Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Mar 20, 2014 at 1:12 PM
    #4081
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    255 miles ?
    so same as me , 255 miles = 411 km
  2. Mar 20, 2014 at 1:17 PM
    #4082
    la0d0g
    running for the hills
    For crawling not hauling
    886s and Dakars. 315s and a little bit of armor.
    Yes, miles. I noticed we were about the same.
  3. Mar 20, 2014 at 1:34 PM
    #4083
    99civ
    99civ Well-Known Member
    Edmonton
    06 TRD Sport
    OME 885x w/Dakars - HIDs - Husky Mudflaps - LED Dome/Map/Reverse Lights - Illuminated 4x4 switch
    Hmm little worse than expected then haha. I was getting around 450km over the winter and right around 500 in warmer months. I'm down a quarter tank after filling up yesterday :/
  4. Mar 20, 2014 at 1:38 PM
    #4084
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Hopefully I will get at least mid point of those. I can live with that.
  5. Mar 20, 2014 at 1:38 PM
    #4085
    99civ
    Edmonton
    06 TRD Sport
    Those numbers were pre lift btw. I'm just hoping I can hang around the 450 mark
  6. Mar 20, 2014 at 2:13 PM
    #4086
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Hey guys, can someone explain to me the new 887x coils? How much lift do you get with double cab short bed 4.0. Does anyone have them on there truck? Thanks
  7. Mar 20, 2014 at 2:15 PM
    #4087
    OZ-T
    Peter North
    British Columbia
    2 3/4 - 3"
    There are a couple guys running them
  8. Mar 20, 2014 at 2:51 PM
    #4088
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    So I just ready that in many cases a lift does not increase the ground clearance. I dont see how that could be. is this BS or am I just not seeing it.
  9. Mar 20, 2014 at 2:54 PM
    #4089
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    a drop bracket lift does not increase clearance.
  10. Mar 20, 2014 at 2:58 PM
    #4090
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    So new shocks and springs will increase clearance. right?
  11. Mar 20, 2014 at 2:59 PM
    #4091
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Lift springs will like OME. Bilstein 5100's does as well by preloading your springs.
  12. Mar 20, 2014 at 3:01 PM
    #4092
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Not sure what part of CA you are in but Headstrong and Downsouth is like next day delivery.
  13. Mar 20, 2014 at 3:02 PM
    #4093
    OZ-T
    Peter North
    British Columbia
    Sure you don't mean tire clearance instead of ground clearance ?
  14. Mar 20, 2014 at 3:05 PM
    #4094
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    Lifts don't increase ground clearance, but they allow for bigger tires which DO increase ground clearance. If you think about it, the lowest part under your truck (solid axle) is still at the same height after a suspension lift
  15. Mar 20, 2014 at 3:06 PM
    #4095
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    I already have all my parts ready to go, just got worried when i read that. now you have put me at eas, thank you. I will have my 5100s and leaf pack installed by the end of this week.
    I understand that i will be able to fit bigger tires and that the axle wont be higher, im more worried about the rest of the body.
  16. Mar 20, 2014 at 3:14 PM
    #4096
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    So it seems that what i thought of as clearance is just slightly different then what the true meaning is.
  17. Mar 20, 2014 at 3:23 PM
    #4097
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The right lift increases suspension travel. Ground clearance is from ground to lowest part of the vehicle whatever that may be (probably axle or shock mounts). When you lift your suspension, it allows for bigger tires at times and bigger tires increases your ground clearance.
  18. Mar 20, 2014 at 3:30 PM
    #4098
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    I see, ok thank you for the help. time to get some bigger tires.
  19. Mar 20, 2014 at 4:19 PM
    #4099
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Installed my ome lift today. This is a bad picture as I was on uneven ground. pehejavu_9595f2df7a92bfaca77542dd669d40ec71209b2c.jpg
  20. Mar 20, 2014 at 5:22 PM
    #4100
    OZ-T
    Peter North
    British Columbia
    Looks good to me
