Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Jul 2, 2014 at 6:06 PM
    #4821
    smith945
    smith945 Member
    South East Massachusetts
    2012 Off Road Dbl. cab
    OME at the corners Dakars at the back, Total Chaos UCA's, Leer cap, Pelfreybilt battery cage
    Thanks for the quick replies, I guess I won't worry about it and I'll get it done after the holiday weekend.
  2. Jul 2, 2014 at 8:07 PM
    #4822
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Same experience here. Except I did the UCAs at the time and they were a bitch.
  3. Jul 2, 2014 at 8:08 PM
    #4823
    bjboucher
    Brad
    San Antonio, Texas
    Firestone here won't align lifted trucks. Pretty lame.
  4. Jul 3, 2014 at 4:13 AM
    #4824
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    That sucks. They didn't even ask if my truck was lifted. Only mentioned the alignment numbers were all over the place and asked if I hit a huge hole in the road. That's when I mentioned I worked on the truck. They didn't seem to mind.
    I know NTB has 1, 3, and 5 year alignment options. Maybe they'll align your truck?
  5. Jul 3, 2014 at 4:35 AM
    #4825
    bjboucher
    Brad
    San Antonio, Texas
    I found a shop that does it, was just pointing out that Firestone here in San Antonio won't do it. We have several locations and none of them will do it. They claim they can't guarantee it, some legal crap. I think they just know they're more likely to do multiple alignments on lifted trucks and don't want to lose money.
  6. Jul 3, 2014 at 5:39 AM
    #4826
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    exactly what they said to me here in Jax, FL. But then I went to tires plus and got the lifetime allignment, they did it and guess what? You can use your lifetime allignment from tires plus at any firestone location. Doesn't make sense ha
  7. Jul 3, 2014 at 6:51 AM
    #4827
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    This section was a huge help for me when working on my lift. I went with OME 885s in front (assembled), with OME shocks and an AAL (toytec) in the back. I decided to keep the stock UCAs since I'm more of a weekend warrior. While I was working in the back, I decided to swap the rear brake lines. It was my first time doing it, so it took a bit longer. I did the sway bar relocate kit as well. All in all, it was a fairly easy process. And I'm more than pleased with the results.
    Before
    Front driver 20 1/4
    Front passenger 20 1/2
    Rear driver 21 1/2
    Rear passenger 21 1/2
    After (I'll check the numbers again in 2 weeks after the suspension settles a bit)
    Front driver 23
    Front passenger 23
    Rear driver 23
    Rear passenger 23
    Before
    After
    Increase of 2.5" all around.
    Pics of work:
    After thoughts:
    I wish I had more knowledge on how to do brake lines and what to expect. Had a tough time trying to loosen the connections without stripping the nut.
    Make sure to double check the parts you loosened. When I first drove it to the alignment shop, I heard a thunking noise at time coming from the driver side wheel well. A day later I was able to check it and saw the sway bar link was a little loose. After tightening it, all was good.
  8. Jul 3, 2014 at 8:47 AM
    #4828
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    This happened to me on my 04 Tacoma after I installed Bilstein 5100's in the front. haha It took me a while to figure out what that clunking sound was...
  9. Jul 3, 2014 at 8:47 AM
    #4829
    gtokarski
    gtokarski Well-Known Member
    George
    Dublin, CA
    06 4x4 xtra cab silver
    OME 886, AAL, ARB Bumper, XRC8 Winch, Sony MEX-N5000BT, and one angry beagle.
    What you want is a flare nut wrench
    I bought a set a long time ago but I only use it when working on brake/hydraulic lines so its probably better to rent/borrow one in the future. Replacing the flare nuts is not fun if you round them off :frusty:
  10. Jul 3, 2014 at 10:05 AM
    #4830
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    This was brought to my attention after I had swapped the lines and was tightening the nuts. One of the guys who came over to help had them in his bag, but was busy working on the front end and forgot to mention it. Oh well. Lesson learned.
  11. Jul 3, 2014 at 2:42 PM
    #4831
    outside2ride
    outside2ride Member
    Jeff
    Colorado
    06 Tacoma TRD Sport work in progress
    Been lurking here absorbing all the info that I can. I pulled the trigger on the full OME setup (885x coils w/ top plate spacer 1/2" I believe (assembled), dakars in the rear). I made sure to get centere pin collars on the Dakars, got the CB drop, bushings for the Dakars already installed, LR UCA's, trim packer for taco lean, skipping the diff drop. I'm looking to add SS extended rear brake lines and probably a sway bar relocate as well. I'm an '06 Access Cab with topper and fair about of weight regularly in bed ~300-400lbs regularly. Minimal off-roading and daily driver, but only average ~ 8,000 miles per year and want the rig to be capable off-road if needed. I was looking for right at 3" of lift and a level look. No immediate plans for armor as of yet, but prob sliders in the near future. About to install in 2 weeks, so digging for info to make my first-time lift install as seamless as possible. I have a helper, most tools, and 3 days timeframe to get everything done. My question: what have I not thought of? Where should I search for good info/installation help? I have bjmoose's install thread and little else as of yet.
