Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 7, 2014 at 5:18 PM
    #3881
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    If you get the right aftermarket UCAs you might not need a cab chop, the adjustments can move the tire far enough. But if they added spacers to the wheels, that may be why they didnt need to trim.
  2. Mar 7, 2014 at 6:15 PM
    #3882
    InducedComa
    InducedComa Well-Known Member
    Paul
    Northern VA
    13 TRD Sport DCLB
    OME Nitrocharger shocks, 885x Springs with Toytec 3/4 inch spacer, LR UCA's, DAKAR Leaf Springs, Line-X'd Avid Offroad Step Bars, Pop-N-Lock Power Tailgate Lock, Truxedo TruXport Roll-Up Tonneau
    I have 265 70 17s with spidertrax on my stock sport wheels with the ome 885's w/ spacers on nitrochargers and dakars and I rub while backing up with my 265's on. I havent trimmed anything. I also run LR UCAs and have my caster set at 2.4-2.5
  3. Mar 8, 2014 at 6:06 AM
    #3883
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You are probably rubbing BECAUSE of the spacers. I have that exact size tire and lift with no spacers and I don't rub at all. Been off roading several times with it too and no rubbing at full stuff either. Unless you just like the look, i'd take the spacers off.
  4. Mar 8, 2014 at 11:00 AM
    #3884
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Spacers alleviate touching UCA or frame. They increase the chances of rubbing on the outside edges of the tires.
  5. Mar 8, 2014 at 12:07 PM
    #3885
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    I have 17in ATX Crawl w/ 265/75/17 Nitto Terra Grappler
    I had to take the front mudflap off and trim a very small amount. I just ordered my OME kit and will be putting 285s. I am sure some trimming will be required if not a cab mount chop. I have seen some that don't need it and some that do but we shall see. My BS is 4.5"
  6. Mar 8, 2014 at 12:26 PM
    #3886
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Never heard of a 265/75/17
  7. Mar 8, 2014 at 2:48 PM
    #3887
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    whoops 275/70/17
  8. Mar 8, 2014 at 2:49 PM
    #3888
    OZ-T
    Peter North
    British Columbia
    I run 275/70/17 on stock Sport alloys , no rub , flaps on
  9. Mar 8, 2014 at 2:57 PM
    #3889
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Okay I must not be explaining this clearly. 285s wont touch the frame and no one chops that part. The part that has to get chopped is the body mount. You will hit the body mount more with wheel spaces. Depending on the wheel.
    I will go take pictures because this is getting too difficult to explain via text.
  10. Mar 8, 2014 at 8:01 PM
    #3890
    Chaz84
    Chaz84 Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    After ~4 weeks of reading and researching for the ideal solution to my needs, I feel this is likely the best place to ask questions. Following the death (mother rear-ended on interstate :/... She's alright, Taco saved her life) of my '97 Rhino-lined tank of a Taco, I found a '09 blk trd or 4x4 with only 18k on her... Older man owned it, never been off-road..... My new project, gotta get her ready.
    So, my dilemma:
    The front sits 1.5" low on the passenger front and 2" on the driver's.
    According to the VIN#, no tsb's for its production number so non tsb rear, look solid and zero rust.
    For mileage reasons, I only intend to run 265/75r16 BFG at's once these crap trail ta's are done (yes, it's a '09 w factory tires haha)
    I have a 68lb winch mount on the way and will be adding my old M8000 to the new truck shortly... Guessing ~110 lbs w shackles etc. Note the link, in love with this mount! US Offroad!!!!
    http://www.tacomaworld.com/forum/group-buys/314386-2005-2011-winch-mount-bumper.html#post8142363
    I am certain I need a .25" top plate spacer for driver's lean.
    I, unlike some, basically love how the factory TRD OR suspension feels. Although I have not had the opportunity to really push it off road (just light riding on trails <20mph), it seems ample for my needs... Graduate student stuck in city only getting home to 500ac farm once every month or two.
    I would like to keep the feel/ride of the truck as close to stock as possible while keeping .5-1" of rake with the added weight of the winch and mount. Spacers are out bc this needs to be a solid mechanical upgrade, not a possible Achilles heel. (yes, I do drive the shit out of my vehicles on occasion... Like H2O in floorboards, 150ft of cable, and a John Deere 5500 4x4 to get me out of bad decisions kinda thing).
    That being said, I suppose I am not completely against a small spacer lift considering my minimal lift goals, but just doesn't seem right to me when new coils are $160... I'm open to thoughts on top plate/preload combos etc., but don't want more than 1.5" in front with winch weight.
    From a budget, functionality, and longevity standpoint, replacing the coils seems to be my best option. I almost ordered the Eibachs earlier this week, but stopped myself bc I had not researched OME enough. I am now convinced that they may be too stiff and maybe a .5" low. This puts me between the 883's and 884's.
