Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 2, 2014 at 7:28 PM
    #5161
    DarthTarmac
    DarthTarmac Well-Known Member
    Craig
    Paducah KY
    Lifted, 33'd, and Murdered
    TRD Off-Road Package, Method Mesh 17x8.5 0 offset, Toyo Open Country AT2 285/70/17, Bilstein 5100 front and rear, OME 885, Wheeler's Progressive 3 leaf, OME Driveline Carrier Bearing Drop Kit, Depo black housed head lights, OEM 2011 TRD Sport grill color matched, Toyota accessory skid plate, bed linered rear bumper, black Kuat NV, Tepui Kukenam Sky RTT
    But why? Why is that better? Pardon my ignorance, I'm from the 4runner world and I'm not familiar with leaf springs.
  2. Sep 2, 2014 at 7:34 PM
    #5162
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do you ever load your truck , have a cap or tow ? or do you usually have an empty bed ?
  3. Sep 2, 2014 at 7:39 PM
    #5163
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
  4. Sep 2, 2014 at 7:40 PM
    #5164
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    I just went with the full ome kit from wheelers. Went with the 881 springs since I wanted as little lift as possible and have no plains for a bumper or winch.
    Very happy with how it rides now.
  5. Sep 2, 2014 at 7:54 PM
    #5165
    DarthTarmac
    Craig
    Paducah KY
    Good questions, sorry I left out some important details. I don't plan to put a cap on the bed, nor do I plan to do any off road bumpers. I might tow something small from time to time but nothing too heavy and I do have access to full size trucks if needed so towing is not a priority. Mostly used for my daily driver, some light off roading will be done, but no crawling. I might add a skid plate under it eventually but not full armor. Most of the time the bed will be empty, I will also have a hitch mounted bike rack on it that weighs about 40 pounds so I don't think that will affect the rear suspension any.
  6. Sep 2, 2014 at 7:57 PM
    #5166
    OZ-T
    Peter North
    British Columbia
    Skip the Dakars and get a progressive 3 leaf AAL or a leaf pack that isn't designed for heavy loads then
  7. Sep 2, 2014 at 8:01 PM
    #5167
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Anyone got a trim packer laying around that can get me measurements id and od of the hole. I'm sure I can find a stainless thick washer that will do the same.
  8. Sep 2, 2014 at 8:02 PM
    #5168
    OZ-T
    Peter North
    British Columbia
    Why didn't you order one ?
  9. Sep 2, 2014 at 8:05 PM
    #5169
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I struggled with this for a while, but ended up with the full OEM, dakars, and light racing UCAs.
    Some people will say that the OME shocks are valved for the OME springs, so they will produce a better ride. This may or may not be true. Plenty of people say they have OME springs and billies and enjoy the ride. I decided on the full OME setup because I carry a lot of weight in my bed (easily 400 lbs...more during hunting season). The Dakars handle the weight well. The AAL would have sagged quickly and they don't ride as well as a new leaf pack. Also, if I had put billies in the rear I would have had to replace them with a longer shock, like OME, if I went with the Dakars later. The standard billies that you would use with an AAL are too short for a Dakar leaf pack.
    Ultimately I felt the full OME was more suitable for my long term needs.
  10. Sep 2, 2014 at 8:09 PM
    #5170
    DarthTarmac
    Craig
    Paducah KY
    The one from wheeler's is 1.5 inch, would that put me nose high with the OME 885 springs up front? Does anyone make a 2 inch 3 leaf AAL?
  11. Sep 2, 2014 at 8:10 PM
    #5171
    OZ-T
    Peter North
    British Columbia
    You have 1 1/2 to 2" of rake stock no ?
  12. Sep 2, 2014 at 8:14 PM
    #5172
    cstallings
    Arkansas
    I think you can leave the overload in and it would be 2". Someone else may be able to verify this.
    Just measure the difference between your front and back right now then add the appropriate lifts you are looking at. Your suspension might have sagged some, so that is really the only way to tell for sure.
  13. Sep 2, 2014 at 8:18 PM
    #5173
    DarthTarmac
    Craig
    Paducah KY
    Seems like most people get 2.5 up front with the 885s, right? Not sure what the rake will look like with the new struts and springs. If the overload makes it a half inch higher, that would be great. Can anyone confirm?
  14. Sep 2, 2014 at 8:26 PM
    #5174
    OZ-T
    Peter North
    British Columbia
    You're not getting what I'm saying
    885's will give you about 2 1/2" lift up front
    If you have a 1 1/2" rake stock , then add 1 1/2" with an AAL you will still be 1/2" high in the rear
  15. Sep 2, 2014 at 8:28 PM
    #5175
    cstallings
    Arkansas
    I got about 2.5" with my 885s. use the trim packer or 1/4" spacer on the driver's side. My trim packer didn't fully correct my lean.
    You should have enough factoy rake that you won't be nose high. The extra 1/2 inch might help when towing or hauling something heavy. I hate being nose high when towing.
  16. Sep 2, 2014 at 8:33 PM
    #5176
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Didn't know they didn't come with it. I got the springs off a member here and a the struts from headstrong. I was thinking it just came with it.
  17. Sep 2, 2014 at 8:37 PM
    #5177
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    It says in your profile you're lifted, 33'd, and murdered. So if you're already lifted what is on your truck now? as far as rear end goes?
  18. Sep 3, 2014 at 4:35 AM
    #5178
    DarthTarmac
    Craig
    Paducah KY
    I haven't even got the truck yet, but I'm going to do this stuff as soon as I get it. It'll be stock when I get it. So I should go with billies, 5800s, progressive aal? That'll be about $700 compared the full ome kit at over $1100.
  19. Sep 3, 2014 at 8:29 AM
    #5179
    la0d0g
    running for the hills
    For crawling not hauling
  20. Sep 3, 2014 at 9:21 AM
    #5180
    DarthTarmac
    Craig
    Paducah KY
    Yeah. I work at the dealership, it's being traded in right now and I have first dibs on it. If I buy it I'm going to add the amount for the lift to the financing that's why I'm trying to figure out what to get.
