Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jun 10, 2014 at 10:18 PM
    #4681
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    True. I'm already to far in to cheap out now anyway. Are they all the same or are there any brands that stand out?
  2. Jun 10, 2014 at 10:23 PM
    #4682
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's pretty basic , I got the Toytec ones
  3. Jun 10, 2014 at 10:50 PM
    #4683
    Seantoobs
    Seantoobs Well-Known Member
    2011 4x4 Tundra and 1985 Toyota Extra cab
    5100's on Tundra and the Whole enchilada with extra guac on the 85
    Gentlemen
    Been reading this post for a while. If you don't mind can you help me choose a leaf spring for my setup. I am trying to determine if would be best rouse dakars or all pro leafs
    Note:
    1. I am a 4wd access cab 5 speed 4 cyl
    2. I have about 120-150 lbs of skids and sliders
    3. I have Ome 885 springs and n182 and 9000 shocks already
    4. Only using trim packer no spacer
    5. I would rather sit level
    6. Only real weight is camping equip at 300 lb once a mo.
    7. Going with 255/85/16's
    Also no matter which spring should I remove the third leaf to help on comfort and/ or flex and be level?
    Thanks for your input!
    Sean
  4. Jun 10, 2014 at 10:58 PM
    #4684
    OZ-T
    Peter North
    British Columbia
    All pro standards or expos ?
  5. Jun 11, 2014 at 7:13 AM
    #4685
    Seantoobs
    Thanks forgot to specify either one really but Probably standards
  6. Jun 11, 2014 at 7:27 AM
    #4686
    OZ-T
    Peter North
    British Columbia
    Only 300lbs once a month ? You would be fine with the AP standards
  7. Jun 11, 2014 at 7:36 AM
    #4687
    Seantoobs
    Thanks I was thinking Dakars might be overkill.
  8. Jun 11, 2014 at 8:27 AM
    #4688
    OZ-T
    Peter North
    British Columbia
    You would have a pretty stiff ride with them unloaded most of the time
  9. Jun 11, 2014 at 12:20 PM
    #4689
    seakayaker32
    seakayaker32 Well-Known Member
    Richard
    Peoria IL
    Tacoma TRD Off Road DCSB
    TRD CAI, Anytime Locker Mod. Modified Doug Thorley Pipe Bomb exhaust (tail pipe cut off just past the rear axle). All Pro winch bumper w/Tuff Stuff Xtreme 12500lbs winch (don't knock it it was free) All Pro IFS skid plate Custom Transfer Case skid plate Old Man Emu lift Desert products chromoly uniball UCAs Rear Differential breather Mod. Front differential drop kit. Satoshi Grill Bushwhacker Fender Flares Wilschur VT series Tiregate Softopper SOS offroad concept sliders w/kick out. Cobra 29 CB
    Thanks for the info. Turns out I don't have the AAL. Just ordered a set, so that should solve the prob.
  10. Jun 11, 2014 at 5:27 PM
    #4690
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Anyone have torque specs for the front and rear suspension?
  11. Jun 12, 2014 at 5:16 AM
    #4691
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    OME uses the stock suspension torque specs.
    Front shocks/struts lower bolts 101 ft*lbf
    Front shocks/struts upper 3 nuts 47 ft*lbf
    (If your re-using your stock top plate: top center nut 22ft*lbf)
    Upper ball joint 80 ft*lbf (align up to 60 degrees further for cotter pin)
    Upper control arm bolt 87 ft*lbf
    Rear shock lower bolt 53 ft*lbf
    Leaf spring front hanger pin bolt 116 ft*lbf
    Shackle pin mounting bolts (top and bottom) 67 ft*lbf
    OME U bolts 93 ft*lbf
    Stock U bolts 90 ft*lbf
  12. Jun 12, 2014 at 5:42 AM
    #4692
    dispatch55126
    MN
    2004 Xtracab SR5
    Awesome, thanks.
  13. Jun 13, 2014 at 1:57 PM
    #4693
    MD11Fr8Dog
    MD11Fr8Dog Well-Known Member
    Sean
    NC
    Double Cab
    Snorkle, sliders, OME suspension, CBI Bushmaster rear bumper/swing out tirre carrier, Addicted Off Road tubed front bumper
    Double thanks!
  14. Jun 13, 2014 at 1:59 PM
    #4694
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    So a group of us on the East Coast are planning a trip to Moab next year. (You may have seen the thread). Hopefully I can make it but I was just wondering if anyone has ran their OME setup there. I usually only see mid or long travel setups in pics.
  15. Jun 13, 2014 at 2:35 PM
    #4695
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    theres so many ome setups in moab dude... hell im running ome up front still:)
  16. Jun 13, 2014 at 6:15 PM
    #4696
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    well I am not going to worry about it then and rock my OME. I can put money towards other items needed to get prepared like a locker, bumper, skids etc.
  17. Jun 14, 2014 at 11:46 AM
    #4697
    the paulinator
    the paulinator Member
    Durango, CO
    14 SR5
    I am looking for some advice on which version of the OME suspension to put on a 2014 Double Cab Long Bed. I pull a 14 ft construction trailer +/- 3500#. I also take the truck camping with a Phoenix slide in camper +/- 900 #. Previously, on my 2006 I used ride right air bags to level the load. The only problem with this set up was that I totally destroyed the stock leafs under the bags. The go round I want to use the OME suspension first and the seen if I need the air bags to level out the load. My question is do I need the heavy duty set up or the medium. The OME website only addresses needing the heavy duty when you add a winch and heavy front bumper,which I will not do.
  18. Jun 14, 2014 at 12:50 PM
    #4698
    OZ-T
    Peter North
    British Columbia
    Medium
    885's and Dakars
  19. Jun 14, 2014 at 1:37 PM
    #4699
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    The heavy duty and medium are only talking about the fronts anyway, so like OZ said.....go with medium. The rear leafs are the same no matter the configuration. The Dakars should be able to handle the 900 pounds quite easily.
  20. Jun 14, 2014 at 2:15 PM
    #4700
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    For a 1st Gen it is absolutely worth it. The load capacity of the standard Dakars is the same as the stock leaves and that is just not enough for a truck that is consistently carrying extra weight with things like a heavy rear bumper, tire carrier, extra fuel, extra water, heavy skid plates and then adding camping gear for multiple days. Before I added the extra leaf to mine I was constantly hitting the bumpstops when the truck was loaded.
    It may be slightly different for the 2nd Gens but I think the extra leaf is still a worthwhile mod. It is not going to hurt. Ride quality is not affected, flex is not affected but load capacity is vastly improved.
