Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 1, 2014 at 9:57 PM
    #4801
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Lol , no harm no foul
  2. Jul 1, 2014 at 10:05 PM
    #4802
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    It feels really good. Firm but not hard. I get my alignment tomorrow so I'll take off the kids gloves and test it then.
    Edit:
    On the LR UCA's, you don't have to grease the ball joint right?
    Does anyone know what the drive shaft angles are supposed to be relative to each other?
  3. Jul 2, 2014 at 8:43 AM
    #4803
    ajwhlr04
    ajwhlr04 Well-Known Member
    Aaron
    Woodland Hills, CA
    2007 Tacoma 4x4 Double Cab 6MT
    I just ordered my OME kit and LR UCA's!!
    Can someone post a picture or two of what the center pin collar is for? I'm not getting it. I've gathered that it's to shim the axle to a new angle, but if you have to take the bolt out of the leaf pack to remove the collar and replace with shim, what's the point?
    Will the CV boot ribs rub against one another? I'm wondering if I'll need to do the CV boot mod so they don't rupture over time.
  4. Jul 2, 2014 at 8:45 AM
    #4804
    OZ-T
    Peter North
    British Columbia
    The centre pin collar extends the head of the pin so you can add or remove the slide in style axle shims
  5. Jul 2, 2014 at 8:47 AM
    #4805
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    the collar allows you to "slide" a shim in so you don't have to take everything apart like you stated above. Using shims of this nature.
    http://www.jegs.com/p/Specialty-Products/SPC-Truck-Axle-Shims/1982009/10002/-1
  6. Jul 2, 2014 at 9:40 AM
    #4806
    ajwhlr04
    Aaron
    Woodland Hills, CA
  7. Jul 2, 2014 at 9:41 AM
    #4807
    ajwhlr04
    Aaron
    Woodland Hills, CA
    Ok, only the slide in style. Got it.
  8. Jul 2, 2014 at 9:49 AM
    #4808
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    It'll make more sense when you take your apart but this first pic shows shims installed on a leaf pack with the center pin in the middle:
    This pic shows a spring perch. The center pin goes into the hole in the middle to "center" the spring on the axle:
  9. Jul 2, 2014 at 9:53 AM
    #4809
    OZ-T
    Peter North
    British Columbia
    Those aren't slide in shims and don't require the collars
  10. Jul 2, 2014 at 10:04 AM
    #4810
    ajwhlr04
    Aaron
    Woodland Hills, CA
    Ok that's what I thought. Thanks guys.
  11. Jul 2, 2014 at 10:22 AM
    #4811
    ajwhlr04
    Aaron
    Woodland Hills, CA
    Yeah, I get it. Thanks for the clarification though. :)
    I'll probably install the collars, install the lift, measure drive line angles, and machine some custom shims at work and slide them in (or buy them if whole degree increment shims will work, since they come in degree increments).
    I've been lurking for awhile, and see a lot of people just try shims, carrier drop, etc. without measuring angles first, which is trial and error. That works if you have the time, but I'd rather only have to do it once and be done, so I'm going to measure and get it right the first time.
  12. Jul 2, 2014 at 10:32 AM
    #4812
    ajwhlr04
    Aaron
    Woodland Hills, CA
    ^^Good point. I'll do that.
  13. Jul 2, 2014 at 12:14 PM
    #4813
    Joben
    Joben Well-Known Member
    Wilmington, DE
    06 TRD Sport, Speedway Blue
    Before
    After
    Thought I'd throw this out there, put 2,000 miles on the kit since install, working out nicely. Thanks to this thread for all the guidance.
  14. Jul 2, 2014 at 12:16 PM
    #4814
    TMP1207
    TMP1207 What does this mean anyway?
    Eastern, NC
    '09 DCSB TRD
    Currently 2.5" ProComp Spacer Lift w/ TSB Leaf
    What's with the shims? I'm about to order the OME complete kit with dakars...am I going to have use a shim? Sorry to sound like I have no clue but i don't. Thought I had it all figured out and then I read about shims and drive line angles...
    What does this achieve and is it necessary for ordinary driving/light off road?
  15. Jul 2, 2014 at 12:23 PM
    #4815
    OZ-T
    Peter North
    British Columbia
    Shims are a corrective measure used to fix driveline vibrations that you may or may not get after lifting , adding the centre pin collars allows you to add shims later without needing to remove the centre pin
  16. Jul 2, 2014 at 12:30 PM
    #4816
    Madjik_Man
    Colorado Front Range
    edit:
    question answered
  17. Jul 2, 2014 at 2:10 PM
    #4817
    ajwhlr04
    Aaron
    Woodland Hills, CA
    These guys have it right. You get drive line vibration when the transmission output shaft and the differential input shaft aren't parallel (or within some specified tolerance). Note that they can, and will, have an offset, but can still be parallel. It gets a little more complex with the 3rd u-joint on the double cab but that's basically it. It's all due to the nature of the u-joint. A constant angular velocity on one side doesn't give you a constant velocity on the other side of the joint, but if you have two u-joints like most drive shafts (which should theoretically have equal and opposite angles), the velocity phase difference between the two joints cancels out, so you get constant rotation speed at the differential. If the angles don't match, the phase doesn't completely cancel out, giving you a vibration.
    This can be exaggerated by the fact that all physical things have multiple resonant frequencies, including a drive shaft. So you may only notice vibrations at certain speeds; when the rotational speed of the shaft matches it's resonant frequency(s).
    Not that you care about any of the background...I just think it's cool. I'm geeky like that. :rolleyes: Maybe I should do a write-up about this. I could even measure the resonant frequencies of the drive shafts / carrier bearing to correlate with the speeds that people experience the vibration. It will take a bit of time, but is there any interest?
    I just bought the full OME kit too. The bottom line is that you shouldn't second guess doing the lift because of the potential vibrations. You may or may not have them, but there's a lot of people here that have had it, and fixed it.
  18. Jul 2, 2014 at 3:37 PM
    #4818
    smith945
    smith945 Member
    South East Massachusetts
    2012 Off Road Dbl. cab
    OME at the corners Dakars at the back, Total Chaos UCA's, Leer cap, Pelfreybilt battery cage
    Opinions please, with the help of a friend I started and completed my install of the full OME kit and TC UCA's. Should I immediately get it aligned or maybe drive for a day or two and let things settle. Maybe drive 15-20 miles in the next day or so.
  19. Jul 2, 2014 at 3:47 PM
    #4819
    la0d0g
    running for the hills
    For crawling not hauling
    Both time I lifted it I drove around for a couple days without getting it aligned, not intentionally but I just couldn't get in the shop. Worked out fine both times. I'm not sure how much settling is really going to happen over a couple days.
  20. Jul 2, 2014 at 4:45 PM
    #4820
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    I did a quick drive way alignment with the help of this thread, drove around for a week or so and then paid for the laser deal. Surprisingly, my home alignment wasn't too far off from where I wanted it.
