Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jan 31, 2013 at 6:45 AM
    #461
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  2. Jan 31, 2013 at 7:18 AM
    #462
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Heretic !
  3. Jan 31, 2013 at 7:21 AM
    #463
    Pugga
    Massachusetts
    Doode, I'm running Eibachs.... It's your Bible, not mine. I'm praying to a different color coil :p
  4. Jan 31, 2013 at 8:55 AM
    #464
    OZ-T
    Peter North
    British Columbia
    Heathen
  5. Jan 31, 2013 at 9:14 AM
    #465
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    For you guys running OME kits did you end up putting that 5mm trim packer in or not?
  6. Jan 31, 2013 at 9:15 AM
    #466
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Yep and still have some taco lean. Dont leave it out
  7. Jan 31, 2013 at 9:16 AM
    #467
    OZ-T
    Peter North
    British Columbia
    Yes , use the trim packer
  8. Jan 31, 2013 at 9:20 AM
    #468
    Pugga
    Massachusetts
    Races
  9. Jan 31, 2013 at 9:20 AM
    #469
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    this is why I got rid of my Pro Comp springs that the dealer had installed. I think the pro comps are 720lbs!!!! Like a rock on and off road.
    Love my 885 set up now.
  10. Jan 31, 2013 at 9:23 AM
    #470
    AllMountainToy
    Northern California
    Do you plan on keeping the Dakars complete or removing the 3rd leaf in the pack. If you do remove it, it is an amazing ride AND I went back to factory ubolts since they are long enough and didn't want to cut the new U bolts after doing this.
  11. Jan 31, 2013 at 9:27 AM
    #471
    evanmb31
    evan
    connecticut
    09 trd off road
    Hmm, i didnt realize the factory u-bolts would work after the 3rd leaf is removed. Mine are hanging pretty low but ill probably get a flip kit eventually, i might even put the leaf back in eventually. Plus aftermarket ones seem much stronger.
  12. Jan 31, 2013 at 9:28 AM
    #472
    evanmb31
    evan
    connecticut
    09 trd off road
    I want to know why one of my dakars packs had a O on it where the + or - ushually is. Anyone else have that?
  13. Jan 31, 2013 at 9:33 AM
    #473
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    I have decided on OME set up with wheelers 3 leaf AAL, I cant decide if i should go with the regular and 60019 shocks or HD with N182's I don't haul anything in the bed bud do pull a 4500# boat in the summer time? I am looking for the best street ride possible
  14. Jan 31, 2013 at 9:33 AM
    #474
    OZ-T
    Peter North
    British Columbia
    " + " means the pack is slightly above factory spec , 0 is at factory spec
  15. Jan 31, 2013 at 9:33 AM
    #475
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Oh how I wish that was left on my porch....
    I want the full OME setup with leafs etc... My thing is I really want a full 3" or maybe even 3.25-3.5"... Would the 5100's at .85 work ok an give me that little extra I want? I have searched and haven't found much on that setup. TRDATER has 3.25 I the from with his Icon's and looks sick! I will also be doing UCA's. if really like to run some 285/70/17's and figured that would be less trimming.
  16. Jan 31, 2013 at 9:34 AM
    #476
    OZ-T
    Peter North
    British Columbia
    Most cush ride would be the N182's and the standard Wheelers 3 leaf
  17. Jan 31, 2013 at 9:36 AM
    #477
    evanmb31
    evan
    connecticut
    09 trd off road
    Thats what i figured, but like the picture above some leaf packs don't have a +,-, or 0. I would assume that also means factory spec.
    Edit: nevermind, the sticker is covering where the marking would be
  18. Jan 31, 2013 at 9:36 AM
    #478
    OZ-T
    Peter North
    British Columbia
    4x4 or prerunner ?
  19. Jan 31, 2013 at 9:36 AM
    #479
    OZ-T
    Peter North
    British Columbia
    I believe that is correct
    My packs have no markings
  20. Jan 31, 2013 at 9:37 AM
    #480
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    So run the 90000 in the front and N182's in the rear that seems like a good solution. And i hope no issues with hauling the boat with regular AAl's
