Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Apr 24, 2014 at 8:36 PM
    #4441
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Mine lasted less than 4 years. Not really sure when they went out. But I did some horrendous things to them.
  2. Apr 24, 2014 at 10:42 PM
    #4442
    Avex
    Avex Well-Known Member
    Alex
    PNW
    I saw your truck at the Lynnwood Buffalo Wild Wings today!
  3. Apr 25, 2014 at 4:31 AM
    #4443
    Onurnez
    Onurnez Well-Known Member
    Richmond, Virginia
    2008 Toyota Tacoma
    Fog Light Anytime Mod, LED dome and Map, Alpine Head unit, w/ Alpine door replacements, De-badged/De-Flapped, Anzo Black Headlights, Anzo Black Tail lights, Satoshi by Homer, Full OME Kit, LR UCA's Black interior dash parts, UltraGauge, Custom Decals By RuggedT, TRD Exhaust, Volant CAI, Weathertech Rainguards, Weathertech Floormats, Blueinstinct Center and door handle covers, Tacoma Bed Mat, 17x9 Fuel Kranks, 285/70/17, Window Tint: 5% back/35% front, Powerslot Rotors, Redline hood strut, 14'' Black Billet Antenna, LED Bed Light Mod, 100k mile mod
    Does this look about right:
    OME Complete Suspension Kit for 05+ Toyota Tacoma
    OME885X coils
    OME Nitrocharger sport front struts
    OME Nitrocharger sport rear shocks
    OME Dakar Leaf packs
    OME u-bolts
    OME trim packer
    OME driveshaft spacer
    Bushings and sleeves for shackle side of leaf pack
    Shipped to Chesterfield, VA
    Total = $1260.40
  4. Apr 25, 2014 at 4:55 AM
    #4444
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    That's a good deal, especially shipped at that price. I would look into extended rear brake lines as well. You're probably going to want UCAs at some point too. Center collar pins as we talked about in the last few posts as well are a good idea to add before install.
  5. Apr 25, 2014 at 7:55 AM
    #4445
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    Nice! I was up that way for work. There was a Ford Raptor parked nearby too, I was jelly.....
    :cool:
  6. Apr 25, 2014 at 11:39 AM
    #4446
    scollins
    Scott
    Renton WA
    Post-lift issues to be sorted:
    1.) Take-off shudder: I've had TOS since day one, but it seems a little worse now with the OME lift on.
    2.) Driveline vibrations, mostly from 15MPH to 35MPH when accelerating with partial throttle, or slowing down (off the throttle.) If I accelerate quickly (which increases pinion angle from torque twist/axle wrap), the vibrations are gone. Once above 30-35 MPH, the driveline is pretty smooth and vibration free
    I do have the FK29 kit installed, and no axle shims. I need to get under the truck and take some driveline angle measurements to determine which way to go (larger carrier bearing drop, like StreetTaco's version) or axle shims, or both.
  7. Apr 25, 2014 at 1:39 PM
    #4447
    madmex
    madmex Well-Known Member
    Frank
    TX
    '14 TRD Sport 4x4 DCLB
    Hey guys just finished installing the full OME kit with Dakars and was wondering if I'm going to need a sway bar relocate kit? Sway bar looks good but won't know after driving it for a while. Also what do you think about new bump stops? need them or hold off??
  8. Apr 26, 2014 at 5:50 AM
    #4448
    bjboucher
    Brad
    San Antonio, Texas
    Are you sure the drive line vibes aren't from the front differential? Try putting it in 4x4 and see if they go away. http://www.tacomaworld.com/forum/2n...nt-differential-bearing-vibration-thread.html
  9. Apr 26, 2014 at 5:52 AM
    #4449
    bjboucher
    Brad
    San Antonio, Texas
    Sway bar relocate necessity seems to be hit or miss. Some folks have issues with the coils hitting it, some don't. I installed one just in case, was cheap and easy. You don't really NEED new bumps from what I've been told. I'm still on stock.
