Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Nov 3, 2014 at 1:25 PM
    #5421
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Yep, lots to figure out. I went straight for the LR UCA's with the 881's but others have kept the stock ones with no problems, they just give low caster. I switched to the 882's after the addition of the skids (bumper and skids only) but I think you could do it before. It might be slightly stiff until you add some more weight up front but it's a truck right :D
  2. Nov 4, 2014 at 6:37 AM
    #5422
    MoreTimeThanMoney
    MoreTimeThanMoney Member
    St. Louis
    07 TACO 4x4 DoubleCab
    I installed medium springs (OME 2885) and Sport struts (OME9000) - Easy part.
    I had to lower the Lower Control Arm (LCA) in order to remove the old strut and install the new application.
    I cannot raise the LCA to reconnect the 2 bolts by the ball joint. I instead raise the entire truck.
    I believe the new spring is preventing this. Any advice on how to resolve this problem would be greatly appreciated.
  3. Nov 4, 2014 at 9:06 AM
    #5423
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    I seem to recall using the spring compressors to assist a little at that point. But it's been a year and a half... Not going to be my problem when they swap everything over to my new frame and LCAs that come with it.
  4. Nov 4, 2014 at 12:21 PM
    #5424
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I'll just leave this here.
  5. Nov 4, 2014 at 12:57 PM
    #5425
    la0d0g
    running for the hills
    For crawling not hauling
    They look beef cake :eek:
  6. Nov 5, 2014 at 7:09 PM
    #5426
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    looks serious n legit
  7. Nov 5, 2014 at 9:11 PM
    #5427
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    is your shock fully compressed when installing it?
    what is the height of your spring prior to install?
    The usual problem would be getting the shock through the
    upper hole, not reattaching the lower control arm.
    [/QUOTE]
  8. Nov 5, 2014 at 9:38 PM
    #5428
    Cjanik
    Cjanik Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    drooooooool:drool:
  9. Nov 6, 2014 at 9:30 AM
    #5429
    MoreTimeThanMoney
    St. Louis
    No, I don't think the shock is fully compressed.
    Is that something that requires a special tool? Sorry, all this is a learning experience.
    Thank you.
  10. Nov 6, 2014 at 6:53 PM
    #5430
    Deercantseeme
    Deercantseeme Well-Known Member
    Massachusetts
    I just put new ome 884s and dakars on my single cab and now I'm getting some serious vibes around 60mph. It seems to almost go away when I let off the gas. Does anyone have advice on where to start to solve this problem?
  11. Nov 6, 2014 at 7:05 PM
    #5431
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Drive shaft. I had the same issue after 884's and a 2"AAL on a RC.Mine does it around 59mph to 63mph. A couple of members here posted that they flipped the driveshaft on a RC and it cured it.
    I've been meaning to do this, but I rarely drive 60mph around here. When I do I drive 64mph. I'll do it eventually.
  12. Nov 6, 2014 at 7:10 PM
    #5432
    Deercantseeme
    Massachusetts
    Hmm. I wonder if shims would help? Couldn't hurt to flip the driveshaft first just to see. I had no problems with just an add a leaf. Maybe the dakars lifted it just a bit more causing the vibes
  13. Nov 6, 2014 at 7:23 PM
    #5433
    Yotabilly
    The Bluegrass
    FWIW I have 2" AALs. Mine mellowed out some as the leafs settled. I'm planning on getting top plate spacers for the 884s and changing to Dakars in the back and going to a 255/85 this spring so I'm interested in your outcome with the vibe.
  14. Nov 6, 2014 at 7:26 PM
    #5434
    Deercantseeme
    Massachusetts
    From what I've read dakars don't settle too much so we'll see. I may try to flip my driveshaft this weekend and see what happens. I'll be sure to post my findings.
  15. Nov 13, 2014 at 3:26 PM
    #5435
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    This is for some with Dakars with Nitrochargers in the rear.
    Do the Dakars take up all the extension of the shocks or do the shocks still have a little down travel left in them?
  16. Nov 13, 2014 at 4:52 PM
    #5436
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Question....I just purchased a full OME suspension kit :D and was just wondering what is a respectful price to pay to have it installed? I know that this is a general question but I don't want to get hosed.
    I purchased, OME 885 Front Coil Springs, Nitro Charger Sport Front Shocks, Nitro charger Sport Rear Shocks, Light Racing Upper Control Arms, and Dakars. I am also getting the front coils pre-assembled with the 1/2" spacer and the 1/4" trim packer.
    Thoughts??
  17. Nov 15, 2014 at 4:18 PM
    #5437
    Hollywood22
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Really?? Nothing?? ^^
  18. Nov 15, 2014 at 5:33 PM
    #5438
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    If you bought them assembled and have a moderate assortment of your own tools, you can easily do this install yourself in under a day.
    I wouldn't want to pay a shop that has access to a lift more than 4 hours. Someone experienced with Tacomas could probably do it in 2.
  19. Nov 15, 2014 at 5:37 PM
    #5439
    Hollywood22
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Thanks man. I don't think I would be comfortable doing it myself. I will get some quotes from a couple reputable shops and see what the damage will be. Thanks.
  20. Nov 17, 2014 at 8:00 AM
    #5440
    dwaltdtx
    dwaltdtx Well-Known Member
    David
    DFW, TX
    I got 2 or 3 install quotes that ranged from 600 - 800(dealer). I ended up paying a friend less than half that and he said it took about 3 hours to complete.
