Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Sep 3, 2014 at 11:20 AM
    #5181
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    I'd go full ome, dakars ride so much better than aal. and since your financing that $400 over (I would guess) 60 months, it will be less than $10 a month.
    I've got 885s and 1.5 aal. truck has about 3/4 inch rake. Also toytec has 2" aal.
  2. Sep 3, 2014 at 11:40 AM
    #5182
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Have you ridden in a truck with Dakars and an empty bed ?
  3. Sep 3, 2014 at 12:00 PM
    #5183
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    My truck with dakars rides unloaded better than my wore out stock springs with a lift block.
  4. Sep 3, 2014 at 12:03 PM
    #5184
    jhcole
    jhcole Well-Known Member
    Hunter
    Birmingham, AL
    '15 DCSB 4x4 TRD-OR MGM
    ToyTec 3" w/ Bilstein 5100's
    Hey guys, new user here...
    Looking at buying a used Tacoma and have done a lot of research on OME combos but want to raise a few questions.
    The truck I'm looking at is a used 2013 Tacoma 4x4 SR5 Double Cab with:
    --ARB deluxe bull bar
    --ENGO winch
    --Daystar 2" leveling kit up front,
    --1" block & TSB Leaf Pack (4 leafs, 3 & 1 overload) in the rear
    I know the Daystar 2" with stock SR5 suspension in the front is not sufficient for the 200lbs+ hanging off the front now. I want to know the most affordable way I can get a decent setup up front (comfortable off road, will see very light off road use) and for the truck to sit level. I want to avoid messing with the rear right now if possible.
    If I go with 886's and 90000 OME Shocks, will it be front high?
    For affordability, would 886's and Bilstein 5100's set to 0" be ill-advised?
    Will I need a diff drop?
    Should I fear any of the infamous vibrations?
    Thanks for the help!
  5. Sep 3, 2014 at 12:39 PM
    #5185
    TheGoat
    Justin
    Greenville, SC
    No, had a Camper top on it. but stock springs wear out fast too, might as well address the problem while he's spending money. I've got 70k and my leafs already are seperating. The aal got them back into shape but won't hold them long.
  6. Sep 3, 2014 at 12:49 PM
    #5186
    J1Time
    J1Time That guy...
    Atlanta
    2014 Tacoma TRD Off Road 4x4
    If you never have your bed loaded and rarely if ever haul anything will dakars suck to use as a daily driver?
  7. Sep 3, 2014 at 12:56 PM
    #5187
    SWOreBowHunter
    SWOreBowHunter Well-Known Member
    Oregon
    '14 AC 4x4
    Front: 5100s and 884x Rear: Dakars and OME Nitrochargers
    No
  8. Sep 3, 2014 at 12:57 PM
    #5188
    OZ-T
    Peter North
    British Columbia
    Lift blocks suck , and I suggested a progressive 3 leaf AAL
    Apples and Oranges
  9. Sep 3, 2014 at 12:59 PM
    #5189
    OZ-T
    Peter North
    British Columbia
    They will be very stiff
  10. Sep 3, 2014 at 3:43 PM
    #5190
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    It's not that bad.
    You just has an old mans back.
  11. Sep 3, 2014 at 4:05 PM
    #5191
    OZ-T
    Peter North
    British Columbia
    I like the Dakars , but really , c'mon , unloaded they ride stiff , like no articulation
  12. Sep 3, 2014 at 4:16 PM
    #5192
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I have the Dakar leafs on my 08 DCSB and I drive 95% of the time with the bed empty. I've only had the setup on for 2 weeks now but so far, I can say this:
    - It does ride pretty stiff
    - If I go over a bump quickly...its kind of jaring. Meaning that it feels as though the leaf pack isn't really flexing much.
    - It rides Much better than the stock leafs + helper leaf setup I previously had.
    Hope this helps..... feel free to ask me anything else if it comes to you.
  13. Sep 3, 2014 at 4:45 PM
    #5193
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    True. I have extended 5100s back there and it rides like a dream with weight back there.
  14. Sep 3, 2014 at 4:58 PM
    #5194
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Since this is the OME thread, figured this question belongs here.
    On a DCLB with no weight up front, will the 884 coils give me a full 2" on 5100's?
    Also, if i add a winch with no plate bumper, will 885 coils support the weight and still give me 2"?
  15. Sep 3, 2014 at 5:08 PM
    #5195
    Gaunt596
    Matthew
    Central Maryland
    so 885's will give me 2" without any weight? Id love to go full boat OME but its just not in the budget. im also a weekend warrior, so the truck sees mostly street with an offroad trip or two now and then, hence the billy's. Also, in the back... if you throw an 3 Leaf AAL in, do you actually need longer shocks? ive been told that an AAL only increases ride height, so you don't need longer shocks.
  16. Sep 3, 2014 at 5:22 PM
    #5196
    Gaunt596
    Matthew
    Central Maryland
    Edit because that was stupid, of course it goes on sale at some point
  17. Sep 4, 2014 at 8:42 AM
    #5197
    EL JEFE 83
    EL JEFE 83 Well-Known Member
    Jeff
    Albuquerque NM
    2007 Tacoma TRD Supercharged!
    OME LIFT, 32'S, Super Charger, URD Pully, Banks Exhaust
    Can the dakar leaf packs be installed with stock ubolts?
  18. Sep 4, 2014 at 8:50 AM
    #5198
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Nope.
  19. Sep 4, 2014 at 8:54 AM
    #5199
    EL JEFE 83
    Jeff
    Albuquerque NM
    Thanks!
  20. Sep 4, 2014 at 10:53 AM
    #5200
    la0d0g
    running for the hills
    For crawling not hauling
    I carry ~100 lbs in my bed and love the dakars both on and off road.
