Old Man Emu: Questions, Answers & Pictures
Discussion in 'Suspension' started by 4Wheelin4Banger, Jan 15, 2013.
  1. Feb 4, 2013 at 8:25 PM
    #581
    4Wheelin4Banger
    4Wheelin4Banger [OP] Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Only if you put a heavy plate bumper & winch on it.
    886s will give you more than 3" and you don't want that.
    885s will probably give you around 2.75"
  2. Feb 4, 2013 at 8:30 PM
    #582
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Go back to post 619. I just posted it I have an access cab im running 885 with no top spacers except the 1/4 on the driver side for exactly 3 inches.
  3. Feb 4, 2013 at 9:22 PM
    #583
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    Thanks guys, I'm just trying to avoid the top plate spacers of possible for that 3"
  4. Feb 4, 2013 at 9:26 PM
    #584
    just2wd
    Dan
    California
    What size tires do u have gabassman?
  5. Feb 5, 2013 at 1:15 AM
    #585
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
  6. Feb 5, 2013 at 4:14 AM
    #586
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    05 Access cab
    What did you put up front & what did you get?
    885's & Nitro Charger struts
    Before
    LF 20.0" RF 20.5"
    After
    LF 23.25 RF 23.5"
    What did you put in back & what did you get?
    Before
    LR 21.5" RR 21.5"
    After
    LR 25.5" RR 25.5"
    Are you running trail armor & how much lift did you loose or what did you do to regain/maintain lift?
    No trail armor.. yet. planning on adding a rear bumper with swing out tire carrier.
    Tire & wheel specs & rub or what you did to eliminate rub.
    Are you still running a sway bar?
    standard 265/70/16's on stock rims as of now. 285/70/17 on SCS Stealth 6's will be on in the next few weeks so I will edit this post when that happens.
    No sway bar, truck drives great on road
  7. Feb 5, 2013 at 5:12 AM
    #587
    Gabassman
    Tyler
    Georgia
    265/75r16
  8. Feb 5, 2013 at 7:08 AM
    #588
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    I just did my OME and had the dakars installed. I purchased my lift and had it installed by Cruiser Outfitters ([FONT=Arial,Helvetica][SIZE=-1](801) 518-3937[/SIZE][/FONT]). They put in the new bushings, I am pretty sure he has them in stock.
  9. Feb 5, 2013 at 7:13 AM
    #589
    nj636
    Kev
    Jersey
    I used the poly bushings from wheelers and was able to put them in by hand.
    All Pro steel braided brake line front and rear, 2 front 2 rear.
  10. Feb 5, 2013 at 7:14 AM
    #590
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I left the shackle bushings in and got OEM bushings from toyota for the dakars, you will need 4
  11. Feb 5, 2013 at 7:17 AM
    #591
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Those aren't for 2nd Gens
  12. Feb 5, 2013 at 7:18 AM
    #592
    OZ-T
    Peter North
    British Columbia
    I did this
  13. Feb 5, 2013 at 7:30 AM
    #593
    evanmb31
    evan
    connecticut
    09 trd off road
    Oem part number if you need it 90389-A0003
  14. Feb 5, 2013 at 8:36 AM
    #594
    4Wheelin4Banger
    Randy
    I added some Relentless sliders and it looks like it lowered front & rear 1/8"
  15. Feb 5, 2013 at 9:16 AM
    #595
    evanmb31
    evan
    connecticut
    09 trd off road
    Nice! Looks good. My bamf sliders should be going on next week.
  16. Feb 5, 2013 at 9:20 AM
    #596
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    So was thinking again... If I go with 886's will that put my DCLB over 3". I plan on doing a hidden winch up front (and really like the added shackle posts!). That won't be for a little while so would I be ok until I put that on? I know they would be stiff but that doesn't bother me.
  17. Feb 5, 2013 at 11:11 AM
    #597
    4Wheelin4Banger
    Randy
    Thanks, BAMF sliders look good too. Did you get the kick outs?
    886s will probably put you over 3" before the winch, you might be OK after the winch. Do the CV boot slide if you put the 886s on before the winch.
  18. Feb 5, 2013 at 11:43 AM
    #598
    teneighty
    886s will probably put you over 3" before the winch, you might be OK after the winch. Do the CV boot slide if you put the 886s on before the winch.[/QUOTE]
    Thanks
    after the winch, would I need top plate spacers to stay at 3"? I want 3" full inches to be able to run 285/70/17's...
  19. Feb 5, 2013 at 12:03 PM
    #599
    4Wheelin4Banger
    Randy
    Thanks
    after the winch, would I need top plate spacers to stay at 3"? I want 3" full inches to be able to run 285/70/17's...[/QUOTE]
    No, but you'll still need to trim for 285s.
  20. Feb 5, 2013 at 12:07 PM
    #600
    evanmb31
    evan
    connecticut
    09 trd off road
    No kickouts, but now i am thinking that i should have. My wheels stick out pretty far so they might stick out farther than the sliders by a hair. I guess i wont know until i get them mounted.
