
    So if looking to run the truck hard in the dirt hitting bigger bumps, not wash-board stuff, go with the AP standards. If not doing that much offroading and need a pack that’s a bit more versatile, the Dakars seem to work better.
    NOTE: Both packs were run with about 100 lbs of weight in the bed at all times, so keep this in mind as well.
    This is just my review of both, but yeah both great options for rear lift.
  15. Feb 26, 2014 at 4:31 PM
    #3715
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Will be pulling the trigger on the full OME setup soonish, 886s up front with Dakars rear and OME shocks all around.
    Lets assume I'm going to put new UCAs in as well as do a u-bolt flip, bumpstops, and extended break lines in the rear.
    How long should a couple of mechanically inclined people that have never torn a Tacoma apart expect to spend doing such a thing?
  16. Feb 26, 2014 at 4:39 PM
    #3716
    99civ
    99civ Well-Known Member
    Edmonton
    06 TRD Sport
    OME 885x w/Dakars - HIDs - Husky Mudflaps - LED Dome/Map/Reverse Lights - Illuminated 4x4 switch
    I'm in the same situation and personally I'm not expecting much more than 3 hours, barring any major setbacks, at a leisurely pace. Mind you I got mine all pre assembled so its as easy as taking the old junk out and new stuff right back in.
  17. Feb 26, 2014 at 4:55 PM
    #3717
    HHogrider
    HHogrider Well-Known Member
    Mark
    Lexington, KY
    11 Tacoma Sport Pyrite Mica
    Tint, ARE Z-Series Cap, Yakima rack on cap, ROLA basket, SCS Stealth 6 Matte Gunmetal with full size spare, 285 Terra Grappler, OME lift (885's with Top Plate Spacers, full DAKARS, Carrier bearing drop, stainless extended rear brake lines, BORLA cat back exhaust, color matched All-Pro rear bumper
    Good move
  18. Feb 26, 2014 at 5:06 PM
    #3718
    HHogrider
    Mark
    Lexington, KY
    And then they were "Donahoe". I'd have changed my name too
  19. Feb 26, 2014 at 5:42 PM
    #3719
    YOTA LOVER
    NH
    Two people who have their act together, all of the right tools and parts, and are fairly motivated... 8 hours maximum is my best guess.
    I'm chuckling a little bit, but only at your optimism. You'll easily spend an hour torquing all of the bolts to spec, and then rechecking to make sure you didn't miss one. Nothing's that hard about the install, but things like wrestling leaf packs or moving the jack stands from from to rear takes time. You got a pit crew lined up?
  20. Feb 26, 2014 at 6:32 PM
    #3720
    99civ
    Edmonton
    06 TRD Sport
    Na just a nicely equipped shop. And note the "barring major setbacks" part, I'm fully expecting some parts to be a pain in the ass haha. Just in theory swapping parts shouldn't take that long but I guess 3 hours is a little over zealous since nothing ever goes according to plan
