Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Oct 3, 2014 at 11:14 AM
    #5361
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Hey Ryan,
    I have pretty much the same set up as you. I have the 886 coils with the sport shocks. I did get aftermarket UCA (upper control arms) in order to get my alignment to spec. However this is not necessary, as some have gotten the alignment to spec. As for a diff drop, I do not have one, and they don't really do anything. I do however have a carrier bearing drop.
    As for install, if the springs are assembled your essentially just bolting them on. If the springs are not you may have to get a shop to assemble them for you since the 886's are pretty stiff.
    here is a video that gives a bit of insight for install. Removal of shocks and what not:
    https://www.youtube.com/watch?v=vkVLBOnAifc
    Hope this helps
  2. Oct 9, 2014 at 10:13 PM
    #5362
    MateoTorgy
    MateoTorgy Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    This is outstanding.
  3. Oct 10, 2014 at 12:22 AM
    #5363
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I've moved on from OME stuff.. but.. question..
    whats the measurement from center of hub to fender for 3" of lift with 285/70/17 tires?
    just curious as to where I'm at currently.
  4. Oct 10, 2014 at 12:32 AM
    #5364
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    23-23 1/2
  5. Oct 10, 2014 at 12:33 AM
    #5365
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I've personally asked ARB support and they confirm that unless you're going above what Dakar's do by some means, extended brake lines aren't necessary.
  6. Oct 10, 2014 at 12:34 AM
    #5366
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks OZ!
    didnt think you would be up. lol
    I'll double check tomorrow.. but I think I am there.
    thanks!
  7. Oct 10, 2014 at 12:37 AM
    #5367
    OZ-T
    Peter North
    British Columbia
    I just finished playing ps4 but it's past my bedtime , haha
  8. Oct 10, 2014 at 12:40 AM
    #5368
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahhh still hooked on that Last of Us huh??
    and I hear that..
  9. Oct 10, 2014 at 8:28 AM
    #5369
    OZ-T
    Peter North
    British Columbia
    I finished it on Normal , now I'm playing it again on Hard
  10. Oct 15, 2014 at 8:28 AM
    #5370
    woad3
    woad3 Member
    Hello everyone , I just bought a 2015 dclb sport. Before I go tearing stuff on my truck I just want to make sure I'm in the clear . I bought a complete ome kit 885 with sport shocks and Dakar. Also the shim for the driver side and driveline bearing drop kit. I've read quite a bit and I don't know if I'm ahead of where I was an hour ago. :-( will I be sitting fairly level with this set up? Also do I need to purchase anything else? I've read that diff drop kit is a waste, along with new uca and brake lines as long as I don't lift it more then 3"
    Thanks for all the help guys, -just a nervous guy
  11. Oct 15, 2014 at 8:40 AM
    #5371
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    You should still have rake. Don't rule out UCAs. I have a 2010 Sport DCLB and needed UCAs to get my caster in spec after jsut the 885s.
    Might consider installing center pin collars in case you need to run some shims.
  12. Oct 15, 2014 at 9:30 AM
    #5372
    woad3
    woad3 Member
    I'm super new at this stuff so excuse maybe these simple questions. How would I fix the rake? Also isn't the cb drop kit I got for the shims?
  13. Oct 15, 2014 at 6:27 PM
    #5373
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Just to let folks know HS has extended their sale on the complete OME kit.
    Check my signature out
  14. Oct 15, 2014 at 7:25 PM
    #5374
    OZ-T
    Peter North
    British Columbia
    1) raise the front or lower the rear
    2) the CB drop shims down the driveshaft carrier bearing ( CB )
  15. Oct 16, 2014 at 7:49 AM
    #5375
    BLKSR5TACO
    BLKSR5TACO Well-Known Member
    Craig
    Chesapeake, Va
    2021 Tacoma TRD Offroad 4x4 Cement W/Tech Package
    Tint / N-Fab Steps / ME-SO / Extang Bed Cover / TRD PRO Skid Plate
    Has anyone tried replacing just the shocks without adding lift. I only ask because my stock shocks are on their way out and I want to upgrade to a more solid shock set up. I was considering the 90021 fronts and 60091 rears since phasing out n182's. Can these be ran with stock springs? More people say ome ride better than billys and have far less issues with leaking shocks after few thousand miles.
  16. Oct 16, 2014 at 9:29 AM
    #5376
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    So I searched and could not find an easily accessible answer. I am considering the Dakars for an 09 DCSB with a Leer topper. My question is I have the topper on 95% of the time, and I have camping gear (100lbs) and a pup that is going to be ~200lbs. Should I get the D29XL springs for the extra weight (200 all the time up to 500-600) plus people? or will I be fine with the regular leaf pack. I will also be doing a U-bolt flip kit if that matters at all.
  17. Oct 16, 2014 at 11:19 AM
    #5377
    OZ-T
    Peter North
    British Columbia
    Depends how much lift you want , between my Leer cap and tools I run around with 450lbs of gear at all times with no issues on the stock Dakar pack
  18. Oct 16, 2014 at 12:03 PM
    #5378
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    Same here. I bought the extra leafs, but haven't had any need for them. Pretty impressed with the stock Dakar pack, actually. With my Leer cap and an honest 3 face cord of 1 year old hardwood spread between the truck and my 5x10 aluminum trailer, I've still got 2-3 inches of rear suspension travel before the bump stops.
  19. Oct 16, 2014 at 12:07 PM
    #5379
    GeoTaco
    Freeda Feltcher
    Denverish
    Car seats
    great, thanks guys, Just pulled the trigger on the standard pack
  20. Oct 16, 2014 at 11:14 PM
    #5380
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    So it looks like this is an issue between 1st and 2nd Gens, I ran stock Dakars with 300 lbs of gear on some rough dirt roads and I hit my bump stops more than once. I added the D6XL and now it feels like butter down the washboards with 200-500lbs in the back.
