Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Nov 25, 2014 at 8:40 AM
    #5481
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Well after a year and 40k(plus) miles I will be getting rid of my OME shocks and struts. They did not hold up to the North East climate at all and totally rusted to shit. I have a 2010 Access Cab 4cyl 4x4 and the 886 coils I got have sagged quite a lot even with no extra weight added. Going with a custom set of Rock Krawler 2.625 coil overs in the front and a shock relocation in the rear with Rock Kralwer 2.0 emulsion shocks. If I didnt have to deal with snow and salt conditions I would say it would hold up ok but the fact that the coils have sagged that much has def ruined it for me as well
  2. Nov 25, 2014 at 9:52 AM
    #5482
    la0d0g
    running for the hills
    For crawling not hauling
    Were they older 886s or did you buy them new last year? Doesn't seem like the should sag that much with your setup.
  3. Nov 25, 2014 at 10:07 AM
    #5483
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Yep, just remove the 3rd leaf or ditch the longer overload, I've tried both. Ride is good with both methods and still supports weight. That’s the cool thing about these pack, very versatile packs. Both will put you at about 2” lift, maybe just under that after they settle.
  4. Nov 25, 2014 at 10:19 AM
    #5484
    jztacoma
    Upstate NY
    Semi Stockish
    I bought them new last year from Toytech Lifts. Tried to get a hold of ARB with all the issues I had and the only advice I got was to keep the suspension clean in the winter(which is a tad hard when its -20 out) If they didnt rust up I probably just swap the coils out.
  5. Nov 25, 2014 at 10:22 AM
    #5485
    BBBsti LTD
    BBBsti LTD Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    Should I expect a TRD OffRoad Dual can to sag with a new set of 885 coils with no extra weight?
  6. Nov 25, 2014 at 12:49 PM
    #5486
    drmcstford
    drmcstford The Sauce Boss
    David
    Glendora, CA
    14 Prerunner TRD OR
    Remove the upper load? Link not quiet sure what that is... And no i will carry things every once in a while due to my family thinking my truck is a private uhaul for them....:rant:
    Yea sweet I'll probably end up doing that :D
  7. Nov 25, 2014 at 12:52 PM
    #5487
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Removed top plate spacer and achieved my rake again..on 885s
  8. Nov 25, 2014 at 12:59 PM
    #5488
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Just get the Wheelers HD pack if you don't carry constant weight
  9. Nov 25, 2014 at 2:21 PM
    #5489
    EGoldie
    EGoldie Some Miles Under My Belt
    Evan
    Austin, TX
    08 DCSB TRD Sport 4x4
    OME 885/Dakars, 285/70/17 Toyo AT2, LR UCAs
    That's the look I'm going for.
    This is so frustrating that my front end is lifted this high.
    I'm pulling everything apart tonight and redoing the install with new strut bushings and removing everything but the trim packer.
  10. Nov 25, 2014 at 2:30 PM
    #5490
    Jeffvt0508
    Jeff
    Anderson, SC
    Yea..I was slightly nose high when I put things in bed..I have Dakars in rear but just would sag slightly enough that I could notice.. now just full ome no spacer..way it was meant to be..drives smoother too
  11. Nov 25, 2014 at 2:34 PM
    #5491
    Jeffvt0508
    Jeff
    Anderson, SC
    The 10 mm spacer lifted my front a full inch ..definitely was my issue
  12. Nov 25, 2014 at 6:25 PM
    #5492
    EGoldie
    Evan
    Austin, TX
    So I figured out my problem. Previous owner had a Daystar spacer lift installed. When I installed the OME, I removed a fat top plate spacer that was installed and assumed the shock mount and coil isolator were factory. Turns out the factory coil isolator was a 3/4" spacer from Daystar.
    I don't have factory isolators so now I've got some on the way.
    So thay will fix my issue. Only thing I'm still a bit mixed on is if the Taco lean is amplified with spacers. It is currently taking a trim packer and a 10 mm spacer to level it out with the passenger side.
    Guess we'll find out next week.
  13. Nov 25, 2014 at 7:38 PM
    #5493
    Jeffvt0508
    Jeff
    Anderson, SC
    Both sides have the daystar spacer?..it could be that..all that just amplified it. Your coil isolators didn't come with your old man emu?
  14. Nov 25, 2014 at 7:54 PM
    #5494
    EGoldie
    Evan
    Austin, TX
    Yes, both sides have the spacer isolator and no, no OME isolator included.
    Is there usually??
  15. Nov 25, 2014 at 7:57 PM
    #5495
    Jeffvt0508
    Jeff
    Anderson, SC
    No
    ..I just reuse your top plate mount from stock
  16. Nov 25, 2014 at 8:30 PM
    #5496
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Got my lift on!!!
    Old Man Emu 882 front coils
    Old Man Emu Nitrocharger Sport front shocks
    JK 10mm Trim packer
    Old Man Emu Dakar rear leaf springs
    Old Man Emu D6XL Add a leaf
    Old Man Emu Nitrocharger Sport rear shocks
    Old Man Emu shackles.
    Feels a heck of a lot better then my spacer set up, first impressions, really firm, solid, seams like a nice kit, will the ride get any smoother once it's broken in? Should I take my sway bar off?
  17. Nov 25, 2014 at 8:31 PM
    #5497
    Jeffvt0508
    Jeff
    Anderson, SC
    Got pics?
  18. Nov 25, 2014 at 8:32 PM
    #5498
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    We finished it and it was dark already I'll get some in the light tomorrow.
  19. Nov 26, 2014 at 2:02 AM
    #5499
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    Ditch the sway bar!
  20. Nov 26, 2014 at 4:06 AM
    #5500
    Jeffvt0508
    Jeff
    Anderson, SC
    I like having my sway bar...feel more stable than without it..