    I understand the 883's are 1.5" higher and 884's are 2" higher; however, I have seen several posts where guys with 4x4 dblcb tacos only got 1" out of 883's (I need a true 1.5" bc winch will bring it down ~.25")... I am not sure if my winch setup will be enough weight to effect the 883's to the point of needing 884's.
    My stock trd bilsteins are essentially new and I would like to utilize them until replacement is necessary. Will they only work with the 883 length?? Does anyone have experience with the difference in actual mounted height between the 883 and 884? Ride difference? Will stock length billies even work with 884's? Any advice is appreciated fellas, Thanks!!
    Go Dawgs
  11. Mar 9, 2014 at 7:26 AM
    #3891
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    884s will work on stock shocks, but will wear them out. IMO with a winch and bumper you will need 885s on nitrochargers. blisten 5100 shocks will work but some people don't like the parings of ome coils on blisten shocks.
  12. Mar 9, 2014 at 10:18 AM
    #3892
    Chaz84
    Dr. Chase
    GA
    Thanks for the input and apologies if I jumped into a conversation there fellas. Mount should be ready to install w/in 1.5-2 wks and want to do front suspension at the same time.
    Reply:
    Well, the reason I was looking at 884's was ome has them listed at 2" and increased weight handling of 110lbs, which is right around where I'll be. 885's are about the same as the Eibachs, just a tad longer I believe. Afraid they'd be too stiff.
  13. Mar 9, 2014 at 4:36 PM
    #3893
    Chaz84
    Dr. Chase
    GA
    I have that fear, but am under the impression that 883's would have pretty low risk of this.
    Maybe this is all speculation until the winch is mounted and see how the stock suspension rides/sits?... Was just wanting to knock it out at once if could get solid advice from experience.
  14. Mar 9, 2014 at 8:12 PM
    #3894
    808leo
    808leo Well-Known Member
    Kapolei, Oahu
    ‘21 super white dcsb 4wd
    5100 max setting, 285/70/17 ko2, FN 6 shooter, Subaru/kicker tweeters, JBL BassPro sub, nfabs, LED lights exterior/interior.
    I had the same issue.. In reverse I rubbed on that front bumper mud guard flap thing. I removed it and rubbing gone :D
  15. Mar 10, 2014 at 5:56 AM
    #3895
    06taco
    06taco Well-Known Member
    Brendan
    South Jersey
    08 4x4 4-door TRD Sport
    *TRD Supercharger *3" OME lift kit *Dakar rear leaf springs *Total Chaos UCA *TJM T15 Plate Bumper *TJM Stealth 9000 winch
    Does anyone know the overall length of an OME front strut vs. a Bilstein 5100?
  16. Mar 10, 2014 at 6:11 AM
    #3896
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    How heavy is your winch mount? I have 885s and sit at around1.25-1.5" with about 200# hanging on the front. And run 265/75r16. My front isn't stiff at all. la0d0g ran 884s for a while with a winch and aluminum bumper. You might check his build out.
  17. Mar 10, 2014 at 6:18 AM
    #3897
    LowerBost
    LowerBost Well-Known Member
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
    Old Man Emu Lift w/ Dakars and Billsteins, K&N Intake, Throttle Body Space, Front Bull Bar, Side Rails, Painted Stock Rims, Bilstein 5100 Front Shocks, Third Brake Light Cover, Satoshi Grill Mod, BHLM Mod
    I got a quick question here. I was pulling off the old leafs on my 09' this weekend and I released the bolts on each end of the leaf springs. There still feels to be some pressure on the leafs as the bolts were pretty tight getting out. Is there a way to release this pressure on the shackles there? I have jack stand under the rear of the truck by the tailgate to support the back.
  18. Mar 10, 2014 at 10:58 AM
    #3898
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    I have seen several people say it is needed and several say it is not. Who actually has the full 3" OME lift with Dakars without extended rear brake lines and what are your experiences? Headstrong Off-road told me they are not necessary. I just want more info than a few people chiming in "yes" or "no" like I have seen on most of the threads.
    Thanks,
    Simon
  19. Mar 10, 2014 at 11:08 AM
    #3899
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    You only need them if you fully flex out your suspension. When you reach full droop there could be a problem. The Cheap option is creating a spacer where the brake line bracket is on the axle. I have seen people use a bunch of washers and a longer bolt.
  20. Mar 10, 2014 at 12:35 PM
    #3900
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    Anyone here recommend bump stops to help with front rubbage? While offroad my fronts rub on the fender flares and I'm thinking I may need to decrease up travel. I run around with sway bar removed and it's just the 3" OME kit with 1/4" spacer. I've done CMC, clipped the ends of the fender flares, aaaaand removed most of the black inner liner.
    Edit: Also have adjusted caster and moved the wheels forward a bit in relation to the TC ucas and have done the hammer mod on the pinch welds.