    Also, after lift install, I'm looking to go with 285/70/17 duratracs on method double standard 17"x8.5" with 4.72" backspacing and 0mm offset. Yes, I am expecting some trimming, but was hoping to get away without a CMC if possible? From all that I've read, CMC is hit or miss. Anything I've overlooked or something else I should consider? OZ, I've read nearly every post of yours and consider your opinions/experience very helpful. Thank you in advance, any/all advice is very helpful!
  12. Jul 3, 2014 at 4:51 PM
    #4832
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    You've done your homework my friend. I truly believe all the points are checked out. I strongly recommend the SS brake lines for the peace of mind. Do the sway bar relocate as well if you plan to keep it on. Again, you're just buying peace of mind here.
    For wheels, I am running a set of 17x8.5, 4.8in backspacing with LT285/70-17 KM2s. The only trim I have done so far is on the plastic fender flair. No evidence of rubbing on the cab mount, I keep knocking on wood.
    With the same setup on a Double Cab Long Bed, I am having a little bit of a rake, but with your weight in the bed it should not be that bad. Good thing with the Dakars, if you need it, Old Man Emu got you covered with the D29XL Add A Leaf option to handle the extra weight.
    And... Welcome to TW !!!
  13. Jul 3, 2014 at 6:10 PM
    #4833
    outside2ride
    outside2ride Member
    Jeff
    Colorado
    Thanks! I'm a little nervous about the install, but excited to have the satisfaction of doing it myself. So, I'll pick up some SS rear brake lines (any good suggestions where to get them? OCTaco's I've read are good), a sway bar relocate from Toytec, and need for a U-bolt flip kit? what's the benefit of it? Should I consider new bumpstops? Axel shims?
    When setting the LR UCAs, set to neutral and try to get 0 camber, 0 toe, 3.0 caster ideally? Would any adjustments here help to avoid a CMC with 285/70/17's? My main concern with a CMC is the tendency for rust afterward? (I live in the mtns in Colorado)
    Any good install threads besides bjmoose that I should also reference? Where can I find torque specs? I read that I should spray the Dakars and coils with Fluid Film or a Rust Cure Formula to prevent rust? Any bad reviews on Method Double Standard wheels? That might be all the noob questions for the night....thanks guys!
  14. Jul 3, 2014 at 6:15 PM
    #4834
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Somebody that does their own homework , how very refreshing
  15. Jul 3, 2014 at 6:27 PM
    #4835
    outside2ride
    outside2ride Member
    Jeff
    Colorado
    Ah, the stamp of approval...thank you. I've been doing alot of reading, hope I get it all right.
  16. Jul 3, 2014 at 10:06 PM
    #4836
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    I got my lines from OCTaco, good price and very fast shipping, despite the fact I am living across the border. The guy is very reliable.
    My alignment specs are also exactly as you mentioned... well at least when I got it out of the shop. Now since my last offroad trip... I am a little bit off again lol.
  17. Jul 4, 2014 at 3:14 PM
    #4837
    Madjik_Man
    Colorado Front Range
    I have a 1st gen...
    Are there specific torque specs for a full OME (881s, Dakars+AAL) kit? U-Bolts? Shock mounting bolts, etc?
    And after driving post-install, do I need to retighten bolts, etc after the suspension settles?
  18. Jul 4, 2014 at 3:36 PM
    #4838
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
  19. Jul 5, 2014 at 5:46 AM
    #4839
    MD11Fr8Dog
    MD11Fr8Dog Well-Known Member
    Sean
    NC
    Double Cab
    Snorkle, sliders, OME suspension, CBI Bushmaster rear bumper/swing out tirre carrier, Addicted Off Road tubed front bumper
    I used these, got them from TW, I think.
    OME uses the stock suspension torque specs.
    Front shocks/struts lower bolts 101 ft*lbf
    Front shocks/struts upper 3 nuts 47 ft*lbf
    (If your re-using your stock top plate: top center nut 22ft*lbf)
    Upper ball joint 80 ft*lbf (align up to 60 degrees further for cotter pin)
    Upper control arm bolt 87 ft*lbf
    Rear shock lower bolt 53 ft*lbf
    Leaf spring front hanger pin bolt 116 ft*lbf
    Shackle pin mounting bolts (top and bottom) 67 ft*lbf
    OME U bolts 93 ft*lbf
    Stock U bolts 90 ft*lbf
  20. Jul 5, 2014 at 2:39 PM
    #4840
    Madjik_Man
    Thank you gentlemen.
