Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Dec 22, 2014 at 7:28 PM
    #5681
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I have ome with 885's. When I'm in a turn usually happens full lock turning left. I hear a pop sound. I've heard it on both sides. Any ideas?
  2. Dec 22, 2014 at 10:24 PM
    #5682
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Sorry on phone..couldn't see that
  3. Dec 22, 2014 at 11:09 PM
    #5683
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    You will have a bit of rake at first with the AAL, I sure did. I threw a few bags of concrete mix in the back for a couple of weeks and it helped it settle quicker. Out of curiosity, what made you decide on the 883's instead of 882's?
  4. Dec 22, 2014 at 11:16 PM
    #5684
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Heavy bumper, heavy winch. Firm, less bouncy ride. I'll see how I like it. It was honestly a toss up between the two and I had more people recommend the 883 for my application.
    I'll throw out the same question for you why 882 over 883? :p
  5. Dec 22, 2014 at 11:20 PM
    #5685
    Jiveydude
    Micah
    OH
    04Taco
  6. Dec 23, 2014 at 4:45 AM
    #5686
    btdawgs10
    btdawgs10 Well-Known Member
    Alabama
    08 PreRunner SR5 2wd
    What about brake lines for the front
  7. Dec 23, 2014 at 6:19 AM
    #5687
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    I know these questions have answered before. It's still a little confusing, and I don't want to do this twice. I've got a '14 DCLB 4x4 with full skids, sliders, and a camping shell (basically a heavy pig). I was only hoping to get 2-3" of lift from stock so I can keep good CV angles. Questions are:
    1. Which springs? 885, 886? Would like to error on the heavy side for future bumpers and winch.
    2. Which leaf springs? Daker? Again, heavy side (possible HC bumper with swing out).
    3. Is OME a good setup for my rig as a daily driver with a mix of off-roading? I know some people are installing fully adjustable coil overs. I don't mind spending the extra $, but only if it is needed.
    Thanks for the help.
  8. Dec 23, 2014 at 6:23 AM
    #5688
    crazy joker
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    That was quick! Kind of what I was thinking. Thank you.
  9. Dec 23, 2014 at 6:32 AM
    #5689
    crazy joker
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    I had to do the armor first, as I already had some rocks hit some stuff. Now a lift is an absolute must. Bumpers will have to wait though. Expensive stuff. Thanks again for the help.
  10. Dec 23, 2014 at 6:48 AM
    #5690
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    thats me exactly,I'll look into that, can someone send a picture of these bolts I think I've counted 4 if I'm looking at the right bolts
  11. Dec 23, 2014 at 6:53 AM
    #5691
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Oz-ARB says OMESB108 are poly bushings for CS047R Dakars. Should be available from any OME ARB dealer.
  12. Dec 23, 2014 at 7:42 AM
    #5692
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Awesome , good to know
    are they for front and rear or just rear ? The Dakars come with the fronts already installed with OEM style bushings or at least they used to , do you remove them and install these or do you know if the fronts are now poly ?
  13. Dec 23, 2014 at 8:02 AM
    #5693
    MTyota86
    MTyota86 Well-Known Member
    Haverhill, MA
    09 TRD Off-Road
    Airaid Intake, Magnaflow Exhaust, Diff Breather, SOS Concept Sliders, OME 3" Lift, SOS Concept rear bumper, Plasti-Dip grill and Badges.
    I'm gong to be looking to do just about the exact same setup. Are you saying to put the 886s on before the front bumper? I would be worried about the front being to stiff.
    I have no lift now with skids and SOS sliders.
  14. Dec 23, 2014 at 8:36 AM
    #5694
    Jiveydude
    Micah
    OH
    04Taco
    I ran 881's until I added a full set of skids and the ride was perfect, so picking 882's was an easy choice as they have the same spring rate as the 881's. Even now with the addition of a winch, sliders and IFS skids the ride is just how I like it. I'll think about going to 883's when I add the second battery and the under-hood welder.
  15. Dec 23, 2014 at 9:05 AM
    #5695
    reasonselzzz
    reasonselzzz TAMU '18ish
    Reason
    Temple, TX
    2010 PreRunner 1981 Pickup
    I plan on getting 884x and was wondering if the nitros or bilstein 5100s would be better. I do not do any serious off roading.
  16. Dec 23, 2014 at 9:09 AM
    #5696
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I have 884s and Bilstiens and the ride is great.
  17. Dec 23, 2014 at 9:39 AM
    #5697
    68vert
    AZ
    DCSB 4X
    Ha! I wish I had that level of clarity myself? ARB just kept repeating "you'll need 2 packs for 1 leaf". ??? After asking 3 times 3 different ways, I just came to the conclusion I'll ask the dealer upon ordering.
    Just received my leafs and the fronts are still rubber. Ordered polys from Toytec and they have a noticeable gap between the poly bushing and spring eye. Toytec says they will expand. From all my past experiences, poly bushings have always been press in by hand or c-clamp. Whats your opinion here?
  18. Dec 23, 2014 at 9:41 AM
    #5698
    la0d0g
    running for the hills
    For crawling not hauling
    What Scott said. Crap might be too strong of a word but it'll definitely ride stiff with only a little bit of armor and 886s. Coils are relatively inexpensive so if its going to be a long time before you put an aftermarket bumper/winch on the front I would just do 885s for now.
    Agreed, prior to my 886s I had 884s paired with billys running 265s and the ride was great.
  19. Dec 23, 2014 at 10:06 AM
    #5699
    OZ-T
    Peter North
    British Columbia
    We used a bench vise to press in my OEM bushings into the rear Dakar eyes , and you needed 2 per leaf pack , sounds like the poly ones from OME / ARB are intended to only replace the need for OEM bushings ( or another aftermarket ) bushing on the rears
  20. Dec 23, 2014 at 12:03 PM
    #5700
    MTyota86
    Haverhill, MA
    09 TRD Off-Road
    That's kind of what I figured. I would also assume the same goes for the dakars in the rear.
    Thanks for the input.