  10. Apr 26, 2014 at 7:13 PM
    #4450
    scollins
    Scott
    Renton WA
  11. Apr 27, 2014 at 10:08 AM
    #4451
    bjboucher
    Brad
    San Antonio, Texas
    Read through that thread.....it happens pretty quick with a lift. Be ready for it. I need to replace mine, just haven't gotten around to it yet. I'm at about 25,000, started noticing it around 24,000.
  12. Apr 28, 2014 at 12:32 PM
    #4452
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    Just installed the OME kit with Dakar packs over the weekend.
    What are people doing for rear shocks to maximize droop? I have the Nitrocharger Sports and these shocks fully extend out with only two inches of droop on the leaf packs....
  13. Apr 29, 2014 at 8:22 PM
    #4453
    usaftaco4x4
    usaftaco4x4 Active Member
    Dean
    Spokane, WA
    08 Reg Cab 4x4
    BS 3in Spacer lift in front and blocks in back that i need to get rid of.
    I am trying to replace the junk spacer/block kit the previous owner had installed. Looking into the OME kit. Front: 885 coils with Nitrocharger Sport shocks, Rear: Dakar leaf spring with Nitrocharger shocks. With that setup, will i need to buy an AAL to keep my lift i have on it now or will the Dakar's/Nitrochargers do the same thing? Also, should i just throw on new UCA's since i wil have it torn apart? I know most say you dont need them unless you go over 3", but what are the advantages of replacing them now?
  14. Apr 29, 2014 at 8:49 PM
    #4454
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dakars will give 3" of lift on a reg cab
  15. Apr 30, 2014 at 12:01 AM
    #4455
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    Anyone know the gains up front with the 887's and 888's. Ive been thinking this way lately, someone correct me if I'm being a brotarded.
  16. Apr 30, 2014 at 12:07 AM
    #4456
    OZ-T
    Peter North
    British Columbia
    A few guys are running 887's and getting 3" , haven't heard of anybody trying the 888's yet
  17. Apr 30, 2014 at 7:57 AM
    #4457
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Very interesting.
    885's. 395 mm spring = 63.5 mm additional lift 2.5"
    887's. 400 mm spring = 76.2 mm additional lift 3.0"
    888's. 405 mm spring = 88.9 mm additional lift 3.5" (Theoretical)
    So is the excess coil length similar to using a top plate spacer in regards to The 2x relationship? ie: 1/4" top plate nets you 1/2". Could some one explain this to me, otherwise Im going to continue think of it as Taco Voodoo
  18. Apr 30, 2014 at 1:22 PM
    #4458
    Joben
    Joben Well-Known Member
    Wilmington, DE
    06 TRD Sport, Speedway Blue
    Just got the truck back from the shop today....
    Lessons learned, do the suspension sooner then later.....195k on the truck compounded the problems with install.
    And praise baby Jesus I decided to have a shop do it, it would have been a nightmare to do this on jack stands.
    LCA's had to be cut out, needed to be replaced.
    All in all couldn't be happier with the ride quality vs. stock. Stance is perfect with the 885's and 1/4" top plate. I'll post pics as soon as the monsoon blows through...
  19. Apr 30, 2014 at 5:44 PM
    #4459
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I'm running 887's and Dakar rears I got almost exactly 3" in the front and a little over in the back.
    My before and after numbers read like so:
    Before - After
    Driver front: 20 5/8 - 23 5/16
    Pass front: 20 7/16 - 23 3/8
    Driver rear: 21 5/16 - 24 3/8
    Pass rear: 21 1/4 - 24 1/2
    This is after about 500 miles and some mild offroading to help settle.
  20. Apr 30, 2014 at 6:25 PM
    #4460
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Good to hear, and nice looking rig. I think that will be what i go with.
    888's are prob a bad idea. Maybe not if a guy was gonna put a bumper on without a winch. Interesting thought, but im a noob still.
    That did clear my head a bit.
    (5mm) of extra spring = about 13mm of lift. half inch
    (10mm) of top plate =about 13 to 16mm of lift (per Wheelers)
    Seem about right?
