Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 3, 2014 at 7:13 AM
    #5541
    mdne04
    mdne04 Well-Known Member
    Eduardo
    Weslaco, Texas
    DCSB TRD Off-Road 4x4
    OME 3" kit (885's), LR-UCA's, Dakars, Ext. rear brake lines
    Would the 1/4" spacer go on the passenger side or take the place of the trim packer?
  2. Dec 3, 2014 at 7:30 AM
    #5542
    EGoldie
    EGoldie Some Miles Under My Belt
    Evan
    Austin, TX
    08 DCSB TRD Sport 4x4
    OME 885/Dakars, 285/70/17 Toyo AT2, LR UCAs
    I have the trim packer installed on the shock and 1/4" spacers installed on both sides.
    As far as my CVs go, I'm not rubbing any more like I was but I also wouldn't want to go any higher. Actually considering a diff drop to open them up a bit more.
  3. Dec 3, 2014 at 7:35 AM
    #5543
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The OME trim packer goes on the driver's side to help compensate for taco lean
    Are you also going to add spacers for more height ?
    TacoManSam likes this.
  4. Dec 3, 2014 at 8:25 AM
    #5544
    mdne04
    Eduardo
    Weslaco, Texas
    I understand the use of the trim packer to compensate, I think I was just over thinking at the time.
    I was considering adding spacers for the full 3" and have it sit more level (dakars in the rear).
  5. Dec 3, 2014 at 8:28 AM
    #5545
    OZ-T
    Peter North
    British Columbia
    Then do the OME trim packer on the driver's side ( which goes below the coil ) and add a top plate spacer to each side
  6. Dec 3, 2014 at 9:08 AM
    #5546
    mdne04
    Eduardo
    Weslaco, Texas
    Got it, thanks. Will the 1/4" suffice or would the 1/2" be better?
  7. Dec 3, 2014 at 9:13 AM
    #5547
    OZ-T
    Peter North
    British Columbia
    Are you adding any additional weight over stock ?
  8. Dec 3, 2014 at 9:19 AM
    #5548
    mdne04
    Eduardo
    Weslaco, Texas
    Lights up front and maybe upgrade the stock skid plate.
  9. Dec 3, 2014 at 9:24 AM
    #5549
    OZ-T
    Peter North
    British Columbia
    I got 2 1/4 - 2 1/2" out of 885's alone on my DCLB 4x4 so theoretically the 1/4" spacers should put you right around 3"
  10. Dec 3, 2014 at 9:37 AM
    #5550
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    If unsure on the spacer I would wait..let the Dakars settle a little..mine settled 1/2 inch.. ..I had 10 mm spacer and it caused me to be nose high
  11. Dec 3, 2014 at 9:37 AM
    #5551
    mdne04
    Eduardo
    Weslaco, Texas
    Cool. Thanks for the help.
  12. Dec 3, 2014 at 9:39 AM
    #5552
    OZ-T
    Peter North
    British Columbia
    Or just use the 1/4" spacers with the factory studs
  13. Dec 3, 2014 at 9:41 AM
    #5553
    mdne04
    Eduardo
    Weslaco, Texas
    Good point.
  14. Dec 3, 2014 at 9:43 AM
    #5554
    mdne04
    Eduardo
    Weslaco, Texas
    You lost me OZ.
  15. Dec 3, 2014 at 9:45 AM
    #5555
    OZ-T
    Peter North
    British Columbia
    If you go with a spacer any thicker than the 1/4" one you need to replace the top hat studs with longer ones to accomidate the spacer thickness
  16. Dec 3, 2014 at 9:57 AM
    #5556
    mdne04
    Eduardo
    Weslaco, Texas
    Ah ok. That makes sense. I stick with the 1/4" then. Thanks for clearing that up and for the advice.
  17. Dec 3, 2014 at 1:21 PM
    #5557
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Would I need to purchase aftermarket UCAs or anything else with this kit:
  18. Dec 3, 2014 at 6:40 PM
    #5558
    TimberLandTaco
    TimberLandTaco Well-Known Member
    Mason
    Northeast Oklahoma
    2012 Timberland Mica TRD Offroad
    Light, Bumpers, and lots of switches.
    Can anyone tell me how long it will take someone with good mechanical skills to install a full ome lift (new leafs and everything but new UCA) or would it be better to pay a shop to do it
  19. Dec 3, 2014 at 7:05 PM
    #5559
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    ^ It took me about 8 hours for my first and only install, but I was being overly methodical. It's not really that difficult. If you think that you can do it yourself then I suggest doing so. You will appreciate and understand your suspension much more. Also, it should save you money for more parts.
  20. Dec 3, 2014 at 7:11 PM
    #5560
    TimberLandTaco
    Mason
    Northeast Oklahoma
    I'll do it myself then
